#1 | |||||
"You really need to download that firmware update for your sarcasm detector..." ----------------------------------------------------------------------------------- D-Series Turbo Ninja EJ8-T Granada Black Pearl Full Custom D16Y8 SOHC Turbo Setup - 10 psi daily - Powered by Hondata 2B *UPDATE* - Payn Tech tuning in 2 weeks http://images.honda-tech.com/set1/smile/emthup.gif My Turbo Civic SOHC Sedan http://images.honda-tech.com/set1/smile/emthup.gif Rank My Ride!!! |
#2 |
Smarter than you
only problem will be is that once you install the turbo you will have to go back to get it tuned..
Chris Stein Crew Chief - Team Arturbo - 10.006 @ 149.2 www.Arturbo.com www.fast-turbo.com 817-439-3748 www.t1racedevelopment.com 214-607-9022 |
#3 |
Well that is a very small problem really. Hondata base maps are so good that OFTEN times even when the car is tuned, the variation from a base map is so small that it makes little difference. I think I will run the car on base maps until I find that it needs further tuning.
#4 |
Yea, but the difference between the WOT maps w/ turbo and w/o will be large!
Dave |
#5 |
Smarter than you
I dont think hondata uses a WOT map.. I think it adjusts fuel according to how much boost it sees and how much throttle is applied.. So I would assume that when there is no boost being read that it would just not deliver as much fuel..
#6 |
"I dont think hondata uses a WOT map.. I think it adjusts fuel according to how much boost it sees and how much throttle is applied.. So I would assume that when there is no boost being read that it would just not deliver as much fuel.. "
Correct. the computer reads the MAP voltage (boost) , retards the ignition and adds the fuel as necessary, so the system will work NA perfectly if setup for 440s. Doug
http://www.hondata.com |
#7 |
Doug, thanks for the answer. I thought this was how it worked. I will be going to get the system installed then going home with it to install the turbocharger.
#8 |
Doug: I asked this on the TOO board but got no answer.
With a Hondata, for a NA application, can non WOT be tunes as well as idle? Im using big cams which like lots of fuel, but when Im just cruising or idling...it runs WAY rich.
2002 Audi A4 1.8T |
#9 | |
mike
'05 RL-current '94 NSX '04 TL '93 del Sol Si-B18C1/Hondata/turbo |
#10 |
"With a Hondata, for a NA application, can non WOT be tunes as well as idle?
Im using big cams which like lots of fuel, but when Im just cruising or idling...it runs WAY rich." There are 10 load columns (Map sensor voltage) by 20 RPM positions tuneable for each cam. So yes it can be tuned easily for part throttle. It needs a tuner with a wide band lambda meter. It is preferably done on the road. Doug
#11 |
Hondata is the best, IMHO.
#12 | |
Dave |
#13 |
Can you install your turbo but not boost, and then install the injectors when you get your car tuned? I'm in the same kind of situation too, id like to get hondata as well but i have a huge drive.
[Modified by Devin, 9:15 PM 12/7/2001]
The number of stars in the little dipper is astronomical. |
#14 |
When you purchase the Hondata system your dealer can set it up for stock injectors or larger (typically 440 cc) injectors . In effect they would write two chips for you would match the chips with the injectors.
It does not matter if the turbo is not installed at the time, or if your wastegate is set to 0 lb boost with the turbo installed. When I said that There are 10 load columns (Map sensor voltage) by 20 RPM positions tuneable for each cam. That was for NA. With a 3 bar map sensor connected, there are 16 by 20 tuning points for each cam and the same for ignition. A total of 640 fuel and a further 640 ignition tuning points. A little more than most piggyback systems. Doug [Modified by Hondata, 11:00 PM 12/7/2001]
#15 |
why dont you install the turbo there?
<FONT COLOR="blue"> Official Member of BAN JOE club </FONT> bring dustin back |
| Bookmarks |
| Tags |
| 1990, 2001, acura, automatic, civic, honda, hondata, injectors, instal, install, installation, integra, motor, s2000, setup, tuning, turbo |
