| New! Use your Facebook to securely log into this site, click logo to login |
| Register | FAQ | Search | Today's Posts | Mark Forums Read | Garage | Vendor Directory | My Recent Topics | My Notes | Used Cars |
#1 | |
I've been reading Carroll Smith's "Tune to Win" lately, yet I've become a bit confused on the topic of lateral load transfer.
Total weight transfer at the front or rear is a function of the CG height, track, weight, cornering acceleration (seen at the CG), and thus is independent of the roll resistance. WT = (CG height)(weight)(cornering G's)/(track) or something like that. So the only reason we want high roll resistance is to prevent unwanted camber/toe changes and because it is inherently difficult to drive (much less quickly transition) a car that wallows about. I would also guess that the roll stiffness has an effect on how quickly the lateral load tranfer happens, but did not find enough info. in Prepare to Win or Tune to Win. C. Smith then goes on to say that the lateral load transfer is dependent upon spring compression. I'm assuming that this is because the compressed spring changes the roll center height and thus the roll moment will change and this should have an effect on the distribution of load transfered front and rear, correct? Larger roll stiffness in the front means more lateral load transfer between front wheels? But in terms of the actual load tranferred, it shouldn't matter, right? Edit: I just read descartesfool's post here (the big one), and it definitely answered some of my questions. I haven't considered or thought about load transfer through the suspension links (geometric transfer) or that the unsprung portion experiences load transfer and the only "spring and shock" is the tire...also, besides my stumbling across this particluar topic, I feel like I need more technical based reading. Can anyone offer book suggestions that get more in depth? Anyone care to discuss? or at least tell me where I am thinking incorrectly? Modified by GSpeedR at 7:01 PM 12/23/2003 |
#2 | |
Total load transfer is independant of suspension. Portion of load transfer at front "axle" compared to rear "axle" is what is affected by suspension. This determines oversteer/understeer balance based on tires and centre of gravity location, moment of inertia, etc.
'Common sense is the most fairly distributed thing in the world, for each one thinks he is so well-endowed with it that even those who are hardest to satisfy in all other matters are not in the habit of desiring more of it than they already have.' Rene Descartes |
#3 | |
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">Total load transfer is independant of suspension. Portion of load transfer at front "axle" compared to rear "axle" is what is affected by suspension. This determines oversteer/understeer balance based on tires and centre of gravity location, moment of inertia, etc.</TD></TR></TABLE> That makes sense. I found a few interesting articles here: http://www.ozebiz.com.au/racet....html (and I know there is a good amount of stuff out there too), that answered some other questions. So, the rate at which the sprung load is tranferred is determined by the suspension roll stiffness...and the unsprung and sprung transfer through the roll center depends on the suspension type, though they typically happen quickly and are far less than that of the sprung mass (I believe you stated that elsewhere). Can't wait to start playing around with ADAMS (FSAE team).
#4 | |
| Bookmarks |
| Tags |
| 2006, acura, axis, civic, distribution, ef, gravity, honda, load, rsx, weight, wheel, wheels |
