> Engine Management and Tuning
Old 09-03-2004, 01:19 AM   #26
TurblowR
TurblowR's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (Mase)
Hey mase, let me know when you come back to cali, i want you to tune my built motor
sorry for OT
Cars:
2001 Acura Integra Type R Turbo *SOLD: February 2, 2001 - March 2, 2005*
2005 350z *February 28, 2005 - ???*
TurblowR is offline Report Post   Reply With Quote
Old 09-03-2004, 01:24 AM   #27
Alstare
Alstare's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (TurblowR)
How about some info on reading plugs since this seems to be a really key point to good tuning. There doesn't seem to be alot of coverage on the net other then general info on it..
This seems to be one of the taboo topic's of good tuners...
But i guess noone wants to give away there lively hood understandably soo...
-Brian
1996 Civic Si Built H22 Turbo
11.75@127.5mph on DR's
Alstare is offline Report Post   Reply With Quote
Old 09-03-2004, 01:37 AM   #28
Arturbo
Better than steak
Arturbo's Avatar
Send a message via AIM to Arturbo
Default Re: Technical Discussion on Tuning an FI car from Scratch (Alstare)
the plug checking is a secret.. jk. Mase, feel free to take this one. I guess draw a pic of one.
art
10.006@150mph T1 Race Development -Competition Clutch -Full-Race Motorsports
Don't call it a comeback...
Arturbo is offline Report Post   Reply With Quote
Old 09-03-2004, 01:52 AM   #29
Drew Peacock
Drew Peacock's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (Arturbo)
http://www.theultralightplace.com/sparkplugs.htm
Drew Peacock is offline Report Post   Reply With Quote
Old 09-03-2004, 02:08 AM   #30
Arturbo
Better than steak
Arturbo's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (turbozxi)
Originally Posted by turbozxi
Its actually alot easier than that.
Old 09-03-2004, 02:11 AM   #31
Drew Peacock
Do tell?
Old 09-03-2004, 04:22 AM   #32
soon2b
soon2b's Avatar
Send a message via AIM to soon2b
You were talking about knowing what the compression numbers should be for certain ratio's. What should the numbers be for 9:1 pistons in a h22. Sorry if this question is off the topic but it is something i would really like to know. Thanks
92 Civic Hatchback
h22 turbo
t4/t67, speed pro
Thanks to Howard@ AR Fabrication
Numbers and times comin soon
soon2b is offline Report Post   Reply With Quote
Old 09-03-2004, 05:31 AM   #33
White Smoke
i my honda
MoDeRaToR
White Smoke's Avatar
Mase, Keep it up I want to know more more more
I always second guess myself when checking plugs I always think I am reading them wrong or my readings are inaccurate. Hook it up with some tuner secrets. lol
Great Write-up
White Smoke is offline Report Post   Reply With Quote
Old 09-03-2004, 05:36 AM   #34
dirtySOHC's
dirtySOHC's's Avatar
id like to know as well.
you mentioned you can tell the amount of ignition timing a motor is running by reading a plug. how? too much timing =, too little timing = ???
also i dont want to get too specific on AEM or hondata but i plan on purchasing the AEM EMS to tune and id like to do it myself. anyway i understand the ignition numbers but the fuel? 210? 680? and so on.....that shit totally confuses me.
i dont plan to jump right in to tuning on my own which is why i want to soak in as much info as possible.
i've been able to keep my car running on the hack for over a year just off reading the pulgs. so i think if i learn a system well enough i will be able to street tune on my own.
THIS THREAD ROCKS BY THE WAY!
dirtySOHC's is offline Report Post   Reply With Quote
Old 09-03-2004, 06:52 AM   #35
jdmtim
You're 300% right!! Most of us just go off what were told from "a friends friend of my sister", I hope this tread never dies, Mase keep the knowledge coming. All the parts in the world don't mean a thing, if can't make them work as a team!!!!
jdmtim is offline Report Post   Reply With Quote
Old 09-03-2004, 07:17 AM   #36
Universal Magnetic
Universal Magnetic's Avatar
:Everybody has there own way of starting a tune. I personally always check these things before starting any tune, they aren't in any order.
1. Compression: Mase is right, just cause little HT Johnny says the motor is 9:1 because that's what the JE piston box says, doesn't mean it's really 9:1. Also, compression will give you an idea of how good the mechanical condition of the motor is.
2. Synch Ignition Timing: I always make sure my Laptop is reading the same ignition values as the timing light shows @ the crank pulley. This is by far the step that can screw up a tune if missed.
3. Check Fluids: Always check oil and coolant levels all the time. Especially when tuning a daily driver car. Sometimes people don't take care of their cars!
4. Wiring: Especially when the owner does his own work wiring a boost cotroller or any type of extra sensor added to the existing harness.
5. Supporting Parts: Make sure you check and verify the right spark plug heat range, size of injectors, fuel pump, FPR, base fuel pressure, wastegate spring pressure, size of nitrous jets, etc. These parts need to be able to support the horsepower demands of the engine.
6. Fuel: Verify what octane level the fuel is, from 87-93 pump gas, or C16 leaded
race gas.
7. Wideband O2: Make sure the wideband your using is operating properly/accurately so you know your AFR numbers are where they should be to avoiding melting pistons.
I'm still a newbie at tuning i've only used AEM and hondata systems so far and i still got a ways to go. I've signed up for the EFI101 class but never got any time off to go because of race season and work. My co workers Sean Mcelderry and John Reed do all these steps everytime we start a tune and it's definitely helped us so hopefully it will help you.
peace and chicken grease
RRev Motorsports
503 289 4020
Home of the fastest import in the PAC NW
Universal Magnetic is offline Report Post   Reply With Quote
Old 09-03-2004, 07:20 AM   #37
Rory Breaker
Rory Breaker's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (Universal Magnetic)
Great thread guys
Nick - Integra & Forced Induction Moderator
<FONT SIZE="4">Are you a DC Sports fan? This is your off-season kool-aid!</FONT>
Rory Breaker is offline Report Post   Reply With Quote
Old 09-03-2004, 07:43 AM   #38
B18CXr
B18CXr's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (dirtySOHC's)
Taken from the instruction .PDF provided with all EMS units....
B18CXr is offline Report Post   Reply With Quote
Old 09-03-2004, 07:56 AM   #39
EE_Chris
EE_Chris's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (B18CXr)
Great thread!
I would like to add, as others have, that an understanding of Speed-Density metered systems is in order as well. How can you tune if you don't even understand what the sensors on the motor are doing and how they are interacting with one another?
I have in my possesion quite a few .pdf's that explain Honda's fuel injection system. Its a good read and its free to you - just throw me a PM with an e-mail address that can hold a 10M file (zipped) (Yahoo! works great for this).
If you want it, but can't PM me for some reason - my e-mail is ics4me@yahoo.com.
The Helms | How-To: EK swap guide | .nate's Tuning Resource
Team Fortress 2: HT_THOR
EE_Chris is offline Report Post   Reply With Quote
Old 09-03-2004, 08:14 AM   #40
Overblown-Teg
Overblown-Teg's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (EE_Chris)
I'd like some details on the plug reading and tips on tuning timing, especially part throttle.
Overblown-Teg is offline Report Post   Reply With Quote
Old 09-03-2004, 08:27 AM   #41
b00sted2.0L
b00sted2.0L's Avatar
good write up.
b00sted2.0L is offline Report Post   Reply With Quote
Old 09-03-2004, 08:34 AM   #42
buckfittyone
buckfittyone's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (b00sted2.0L)
lets get more specific on tuning proper ignition timing
RBG
buckfittyone is offline Report Post   Reply With Quote
Old 09-03-2004, 09:10 AM   #43
DENCIO
DENCIO's Avatar
Send a message via AIM to DENCIO
Default Re: Technical Discussion on Tuning an FI car from Scratch (buckfittyone)
like he said
Turboedit
DA squad member #20
DENCIO is offline Report Post   Reply With Quote
Old 09-03-2004, 09:38 AM   #44
JDM EJ1 95
Send a message via AIM to JDM EJ1 95
PLEASE keep this thread going with usefull information... i am EXTREMELY interested in what goes into the tuning aspects of these FI hondas and other cars in general
bitch..... Please
01.5 Stg 3 S4, meth injection, DP's, CCW classics baulin
12.3 on pump
JDM EJ1 95 is offline Report Post   Reply With Quote
Old 09-03-2004, 09:51 AM   #45
Mase
Moderator
Mase's Avatar
Send a message via AIM to Mase
Default Re: (soon2b)
for instance, my gauge will usually read 200-210 psi for approx. 9:1 compression. 10:1 is usually 230-240...
http://www.MaseEngineering.com
Mase is offline Report Post   Reply With Quote
Old 09-03-2004, 10:07 AM   #46
Mase
Moderator
Mase's Avatar
Default Re: Technical Discussion on Tuning an FI car from Scratch (Overblown-Teg)
The correct way to tune ignition timing is on a steady state dyno, hold it at a certain load cell and adjust the timing until the maximum torque is achieved. We actually used one of my cars i street tuned, the timing was pretty damn close. maybe 1-3 degrees off at most, and we are talking about minimal difference. so for partial throttle dont worry as much... just make sure your AFR's are in check, which 90% of HT tuners and shop owners can never tune ALL of partial throttle for shit, I have a nice collection of "GREAT" tuners who's partial throttle maps are just something to laugh at.
Ignition timing under WOT is a little more subjective.
A few things you need to consider before tuning:
Compression Ratio, Bore Size, Fuel Octane, Boost pressure and other factors (we wont get into much detail).
As we've already discussed why you run less timing w/ more boost or load, thats all im going to cover on that.
As far as the spark plug reading....its sorta hard to explain, and ive been sworn to the secret haha basically, you can tell by the color change of the spark plug what kind of timing. you will also know, w/ any type of "snow" or white specs, you are experiencing detonation and the motor will not last.
Old 09-03-2004, 10:19 AM   #47
JDM EJ1 95
im extremely interested in all of this.. i need a great place to start at.. anyone have links or resources that you can post just so i can read a lot.?
bitch..... Please
12.3 on pump
Old 09-03-2004, 10:19 AM   #48
Mase
Moderator
Mase's Avatar
Originally Posted by EE_Chris
Great thread!
Yeah id love to read it. Ill send u a pm.
basically most people will know Honda uses a speed density system. The cars use whats called a MAP sensor which only measures pressure. (its actually a flexible diaphram that flexs due to pressure changes) They calculate the the increment of fuel by pressure and rpms. once you start messing with the flow of the engine, the caculation or parameters of the stock Fuel Map is greatly different. I think j davis went into this quite a bit in his hack thread if im not mistaken.
The other system uses whats called a mass airflow system. which measures the actual airflow instead of pressure like the map sensor.
this is why its extremely important to properly tune a FI car. Just because a certain system is say at 14 psi. that doesnt mean the flow cant change. slap on a larger turbo and chances are, its going to flow a hell of a lot more at the same 14 psi.
Other important sensors are: TPS sensor, Intake Air Temp sensor, Coolant temp, rpm or tach signal, and of course your wideband o2.
can anyone tell me why even the TPS sensor is important?
Old 09-03-2004, 10:20 AM   #49
Mase
Moderator
Mase's Avatar
Default Re: (JDM EJ1 95)
my honest answer to that is sign up for Ben Straders EFI101 class at http://www.efi101.com
he covers a lot of this same material, and in even greater detail.
Old 09-03-2004, 10:25 AM   #50
Paul_VR6
Paul_VR6's Avatar
Acceleration enrichment, if you didn't have it the A/F would dip low on sudden throttle openings. Do this under boost and you might even get the silver flecks on your spark plugs that you always wanted.
You don't need a TPS at all for steady state (you can run off of MAP/RPM values with no trouble) but transients are all shot to heck.
-Paul
1995 GTI VR6 2792cc - Street Stock - 12.833@105.48 and falling
:::The Race Shop - KPTuned
Paul_VR6 is offline Report Post   Reply With Quote
Bookmarks
2000, fi, honda, lbt, mbt, tech, torque, tuning
