98 civic, no spark, replaced ICM 2X, dizzy, plugs...
Old 09-10-2010, 04:51 PM
sleepyEK's Avatar
Default 98 civic, no spark, replaced ICM 2X, dizzy, plugs...
no cel, starter cranks, fuses good, all instrument panel lights work correctly, wires from ecm to icm test good, still NO SPARK. I'm at a complete loss here. ANY help would be much appreciated. Thanks.
sleepyEK is offline
Old 09-10-2010, 05:24 PM
sleepyEK's Avatar
Default Re: 98 civic, no spark, replaced ICM 2X, dizzy, plugs...
i searched, but coming up empty handed concerning this.
sleepyEK is offline
Old 09-10-2010, 06:57 PM
92lxsleeper's Avatar
check all your grounds. valve cover, tranny, and the 2 at the thermostat housing. check the ecu fuse
92lxsleeper is offline
Old 09-10-2010, 07:07 PM
sleepyEK's Avatar
thanks for the reply. i did check fuses under hood and dash and all are good. grounds are good at thermostat housing, tranny, and valve cover. >.<
sleepyEK is offline
Old 09-10-2010, 07:12 PM
the only thing i can think of is the ecu then, unless the coil inside the dizzy is bad. that happened to me. ran, turned it off and tried to start and it wouldn't. i replaced the dizzy still didn't work. then for some reason i replaced just the coil and it started right up. god knows why.
Old 09-10-2010, 07:26 PM
sleepyEK's Avatar
yeah i've had strange things happen to me as well over the years, but i've tried two different coils already as well. this is truly driving me nuts. i don't want her to have to spend much more money. i have not replaced distributor cap, as i've never in my experience seen a bad cap and rotor not deliver any spark at all, just weak.
sleepyEK is offline
Old 09-10-2010, 07:30 PM
Former User's Avatar
Is 15A dash fuse 9 blown?
Does the Blk/Yel wire inside the distributor get battery voltage?
Does the fuel pump prime?
Is the timing belt broken?
Former User is offline
Old 09-10-2010, 07:36 PM
sleepyEK's Avatar
rotor turns so needless to say, cam is turning. blk/yel wire has battery voltage, fuse 9 is good, fuel pump is indeed priming, in fact had to disable fuel delivery while trying to get spark to avoid flooding. thanks for the reply.
sleepyEK is offline
Old 09-10-2010, 07:39 PM
Did you check the Yel/Grn wire for a short? With the key in ON(II), does the Yel/Grn wire attached to the ICM have voltage? Does the Wht/Blu wire have battery voltage? Has the ICM been tested?
Old 09-10-2010, 07:51 PM
sleepyEK's Avatar
checked for continuity between ecm connector and yel/grn wire at dizzy plug, and there was continuity, and no continuity to ground, although haven't checked it for voltage. battery voltage on wht/blu wire. all icm's i've tried have been tested good. thanks for making sure i've covered all my bases.
sleepyEK is offline
Old 09-10-2010, 07:59 PM
Do the three distributor sensors have resistance in the normal range?
If the Yel/Grn wire has voltage, as I presume it will, then it's time to swap in a known good ECU, as already mentioned.
Old 09-10-2010, 08:02 PM
sleepyEK's Avatar
ok. i'll check that, and i'll also try to find a known good ecu. can i use one from a manual car even though it's auto?
sleepyEK is offline
Old 09-10-2010, 08:03 PM
yes
Old 09-10-2010, 08:06 PM
sleepyEK's Avatar
will do. thanks for the help. will update with results.
sleepyEK is offline
Old 07-23-2011, 06:49 PM
jake00si's Avatar
hey you ever figure out your issue?! Im having the exact same problem
jake00si is offline
Old 07-23-2011, 08:29 PM
xxvinxx43's Avatar
i had the same problem, mine was a relay. check them all
xxvinxx43 is offline
Old 07-23-2011, 10:24 PM
Texas4door's Avatar
Could also be that a component of the distributor itself is toast...if all else fails, replace the whole distributor and ecu (though that could get expensive >.< )
Texas4door is offline
Old 07-24-2011, 06:17 AM
This is an old thread. Create your own thread and provide details about your car and what you have done so far.
BarebonesB18
02-25-2018 09:28 PM
AznBlueBoy
09-08-2006 08:21 PM
KiNG $h!t
19
08-26-2004 11:14 AM
racerboyb18c1
11-18-2003 07:46 PM
Quick Reply: 98 civic, no spark, replaced ICM 2X, dizzy, plugs...
