A or B pistons, where is it stamped?
Old 06-13-2004, 10:31 AM
Matgallis's Avatar
Default A or B pistons, where is it stamped?
I remember seeing a post a few weeks ago about how to tell which pistons you have (a/b) I can't find that post anymore (it had pictures and stuff)
Can anyone point me in the right direction on where the hell on the block it is stamped? Is there anyway to tell without removing the head or other parts?
Old 06-13-2004, 11:21 AM
NXLude's Avatar
back drivers side, down low........you can also illuminate the cylinder itself (through plug hole and see the stamp......i discovered this last week
Old 06-13-2004, 12:02 PM
Matgallis's Avatar
Default Re: (NXLude)
will I be able to see it easily on the block? I jsut looked and couldn't see much ( a lot of wiring, tubes and stuff in the way.
Old 06-13-2004, 12:14 PM
phryxis's Avatar
Old 06-13-2004, 12:26 PM
Matgallis's Avatar
Default Re: (phryxis)
oh wow, thanks a million! I've heard that there are a series of letters? Abba or something like that, is this true? I saw on yours only an A, so all the pistons are A?
Old 06-13-2004, 12:31 PM
phryxis's Avatar
yeah there will be 4 letters, you just can't see the others in the picture. It can be any combination of A and B. Mine happened to be AAAA. The stamp might be dirty, I just wiped it off with my finger.
Old 06-13-2004, 01:11 PM
pentaq's Avatar
Hey, mods!!
This is a great topic to be mentioned in the Essential Links!
Old 06-13-2004, 04:43 PM
VTECRaZeR's Avatar
Default Re: (pentaq)
Does it make a difference which pistons you have...?
Old 06-13-2004, 06:47 PM
racerx's Avatar
Default Re: (VTECRaZeR)
It does if you're swapping them.
Old 06-13-2004, 07:05 PM
NXLude's Avatar
mine are abab
Old 06-13-2004, 08:35 PM
LudeyKrus's Avatar
I think mine were either all A's or B's. I'll have to check on my H22 block and H23 block and see.
Old 06-13-2004, 10:26 PM
Matgallis's Avatar
Default Re: (LudeyKrus)
what's the whole reasoning behind having a series of different pistons(abba)? I mean wouldn't it make more sense to have one engine have all A and another engine have all B instead. The difference in each piston is so minuscule...
Old 06-13-2004, 10:36 PM
space cadet
Shakes's Avatar
Default Re: (Matgallis)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Matgallis &raquo;</TD></TR><TR><TD CLASS="quote">what's the whole reasoning behind having a series of different pistons(abba)? I mean wouldn't it make more sense to have one engine have all A and another engine have all B instead. The difference in each piston is so minuscule...</TD></TR></TABLE>
so you can be like these guys
Old 06-14-2004, 01:13 AM
phryxis's Avatar
Default Re: (Shakes)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">so you can be like these guys
that is so retarded yet SO FUNNY!
the differences in the piston sizes are to accomidate for differences in the block casting.
Old 06-14-2004, 05:03 AM
OTT
OTT's Avatar
hehe Funny Stuff, Goood info to on these markings. Is that the only reason they have diff pistons? to make up for variables in the casting?
Old 06-14-2004, 07:51 AM
LudeyKrus's Avatar
Honda has always been a stickler for running very exact clearances, so the different size pistons are to make up for the tolerances in the machining and casting processes....much the same way there's like 5 different bearing sizes in OEM Honda bearings.
Old 06-14-2004, 12:32 PM
SKDRCR's Avatar
Default Re: (PirateMcFred)
What if you're putting h22a1 pistons in an h23?
Does the same thing apply?
Old 06-14-2004, 02:17 PM
LudeyKrus's Avatar
Default Re: (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">What if you're putting h22a1 pistons in an h23?
Does the same thing apply?</TD></TR></TABLE>
I would say yes. The blocks are identical and the piston bore is the same, so the procedure for determining piston sizes should be the same as well.
Old 11-20-2010, 10:42 AM
4G92's Avatar
Default Re: A or B pistons, where is it stamped?
rehost pics pleasE?
ivan93egreppin210
07-09-2012 06:43 AM
jv88_dc2
10-31-2010 02:31 PM
turbolou
07-03-2003 11:37 PM
p10hlm
01-07-2003 11:25 PM
Smurfylude
05-01-2002 04:39 PM
Quick Reply: A or B pistons, where is it stamped?
