#1 | |||||
Ghetto Garage Racing |
#2 | |
Nice write up but
#3 |
Oh, there's a bat alright. Look at one of the topmost pics
It's actually a genuine Louisville Slugger! Nothing but the best for my CRX!I'd like to also extend my thanks to sleeper4dr - who sent me an email containing 3 separate pictures and explaining in detail how to remove the transmission casing! This kind of community is what H-T is all about, and so to everyone who was willing to take time and help out someone they don't even know - thanks to you Have a on me!
#4 |
Great write up. I hope you dont mind if I print this is out.
She's only a b16, but yo she's a freak. |
#5 |
Of course not
Info is free! Hopefully it helps you out later if you decide to do this
#6 |
man do i wish i knew about trannys because i really need this done....lucky man really lucky. maybe ill just save for a clutch and do this all at once...
95 integra SFWD = sold NFR turbo S2000 590whp @ 21psi -pump 772whp @ 33psi -q16 Pick your poison
#7 |
excellent write up... someone needs to make it a sticky or a webpage that people can resource.
If you write it up into HTML, i could host it... Hate losing articles like this when i need them.
"Straights are for fast cars. Turns are for fast drivers." RIP Homer... My '90 Honda CRX HF Uh Oh... |
#8 |
It IS written up in HTML
That's the beauty of everything viewed online Just View Source. If you really want I suppose I can make you an HTML file out of it, though...
#9 |
since pictures are good at dissappearing and stuff i have backed this up to my website just incase 8 months from now someone does a search and finds this info
http://texas.clubsi.com/brandon/crx/finaldrive |
#10 | |
Something easier to upload. I don't want to play with it too much... :D
#11 |
LOL, well, it's been taken care of already
#12 |
#13 |
nice, now I just need to find the Counter shaft!
mugen無限power |
#14 |
dude, great write up. i could of helped you a little, but i was helping some friends over the long weekend. i like the part when the mainshaft bearring went flying, that happens to everyone who work on their trannie's for the first time! the only drawback to using the usdm s1/a1 5th gear, is that it's really tall. not like the usdm ys1 ls 5th, wich is more like the hydro gsr 5th gear!
you never know until you try! buyers: AllMotorCRX90--B18Flip--motore--b18c1_powered_si--Petah--blackstar--not so civic--TOR--igo4bmx sellers: b18c1_powered_si--Dominican_Kid--owen_the_soyboy--jason--Sp00n'd Supra--powerfulperformance--stingray2772--PseudoSilvia--nasteboyii--Big Teggie--toyosupr--EL Vap133--b19coupe--c13r--Kidloco51--dizzyroc88--MwGSR--bjorn156--seek167 |
#15 |
That was an absolutly excellent write up. What i'm wondering is what your gas mileage will be now. Make sure when you empty your first tank tell us how much your mileage went up too.
Dude it touched my lips but I never swallowed it I still have the explorer I'm gonna buy back the CRX B16 but my friend fu**ed it to hell, so it is litterly in pieces the tranny is in the hatch and various parts need to be repaired or replaced. I 'm looking so forward to be having two cars. One little racer, and the other a nice cruiser (explorers ROCK). THIRD: 98 Ford Explorer XLT 4X4 (current beater) SECOND: 95 Civic EX (traded for third car) FIRST:90 CRX Si B16 (traded for second car) |
#16 |
Great write up!
This kind of info is what Honda-Tech is all about. This will help a lot of new guys. |
#17 | |
haha
congrats on the install. i'm glad you got everything squared away and i'm glad i could help out.it's like you said, Quote:
ED3 <FONT COLOR="red">LS</FONT><FONT COLOR="white">/</FONT><FONT COLOR="blue">Vtec</FONT> My EF and LS/Vtec site (which I never seem to update http://images.honda-tech.com/set1//smile/emcrook.gif ) |
#18 |
For the sake of completeness, I feel I should mention a couple more things... stuff that you'd get if you were following a manual in addition to this writeup, but if you read the writeup alone you wouldn't get.
1) When replacing the transmission casing, use lacquer thinner to clean the casing mating surfaces, and then use high-temp RTV sealant on the case. Otherwise, you'll be taking it all apart again to fix the leaks. 2) When the case is together, be careful to torque the case down as evenly as possible using bolts as far away from each other as possible. You don't want to warp the case. I don't know how to explain it better than that, but just try and make sure the case moves down evenly against the flywheel cover. Don't torque moving around the case; torque across the case. I used about 20 ft-lbs on the bolts and Loctite on the threads, because I couldn't find the torque specs anywhere. 3) When the case is together and the bolts are torqued and Loctited, before replacing the plug covering the C-clip make sure the C-clip has snapped into place around the countershaft bearing. If it hasn't, you'll need to wiggle the countershaft into position until you hear the C-clip snap. I did this by using a small prybar and a gentle force against the nut at the top of the countershaft assembly. A light pry up and towards the center of the case locked the C-clip with a very audible 'click'. 4) Replace the MTF shortly after doing this procedure. You might get a little dirt and dust inside the case - not a huge deal for a short period of time, but it could get ugly if left in there for too long. 5) There's a magnet in the bottom of the casing that you can pull out with a set of needle-nose pliers. This is the magnet that catches all the gear shavings from worn gears. I cleaned mine up while I had the tranny out and removed all the little shavings as best I could. Might want to do this as well! 6) The selector fork for 5th gear will prevent you from removing this gear. You can wiggle it out of the way by removing the little assembly that connects the shift linkage to the selector fork shafts, and then jimmying the shafts around (there's three separate shafts you can move up and down). I also removed the engagement linkage for the reverse idler gear, which made it easier to jimmy the shafts around. I can't give an exact formula for what I did because it was kind of like a puzzle cube Just fiddle with it and you can worm the gear out from the selector fork, I promise you!That is all, and thanks for the support everybody!
#19 |
I may have missed it, but what about the 5th gear synchros?
#20 |
the synchro teeth on the 90-91 LS 5th are the exact same as the JDM S1/Y1/J1 trannies. if they weren't the same then this swap wouldn't work.
#21 |
awsome!
locals
#22 |
Cool:exclaim: My buddy has a USDM 90' S1 sitting around. I need to swap my y1 5th gear set with his. I like the fact that the shafts were not pulled for the swap. Makes it alot easier to reassemble.
Whip list: '08 S2000 '90 CRX '94 240SX Coupe. |
#23 | |
#24 |
Maybe just the 5th gear synchros are the same. I really want to do this to my car now... Raene owes me some help, now that I helped him wrestle with his tranny!
Ghetto Garage Racing 89 Civic Si. Cage, rear discs, integra brakes, mild n/a ls/vtec: 13.6@99 |
#25 |
Buddy, I 0wn your wiring harness... did I get paid for all the swap help you got?
![]() But I do appreciate your help and you know I'm willing to help out with your swap... BTW you still need to buy some work gloves, and soon...
| Bookmarks |
| Tags |
| 5th, engine, gear, honda, integra, j1, ls, mount, problem, rear, removal, s1, s2000, short, tranny, y1 |
