Old 04-08-2003, 07:52 PM   #1
2.0L EK
2.0L EK's Avatar
Send a message via AIM to 2.0L EK
Default How-To: Extended Shock Travel (56k... Better get some coffee)
K. Benen and I decided to do a 2-Part Shock and Ride Hieght Adjustment, for people without full coilover kits.
This is in regaurd to H-T Thread:
http://www.honda-tech.com/zerothread?id=469012#4884162
Tools needed:
-Measuring Tape
-Hammer
-Hack Saw
-14mm Wrench
-Alan Key Set
-Welder
So here goes.....
Step one:
Remove shock from car, measure huge gap that makes car bouncey.
Step 2:
Take apart shock perch and remove studs
Note: put nut on stud to protect threads
Step 3:
Cut bushing cut off perch.
Caution: edges are very sharp, so make sure to file down
Step 4:
Get a length of tubing and cut to desired length (1 Inch or 1 1/2 Inch, depending on space between hood and top of shock)
once again file edges!!!
Step 5:
Weld tubing to shock tower.
Note: Be sure to weld on the inside of the bushing tower cup
Let the top cool...
Step 6:
Reassemble perch w/bushings and put back on shock.
"Aerosol over haul"
Wow Lookie: same ride hieght with more shock travel!
www.rcrewracing.com
2.0L EK is offline Report Post   Reply With Quote
Old 04-08-2003, 07:56 PM   #2
Archidictus
Unceasing Measure
1998 Oldsmobile Intrigue
Archidictus's Avatar
Send a message via AIM to Archidictus
Default Re: How-To: Extended Shock Travel (2kTypeRHatch)
holy nice writeup batman! good job, fellas
But now the summer's dreams are bent like grain against the scythe, and memories of blissful days, they fall like leaves.
Archidictus is offline Report Post   Reply With Quote
Old 04-08-2003, 08:02 PM   #3
bzyrice
bzyrice's Avatar
Send a message via AIM to bzyrice
Default Re: How-To: Extended Shock Travel (Archidictus)
how's da ride? and any problems so far? good idea...
bzyrice is offline Report Post   Reply With Quote
Old 04-08-2003, 08:05 PM   #4
Big Teggie
Big Teggie's Avatar
Send a message via AIM to Big Teggie
Cool write up. I think I may be doing it soon.
Big Teggie is offline Report Post   Reply With Quote
Old 04-08-2003, 08:15 PM   #5
piscorpio
piscorpio's Avatar
Send a message via AIM to piscorpio
Nifty, makes me wish I actually had access to, and knew how to use a welder.
piscorpio is offline Report Post   Reply With Quote
Old 04-08-2003, 08:19 PM   #6
Evs-One
Gearing Owns Me
Evs-One's Avatar
Send a message via ICQ to Evs-One Send a message via AIM to Evs-One
Default Re: How-To: Extended Shock Travel (piscorpio)
wow..this is one the of better things I've seen.
Thanks for the write up....most would never of thought of the idea.
You should sell them for 15 bucks/pair..lol...make you some good money
And to person above...ride will be the same if not better...if you can see, the top of the shock has been moved 2 inches higher, allowing you to not "bottom out" your shocks or put excessive wear on them, and keep them in the mid region, where they perform best
Independent Honda and Acura.... (360)574-8880
95 Civic Si J32A2 91 Civic ITA/H4
MFactoryOEM Honda
Evs-One is offline Report Post   Reply With Quote
Old 04-08-2003, 08:26 PM   #7
Ekizzle
Ekizzle's Avatar
Default Re: How-To: Extended Shock Travel (Emerika)
Good Job to Ken and Alex ...
Ekizzle is offline Report Post   Reply With Quote
Old 04-08-2003, 08:27 PM   #8
2.0L EK
2.0L EK's Avatar
Part 2!
DIY Shortened Shocks (Front)
Step 1:
Measure the fork seat distance from bottom of spring seat. (All measurments made from same refrence point)
Step 2:
Wrap shock with ice pack so you do not over heat it. Then grind off weld from fork seat. Grind from fork seat side so to not grind a hole in the shock body. Becarefull to NOT over heat shock!!!!!!
Remove fork seat, and smooth out shock body
Step 3:
Slide fork seat to desired point. If the fork seat is moved too high, the shock bottom will hit axle. (We moved ours 1 inch) Just to be safe, measure distance between shock bottom and axle.
Step 4:
Get a piece of tubing that will slip fit over the shock body. Cutting the tubing at a 2 inchs length will secure the fork seat 1 inch higher than before.
Be sure to put a SMALL dent 1 inch from center to center of the dent.
Install "anti wabble tape" and slip tubing over shock body
Step 5:
Slide the fork seat back on and reassemble shortened shock
Step 6:
Now that your shock is 1 inch shorter, raise your spring 1 inch to compensate. Now your spring should have tension, but still be at the same hieght.
Good Luck!!!!
-2KtypeRHatch
-K. Benen
[Modified by 2kTypeRHatch, 7:32 PM 4/8/2003]
[Modified by 2kTypeRHatch, 7:40 PM 4/8/2003]
www.rcrewracing.com
Old 04-08-2003, 08:29 PM   #9
Inigo Montoya
Inigo Montoya's Avatar
Send a message via AIM to Inigo Montoya
Great idea, i think that tien is making a kit like this now, but i love the fact that you figured this out yourselves.
(making comment so it stays in my recent posts)
Inigo Montoya is offline Report Post   Reply With Quote
Old 04-08-2003, 08:33 PM   #10
youngkow
youngkow's Avatar
Send a message via AIM to youngkow
Great write up! But when you lower the front like that, wouldn't it hit the axel?
Forced to get out.........selling all of my goods.
youngkow is offline Report Post   Reply With Quote
Old 04-08-2003, 08:43 PM   #11
dphi
dphi's Avatar
Send a message via AIM to dphi
Have you installed them yet? I'd imagine the bolts at the top of the front struts would come pretty close to hitting the hood, but I guess it'd depend on the type of struts you're using.
dphi is offline Report Post   Reply With Quote
Old 04-08-2003, 08:44 PM   #12
2.0L EK
2.0L EK's Avatar
Default Re: How-To: Extended Shock Travel (youngkow)
Good question.
It will if you just eyeball it. Measuring tape is your friend!
www.rcrewracing.com
Old 04-08-2003, 08:47 PM   #13
g_man80
g_man80's Avatar
Good detailed instructions.
2 questions:
1.) Does the bump stop fit up into the relief that was made in the bushing tower cup allowing the shock to travel more? Or is the travel the same and just the top of the shaft is mounted higher?
2.) Why does the inside of the bushing tower cup have to be welded?
Thanks and again, good job,
G
2003 Honda CRF450R http://images.honda-tech.com/set1/smile/emthup.gif
2000 Honda CR250R (a few mods) <--SOLD
'01 Isuzu Rodea LS
'02 Subaru WRX sedan <--SOLD
'99 Isuzu Rodeo LS <--SOLD
'00 Audi A4 1.8T Quattro <--SOLD
'94 civic cx w/ '96 B18B <--SOLD
g_man80 is offline Report Post   Reply With Quote
Old 04-08-2003, 08:50 PM   #14
2.0L EK
2.0L EK's Avatar
Default Re: How-To: Extended Shock Travel (g_man80)
Ah yes 2 points I forgot to go over.
1) you should flip the bump stop over so the smaller end is up tweards the bushing cup.
2) If you weld on the out side of the bushing cup, the weld may not clear the body of the car, and create a wobble or annoying noise when you drive.
www.rcrewracing.com
Old 04-08-2003, 08:51 PM   #15
K. BENEN
K. BENEN's Avatar
Default Re: How-To: Extended Shock Travel (dphi)
Yes we have been doing this for about 4 years. Nick Theroex Won the SCCA ITA Championship 5 times with this DIY trick. Alex and I helped build the race cars some time ago! It works and well! If any one needs help and would like to do this.. Send us the Cores and some $$ like $20 for a pair and we will send some completed ones right back! they really work well
[Modified by K. BENEN, 4:52 AM 4/9/2003]
Enjoy what you drive or park it.
K. BENEN is offline Report Post   Reply With Quote
Old 04-08-2003, 08:55 PM   #16
PatrickGSR94
PnP Hater Moderator
1994 Acura Integra
PatrickGSR94's Avatar
Send a message via AIM to PatrickGSR94
The modified top mount looks like something Ground Control might sell as a billet piece. They already make a billet upper rear mount for BMW applications, I think they should make something like this for Hondas.
Also if you want to do the bottom modification to a Koni shock, you don't have to worry about cutting off the fork seat, since you're supposed to slide that part off of the stock shocks anyway, so it's a separate piece already for that application.
[Modified by PatrickGSR94, 10:56 PM 4/8/2003]
Please do not PM me with technical questions. Create a thread in the appropriate forum.
H-T OG member #8927 class of '02 ● Koni + GC InstallHID retrofit club
member #0001
PatrickGSR94 is offline Report Post   Reply With Quote
Old 04-08-2003, 08:56 PM   #17
g_man80
g_man80's Avatar
Ah, that makes sense. Thanks for the quick reply.
'01 Isuzu Rodea LS
Old 04-08-2003, 08:58 PM   #18
K. BENEN
K. BENEN's Avatar
to answer the second question a little clearer: The weld may not clear the tower hole and may bend the sheet metal when tightening the shock perch!
Old 04-08-2003, 08:59 PM   #19
FifthGearOnline
2002 BMW 3-Series
FifthGearOnline's Avatar
Send a message via AIM to FifthGearOnline
Default Re: How-To: Extended Shock Travel (K. BENEN)
thanks for the information man, and welcome to HT
- James
http://www.fifthgearonline.com
FifthGearOnline is offline Report Post   Reply With Quote
Old 04-08-2003, 09:01 PM   #20
TheJediMex
TheJediMex's Avatar
Send a message via AIM to TheJediMex
haha
but serious really nice write up and time ya took to help other people out
dam i love honda-tech
***Pics of my (Sold)Si***
"when life's not fast enough
...downshift"
TheJediMex is offline Report Post   Reply With Quote
Old 04-08-2003, 09:08 PM   #21
g_man80
g_man80's Avatar
Yeah, at first I was just thinking what's easier (weld on the outside). But I forgot that the shock perch fits quite flush with the inner fender leaving no room for welds. So the inside it will be.
'01 Isuzu Rodea LS
Old 04-08-2003, 09:21 PM   #22
Bumnah
Bumnah's Avatar
Send a message via AIM to Bumnah
Cool write up.
but i'll just purchase some ground controls pillow mounts
[b]BUY MY GSR MOTOR![b]
Bumnah is offline Report Post   Reply With Quote
Old 04-08-2003, 09:22 PM   #23
PatrickGSR94
PnP Hater Moderator
1994 Acura Integra
Default Re: How-To: Extended Shock Travel (Bumnah)
Cool write up.
They have those?
member #0001
Old 04-08-2003, 09:26 PM   #24
DOMKID
DOMKID's Avatar
nice article .
Ground Control sells something similiar to this.
"The hardships in life that we face do not create character, it reveals it!"
98 Civic EX
07 TSX
DOMKID is offline Report Post   Reply With Quote
Old 04-08-2003, 09:30 PM   #25
BigMig
BigMig's Avatar
Send a message via AIM to BigMig
ahhh! so this trick explains why your hatch is on the ground (this is your hatch, correct?)
BigMig is offline Report Post   Reply With Quote
Bookmarks
2003, 450r, adjustment, civic, crf, damage, extended, hole, hona, honda, illuma, instructions, pnp, rcrew, shock, shocks, signs, tokico, tower
