After many frustrating days with NO success. I FINALLY figured out how to get the pins out of the OBD1 injector clips. Without cutting and splicing. .
If I had a digicam, I'd post pix. But I don't, so you'll have to make due with my descriptions.
#1 You'll see a clear plastic post sticking out of the top of the rubber plug, on the wire-side of the OBD1 injector clip.
#2 Remove the black rubber plug from the back of the OBD1 injector clip.
#3 If plastic pin doesn't come out with rubber plug, pull on it gently with a pliers. It is used as a locking mechanism to hold injector wire pins inside the clips tightly and securely, so they can't be pulled out.
#4 Once the rubber plug and the clear plastic locking collar are removed the injector pins can be freed from the the clip in the usual manner, with a small flat pointed tool, inserted into the open pin side of the clip.
#5 You'll also need to remove the OBD1 injector clips rear rubber plug, as it's not compatible with the OBD0 one.(OBD1 has a hole for the locking collar tab, OBD0, does NOT) I sliced the rubber plugs open and then squeezed them over the injector wires on the OBD0 engine harness.
Hope this helps anyone who needs to change their injector clips from OBD0 to OBD1/2
And thanks, VTECVillain, for all the help so far.
Modified by 4crx4me at 5:03 PM 1/16/2004
1990 CRX Si
1992 GS-R DA squad # 277
Originally Posted by Strawb3rri3
so what I can be a wtf is that called? A BETAMAX if I WANNA BE!
Originally Posted by Knightsport
It's all about perception.
"YOUR attitude is neither wanted nor tolerated!! This mean YOU!"
damm, can you post some pictures. good write up, but i think pictures will do this info more justice
you never know until you try! buyers:
AllMotorCRX90--B18Flip--motore--b18c1_powered_si--Petah--blackstar--not so civic--TOR--igo4bmx
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for Honda-Tech.com content, comments, or advertising. Honda-Tech.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse Honda-Tech.com in any way.
Copyright/trademark/sales mark infringements are not intended or implied.
