> Forced Induction
Old 04-22-2004, 03:22 AM   #1
Joseph Davis
Joseph Davis's Avatar
Send a message via AIM to Joseph Davis
Default AFC hack ignition recurve explained.
Almost two years after I start bitching about it, here's what I hope is a decent explaination. Pester me with Q's if I'm a tard and can't explain it properly. It's late, I'm tired, and I suck - I hope I've excused myself sufficiently in advance.
Accept these as facts, for speed density EFI anyway:
- MAP sensors indicate engine load. The more load, the more Manifold Absolute Pressure on the engine, the more fuel it requires. Under boost you need a whole lot of fuel, right?
- AFCs manipulate MAP signal to alter fuel. By lowering MAP voltage, you aim the ECU at a data location tuned for a lesser load, and you get a bigger set of injectors to act a lot like stock injectors. Making, say, the usual DSM 450cc behave like 240cc injectors for your off boost driving.
Let's have a look at a fuel map off of one of the freeware Honda ECU tuner applications to help visualize how this works. The numbers down the left hand side of the map, the Y-axis for you boring math types, are familiar old RPM values. The numbers across the top, on the X-axis are MAP input translated into mBar. For those of you unfamiliar with mBar, 1000 mBar is 1 Bar or 14.5 psi... 1055 mBar is 14.7 psi or atmospheric pressure. Looking at this B16 fuel map, you go from vacuum on the left to atmospheric pressure on the right.
[img]http://***************.com/gallery/d/108719-2/abr.jpg[/img]
I went ahead and filled in the blank spots below the stock mBar numbers with pink numbers to represent where on the fuel map an AFC sends you with it set to a -40% fuel cut. Pink is a very good color to use for this purpose, as this is a VTEC fuel map.
Now, guys, if you've choked all that down, before we look at the ignition map let me remind you of one single solitary fact in re speed density EFI:
- Ignition maps aren't like fuel map, bitches.
[img]http://***************.com/gallery/d/108713-2/abp.jpg[/img]
From this we conclude that if you transition into boost at 4000 rpms, you are at 39 degrees advance with the AFC hack where the stock crossover is at 24 degrees. Jacking your distributor forward 15 degrees before you hit boost is a great idea! Hey, let's buy an MSD BTM, and it'll dial that 15 degrees ar 0 psi boost right out, won't it?
Well, you want to be safe so you only run a low boost setup, 5 to 6 psi. Whatever the hell low boost has to do with safe, I keep thinking quality of tune and power output are your yardsticks to measure engine safety by... but what do I know? So you run 5 to 6 psi... ~1400 mBar. With the AFC hack you are at 31-32 degrees ignition advance, around 7 degrees advanced from where you would be without any ignition retard under boost with any other setup. Let's not even take into account the higher load your engine is under, and the heat and stresses involved. My, the sweet sound of detonation in the morning!
Now, heaven forfend you should have paid me a lick of attention when I advised people that running as much boost as the stock Honda MAP sensor is capable of reading is your route to safety with the AFC hack. Note how you end up within a degree or so of your otherwise normal ignition timing when you transition into boost. You can't help the transitory high ignition advance you pass through, but with how quickly turbos spool in most cases it doesn't matter; you spend the bulk of your time during the boost event at full boost, and if you have retarded your distributor 2-3 degrees you should have adequate ignition retard under boost.
I'd like to thank the following for inspiration in making this post: Del Slowest, insomnia, too much coffee, a complete and utter lack of respect for VTEC, and Speed Phreak's LS powered goodness:
[img]http://***************.com/gallery/d/107442-2/aaw.jpg[/img]
Modified by J. Davis at 6:18 PM 2/26/2006
There is no mechanical problem so difficult that it can not be overcome by brute strength and ignorance.
Joseph Davis is offline Report Post   Reply With Quote
Old 04-22-2004, 03:51 AM   #2
Trac226
Send a message via AIM to Trac226
Default Re: AFC hack ignition recurve explained. (J. Davis)
Thank you. I've read your previous posts about this and this summary helps out a lot.
Trac226 is offline Report Post   Reply With Quote
Old 04-22-2004, 05:16 AM   #3
S2KP
S2KP's Avatar
Send a message via AIM to S2KP
very well explained
S2KP is offline Report Post   Reply With Quote
Old 04-22-2004, 05:47 AM   #4
91civicDXdude
91civicDXdude's Avatar
what formulas are used to convert in/HG vacuum into mbar, and also how to convert your AFC percentage into the scaled numbers we see in pink?
(i am OBD0 and turboedit doesnt use mbar )
'94 Del Sol VTEC - T3/T04E E85 Tuned on Crome
91civicDXdude is offline Report Post   Reply With Quote
Old 04-22-2004, 05:47 AM   #5
who00knows
who00knows's Avatar
Send a message via AIM to who00knows
Default Re: (Turbo_Siii)
Nice write-up Joseph...Will be looking forward to working with you on the duration of my build up.
| Pamlico Provision Co. |
| P1 Auto |
| R&D Motorsports |
who00knows is offline Report Post   Reply With Quote
Old 04-22-2004, 05:58 AM   #6
GSRswapandslow.
Guest
Posts: n/a
Joseph = stunna
Old 04-22-2004, 06:04 AM   #7
boostincoupe
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Send a message via AIM to boostincoupe
Default Re: (Ej6andslow)
So basically the AFC hack sucks? Sorry, I'm trying to dissect the info. and that's the main point I could gather.
EJ8 Squad Member # 10, bitches.
97 Civic EX coupe, turbo ITR - blown up and parted out...RIP
07 GSX-R 1000 - It's not a bike, it's an engine with wheels!
boostincoupe is offline Report Post   Reply With Quote
Old 04-22-2004, 06:12 AM   #8
notoriousB
notoriousB's Avatar
Awesome post. This is a great clarification - I just recently changed from an FMU to the AFC hack (night & day diff. already), unfortunately (for now) my car's OBD2 so my tuning options are limited. Running 7 psi now, and have a boost controller on order, will be upping to 10psi as soon as it comes in especially since reading this post.
Noobish question re: retarding the dizzy - is that possible w/ OBD2? I was under the impression that the ECU would just put the timing back in. -B
1998 Accord EX-L i4 5 speed, SC3231RE, AEM EMS, CP pistons, Crower billet rods, & other stuff
2005 Silverado 1500 Z71 extended cab, lowered, gibson exhaust, custom 93 octane tune
notoriousB is offline Report Post   Reply With Quote
Old 04-22-2004, 06:22 AM   #9
99lspwr
99lspwr's Avatar
Default Re: (who00knows)
J Davis:::
You really do love making/participating these afc posts huh???Anyway, good write up here!! However, you would not even want to know what I do with my afc, but all I can say is that its been working out good for a while now on my old ass ls motor....
92 EG hatch/full interior (sold 8-2-04)
Retired @ 11.73@118 (18g/ls equipped)
'04 350Z/96EK COUPE/89 4 RUNNER
99lspwr is offline Report Post   Reply With Quote
Old 04-22-2004, 07:03 AM   #10
tvrsir
tvrsir's Avatar
I have a question for you guys running the afc hack. is it mandatory to run the 88-91 resistor box or i can use any honda resistor box. i have a box from a 94 honda accord can i use that along with the afc hack? and dsm injectors
"AFTER 5000 RPMS ALL HELL BREAKS LOOSE"
tvrsir is offline Report Post   Reply With Quote
Old 04-22-2004, 08:14 AM   #11
99lspwr
99lspwr's Avatar
Default Re: AFC hack ignition recurve explained. (tvrsir)
I am runnin rc 440s with mine, so I dont need the resistor box....
Old 04-22-2004, 08:30 AM   #12
G"UNIT
sh!t happens.
G
Send a message via ICQ to G Send a message via AIM to G
Default Re: AFC hack ignition recurve explained. (99lspwr)
damn...nice wrie up dude...
<FONT COLOR="red">1992 Acura Integra GSR Turbo</FONT>
<FONT COLOR="black">TEAM ENVIOUS</FONT>-EST Since 1999
<FONT COLOR="black">DA SQUAD member #247</FONT>
GregUnit!
G Report Post   Reply With Quote
Old 04-22-2004, 08:56 AM   #13
Del_Slowest
Del_Slowest's Avatar
Send a message via AIM to Del_Slowest
Default Re: AFC hack ignition recurve explained. (G"UNIT)
Thanks for the write up. I've been trying to explain this for awhile but i never can put it in words that ppl understand
Previous - TD04H-15G Turbo Del Sol Si @ 6psi Ran the VAFC Hack, now i'm on Uberdata
sorta now - B16 Sir II swap w/ 50 trim T3 at 9psi
Now - B16 Sir II swap w/ 60 trim T04e wheel and .48 ar exhaust at 0psi
Now Now - B16 Sir II swap w/ 60 trim T04e wheel and .63 ar exhaust at 5psi
Vouches = Blundar, USDM 4G VTEC, Platinum00, ludehawk, dagreenhatch, eg6owner
Del_Slowest is offline Report Post   Reply With Quote
Old 04-22-2004, 09:02 AM   #14
Del_Slowest
Default Re: AFC hack ignition recurve explained. (Del_Slowest)
btw- the pics aren't working anymore.
Old 04-22-2004, 09:04 AM   #15
LostCRX
LostCRX's Avatar
Send a message via AIM to LostCRX
just want to make sure, so are you saying that it would be better to retard the timing as the dizzy opposed to using a MSD BTM?
LostCRX is offline Report Post   Reply With Quote
Old 04-22-2004, 09:18 AM   #16
willyboyK20
Default Re: AFC hack ignition recurve explained. (notoriousB)
I want to know that too?
EK Sedan Squad member #28
'04 6mt Acura TSX
www.stutune.com - coming soon
willyboyK20 is offline Report Post   Reply With Quote
Old 04-22-2004, 09:32 AM   #17
Del_Slowest
Default Re: AFC hack ignition recurve explained. (willyboyD16)
you can't retard at the dizzy on a 0bd2 motor. the ecu will know that something is up and change it back
Old 04-22-2004, 09:35 AM   #18
who00knows
who00knows's Avatar
uhm sure you can. Put a jumper at the ecu when you change it...it wont correct it then....
| P1 Auto |
| R&D Motorsports |
Old 04-22-2004, 09:48 AM   #19
notoriousB
notoriousB's Avatar
Default Re: AFC hack ignition recurve explained. (who00knows)
you can wire in 10 watt 10 ohm resistors to each yellow/black wire and not use a resisor box at all - works good for me.
can you please clarify this? a jumper where on my OBD2 ecu?
Old 04-22-2004, 09:55 AM   #20
twkdCD595
twkdCD595's Avatar
good info for people not already aware... for posting a write up most should understand.
-try not, do or do not... there is no try.
God bless the men and women of the U.S. armed forces.
T1 Race Development
Laskey Racing
PortFlow Design
Bisimoto Engineering
twkdCD595 is online now Report Post   Reply With Quote
Old 04-22-2004, 09:58 AM   #21
who00knows
who00knows's Avatar
Its a green plug by your ecu...might have a blue cover....you can use a paper clip if you dont have the honda jumper connector.
| P1 Auto |
| R&D Motorsports |
Old 04-22-2004, 09:59 AM   #22
TABIAS
I want to be MADE into Ice-T
TABIAS's Avatar
Send a message via AIM to TABIAS
very helpful, but I could not see any pics
thanks again
DX is deluxe (it's deluxe son, deluxe)
<FONT COLOR="pink">IHN</FONT>- Member - #0007
iNsAnE cRx 420: NAH SON I FUKIN JACKIE CHAN ***** WITH SKATES
iNsAnE cRx 420: I BE JUMPIN OVA HEADS N SHIT U AINT SEE ME ON ESPN15 SON
Ethuggin at it's best yO http://images.honda-tech.com/set1/smile/emthup.gif
EJ8 squad #35 http://images.honda-tech.com/set1/smile/emsmilep.gif
TABIAS is offline Report Post   Reply With Quote
Old 04-22-2004, 10:21 AM   #23
CRX T-Si
CRX T-Si's Avatar
Send a message via AIM to CRX T-Si
Default Re: AFC hack ignition recurve explained. (LostCRX)
What he is asking...
Carlos Mencia - "You ain't living if you ain't Laughing"
CRX T-Si is offline Report Post   Reply With Quote
Old 04-22-2004, 10:21 AM   #24
Del_Slowest
can't do that. thats only for obd1
Old 04-22-2004, 10:31 AM   #25
kpt4321
Send a message via AIM to kpt4321
JoJo, your pictures are screwed. I want to see the crazy fuel and timing map action!
Great post, and good idea. I never even thought to bring this up.
A while back I did a similar comparison, with similar results. Like you suggested, it manifests itself as knock. We're running a J&S Safeguard on my friend's turbo B18, and the thing would see knock and retard his timing to matter what I did with tuning and the distributor. Now that we are running proper engine management (Uberdata), the car runs amazingly better.
kpt4321 is offline Report Post   Reply With Quote
Bookmarks
91, accord, afc, cars, computer, del, fast, hack, hacks, honda, map, na, sol, tuning, turbo
