ABS pump making noise at startup om 2000 lude
Every time i turn my 2000 prelude , my abs pump makes a noise like its pumping right then. i am not sure if that is normal. I went to honda for them to check somthing else out for me and they brought to my attention that it did that during startup. i already knew it did that, but of course they wanted to check it out for 80 dollars an hour so i said screw that. Is it normal for tyhe pump to make noise on startup? is it somthing i sould worry about?
Re: ABS pump making noise at startup om 2000 lude (TCPRELUDE)
I tell you what, I have a 92 Si 4WS and my ABS pump does the exact same thing. I had some 1 tell me that it might just be it checking it self for the pressure or something but it works perfectly fine.
Re: ABS pump making noise at startup om 2000 lude (HondaLude92)
yes if it is coming from the passengers side rear then it should be considered normal --- it primes itself or does a self check ....
From what I gather it's perfectly normal and is caused by your ABS unit doing a self diagnosis test on itself, as long as it stops after a few seconds then it is nothing to worry about.
preludexl
02-17-2003 07:31 PM
