1993 Honda Del Sol "S" Swappable Underdash Wire Harness?
Hello I have a 1993 Honda Del sol "s" with a 1997 Gs-r swapped in. I know I may not be on the right forums but My questions are, as far as i believe, vehice specific. My questions are:
Can I use an OBD1 Gs-R integra underdash wire harness in place of the OBD1 Honda del sol underdash wire harness? I was told all the OBD1 wire harness' for all Honda and Acura were a two piece design...
Does anybody have a link to where I can find an OBD1 Honda Del sol or OB1 Acura Integra Gs-R Underdash wireharness? (I've looked on craiglist and ebay with no results)
Could anybody give me a list of names the underdash wire harness carries? I know Underdash Wire harness and I've Heard AC/PS Power Underdash wire harness...
Thank you to all of you who can give me some good advice.
Re: 1993 Honda Del Sol "S" Swappable Underdash Wire Harness?
the engine harness connects to the shock tower harness. the under dash harness is one piece which everything under the dash to the front of the car ie headlights, corner lights, fuse box, windshield motor etc...
look on ebay or craigslist.
Seagull Management
It's much easier to just run the wires for vtec, knock and IABs from the shock tower plug back to the ECU, GS-R harness *may* also differ in such places as where the door harnesses connect, headlight and a few other other things.
http://www.ff-squad.com/technet/hybrid.92-95.obd2.htm
Seagull Management
Normally you just keep whatever underdash harness the car came with, it's very labor intensive to change an underdash harness, it requires pulling the dash, heater core, A/C evaportator core if you have A/C (which also requires refilling the system when you're done) pedals, battery tray, steering column and a few other things.
None of the above is a problem, so I'm to assume the link is referring to the Honda del sol Underdash? Would I be able to use an OBD1 Gsr Underdash instead?
So the set up in the end I would have is a OBD2A engine wire harness connected at the shock tower to a OBD1 94-95 Honda del sol Underdash wire harness? What would I have to rewire using the 94-96 Underdash harness? (Regarding sensors and what not)
O.G. triple O.G.
Why in the first place would you need to mess with the dash wire harness...?? Makes no sense to do so just for a swap.
Seagull Management
Using a Del Sol VTEC underdash harness you'd have to add the wires for the IABs (assuming you're keeping the stock GS-R manifold and using an ECU that supports it. If using a Del Sol Si harness you'll need to do that along with wire the knock sensor. If using a Del Sol S harness you'll need to wire the above along with vtec.
From my AIT there are two wires a BLU/BLK and a converted to a green and a BLU/YLLW converted to a blue. The green wire goes into D17 (INTAKE AIR BYPASS CNTRL. SOL. VALUE) and the blue wire is just hanging there soldered to a thin exposed wire spliced to A26 (LG-1 Logic Ground)
whyS0serious
05-25-2013 08:13 PM
Acidcrakker
07-13-2010 06:28 AM
