Old 03-31-2015, 04:33 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Specifications and General Overview
Print Wikipost
Fuel pump killswitch
Old 05-03-2011, 07:06 AM
fusion645's Avatar
Icon2 Fuel pump killswitch
I have a 2000 civic si. (Em1) I want to install a kill switch to the fuel pump. I know the power wire to the fuel pump in yellow and green, well with my car i have two yellow and green wires exactly the same. Which on to i cut and run to a switch?
Old 05-03-2011, 08:57 AM
fusion645's Avatar
Default Re: Fuel pump killswitch
The first pic shows two wires that are yellow and green. The wire with the black electrical tape goes to the fuel pump and the other yellow and green wire goes to the gray plug.
Old 05-03-2011, 11:05 AM
djkurious's Avatar
You will need to get a DMM (digital multimeter). You will need to use the ground wires. Also look into using the Main relay as a kill instead of the fuel pump. Like Desmond states "A thief could tag 12 volts to the pump and your kill is killed"
Old 05-03-2011, 12:29 PM
fusion645's Avatar
Do you know where i can get a nice write up with possible pics for the kill switch off the main relay?
Old 05-03-2011, 02:44 PM
wtf_is_jdm's Avatar
http://www.team-integra.net/forum/17...ct-da-teg.html
Old 05-04-2011, 04:06 PM
djkurious's Avatar
I'm not sure of the location of the main relay in a 2000 civic, but this should give you a idea from the post above: http://www.team-integra.net/forum/17...ml#post2416875
Cut the black wire and extend it to both sides of a switch. I used this switch from WalMart:
Old 05-09-2011, 03:19 PM
nsxxtreme's Avatar
Sorry but disabling the fuel pump by the main relay doesn't prevent a theif from running 12V straight to the pump. That would still turn the pump on.
The main relay kills the fuel pump and fuel injectors. Twist 3 wires together and they are back to working. The main relay is a good start but I would find some additional spots to kill.
Preferably harder to get to then right under the dash or back seat. Layer your kills and hide them well.
Another tip I use is keep you alarm wires short. Replace all the wiring with a solid color. I use black. It's much harder to figure out what wire does what when all wires look the same.
Old 05-09-2011, 04:48 PM
AChickInACivic's Avatar
thanks! ive been wanting to put one in my car
ek951
13
05-01-2012 01:37 PM
00trdtaco
08-20-2009 06:42 AM
almostboostedgsr
04-08-2009 10:29 PM
Eresuncabron
11-27-2003 08:09 AM
dustin
03-01-2002 07:33 PM
Quick Reply: Fuel pump killswitch
