d16z6 valve seal.
d16z6 valve seal.
i think my d16z6 motor is burning oil when vtec kicks and form high rev's.. so i'm guessing my valve seals are bad. oil is not leaking anywhere else so i'm guessing it's the valve seals.. i've never touched a head before so does anyone know where the valve seals are located and are they easy to replace?
Re: d16z6 valve seal.
usually if its valve seals it usually smokes when u just start the car and the engine is cold and slightly goes away when its warm. i would imagine its rings
thatgreenhatch
11-05-2014 08:36 AM
BoostdRex
12-21-2005 05:11 PM
change, compression, d16z6, installation, installations, leak, leakdown, leaking, perporm, replace, seal, seals, test, valve, vlave
