1993 v-tec del sol was runing then shut off and turns over but start please help!!
Re: 1993 v-tec del sol was runing then shut off and turns over but start please help!
a compression test will tell you alot about your problem try that then check for fuel and spark
Don't waste time with a compression test. Check you're fuel filter/fuel pressure. Unbolt the top bolt on the fuel filter, turn the key to the ON position and check that the fuel pump is supplying fuel to the motor. If it doesn't come out at all your fuel pump is dead, if it oozes out your fuel filter is dead, if it comes out like a fountain then both filter and pump are fine.
Pull the plugs out and check for a spark while cranking the motor. If you have a spark on all cylinders that will prove its not the T-belt
You can also check if it was the timing belt, have someone crank the motor and look down the oil fill hole in the valve cover. If you see the rocker arms moving it's not your T-belt.
Check your basics... Do you have Spark? Fuel? Fire?
http://www.askmehelpdesk.com/cars-tr...post-9924.html
just google search. Was trying to find the link I used...I though it was in the FAQs section but it wasnt. Gives a list in order of things to check. This topic has been covered 1000 times so search.
Also you gave no information on what happened, mileage, compression, nothing. just a help.....
