#1 | |||||
94 eg Cobalt Friction http://images.honda-tech.com/set1/smile/emthup.gif Tirerack http://images.honda-tech.com/set1/smile/emthup.gif GroundControl http://images.honda-tech.com/set1/smile/emthup.gif IPS Racing http://images.honda-tech.com/set1/smile/emthup.gif RandD http://images.honda-tech.com/set1/smile/emthup.gif JDMspec http://images.honda-tech.com/set1/smile/emthup.gif |
#2 |
simpson camlocks, 5pt, $353 with hardware from OG Racing.
Madison Motorsports CB750 | CB350 | SV650 04 Trek 8000 | 06 Trek Pilot 2.1 | 85 Trek 660 Racing is one of the finest mechanisms for the disposal of money - RR98ITR |
#3 |
i have the gforce.
My friend was in a HARD collision (100+mph) and he was fine. I fully trust them and I got them @ discovery motorsports ( link on my webpage) for $105!! Cant touch that!
<U>A4G Graphics</U> Contact me about Motorsports Graphics and Numbers! |
#4 |
Actually my Simpson 5-pt Latch/Link was $89 but I think they have gone up a little now... haven't checked in a while.
-Robert NASA Ex-Honda-Challenge Racer - #77 - H2 Need a Photographer? **Need a Website or Hosting? |
#5 |
I use the Sparco/Sabelt 3" ones. Seem to feel pretty good on my body. I paid $180 for the 5 point from www.sportscar-parts.com
If you are in the SF bay area and like racing, post up at: www.Imbecilicracing.com . |
#6 |
Try a search for "harness" in the archived section. Here's a fairly recent thread:
http://www.honda-tech.com/zerothread?id=340267 Personally, I use Sparco's. - being blue makes them special
#7 |
RCI 5-pt latch style...now i wish i woulda spent the extra dough for the camlock....but it'll do....
BTW i paid $60 for mine
2005 Ford Focus: I failed to keep it shiny side up. RIP Focus. What lies behind us and what lies before us are tiny matters compared to what lies within us.... -Ralph Waldo Emerson |
#8 | |
http://www.simpsonraceproducts.com/c...nts/latch.html select the type of mounting in the top right corner to get prices.
#9 | |
Thanks for the info, I chose the cam lock, but what is teh difference between the floor mount Y pull-up, and the floor mount individual harness bolt in? 189 really isnt that bad of a price, either. Mike
#10 |
Wrong-Way Wang
Sabelt from Racer Wholesale. Sparco harnesses/hardware is just Sabelt rebadged.
Warren |
#11 | |
If you are using eye-bolts in the floor, then the "floor mount" is nice because they have clips that snap right to the eye-bolts... works well for multiple cars. The "bolt-in" just has a big washer on the end of the straps.. like the sub-belt... for bolting directly to the floor. I bought the "Floor-mount"... used eye-bolts for the Lap belts... bolted the sub-strap directly to the floor(or if the end isn't sewn in, you could buy another clip and use it with an eye-bolt also) ... and then took the washer off the end of the shoulder harness and wrapped it around the cage instead of bolting to the floor(why I recommend the longer belts..62"). Let me know if you have any more questions. I know how confusing the belt-buying process can be.
#12 |
I got the Deist harness from Stable Energies. I bought my harness bar from them, and figured I'd get the harness at the same time. It is more expensive than the sabelt/g-force harnesses at $270, but the shoulder pads are stiched in, which is nice to have so they don't slide around on you. They include the mounting hardware, and it doesn't require you to drill any holes. I replaced the standard bolts on both the female seatbelt end and the bottom of the factory seatbelt mounting point with eye-bolts, which the harness then clips to. for the sub belts, i attached pieces to the front seat mounting points that the belts loop through.
'07 S2000 #27 Chicago Region SCCA, TSSCC |
#13 |
looks very nice - i would recommend a roll bar if these were to be used on the track for an HPDE.
RJ
#14 | |
Thank you for clearing that up, i appreciate it. Is there really any benefit to bolting directly to the floor or using eye bolts(aside from if you have to remove the harness for use in another vehicle)? Yes these will be used with a roll bar. Thanks again! Mike
#15 |
I have had good luck and like my Simpson Cam lock. The simpson also appears to have thicker webbing than some that I have seen. I believe Pegasus Racing stocks these.
| Bookmarks |
| Tags |
| bolt, cam, challenge, deist, difference, eye, harness, honda, integra, latch, lies, lock, mounting, nasa, racing, sabelt, size, type |
