Where is the EVAP purge valve on 99 Si?
I'm running hondata and have been experiencing bad idle at startup, after a previous drive. Hondata says to pull the EVAP purge valve, I just wanted to make sure I pulled the proper connector.
Its the brown connector on the passenger side of the fire wall. It's connected to a black plastic canister.
Re: Where is the EVAP purge valve on 99 Si? (Civic Power)
Thanks Dave,
I guess I pulled the wrong Valve connector. I pulled the Canister Valve instead of the Purge Valve.
