TPS adjustment???
Old 02-28-2003, 07:15 PM
Red_Si's Avatar
Default TPS adjustment???
ok, i just got a 1st generation jdm b16 throttle body for my y8 manifold. It comes with a working tps but how do i know if the tps is set? I really don't know anything about the tps but i hear it can be set wrong, how do i know i set it up right? can it be done with basic tools?
Old 03-02-2003, 12:51 AM
Red_Si's Avatar
Default Re: TPS adjustment??? (Red_Si)
BuMp PlEaSe BuMp
Old 03-02-2003, 02:08 AM
Xsi
Xsi's Avatar
You need a voltmeter, theres threee wires, one is 5v, one is a ground I think and one changes depending on throttle position. You need to measure the voltage on this and set it to something
I read that it was supposed to be 0.45 V but mine wouldn't go that high so I set it at 0.30 which was what the stock one was set at and it runs fine.
Hopefully someone will come on and tell you what to set it at, otherwise measure your stock one and set it at that.
Old 03-02-2003, 03:44 AM
Technical Hero
HondaPartsHero's Avatar
i've got my b16a TB on my Y8 manifold and set the TPS at 4.5V at wide open throttle, and .5V at idle. Test this by tapping in the red wire on the three wires and move the TPS back and forth to get these values with the car off and ignition on.
Old 03-02-2003, 05:01 AM
primoEF's Avatar
Default Re: TPS adjustment??? (yebabee)
you can see the readings on a SAFC/VAFC if you have one
Old 03-02-2003, 09:12 AM
Red_Si's Avatar
Default Re: TPS adjustment??? (EFDog)
ok thanks everyone
RinzEG6
11-22-2015 11:25 AM
o'malley_808
08-06-2009 10:24 AM
y-49
02-15-2009 07:08 PM
hOndafienD 04
08-26-2004 12:51 AM
CRX A4
06-14-2003 09:43 AM
Quick Reply: TPS adjustment???
