93 civic b16 wont start. Fuel Pump, Fuel Pump Relay.
Old 08-05-2010, 01:55 PM
ThatRHDstatus's Avatar
Default 93 civic b16 wont start. Fuel Pump, Fuel Pump Relay.
I started having this problem a couple days ago. Sometimes it starts sometimes it wont. I noticed when it does not start i notice i dont hear the fuel pump prime or the the relay click. My question is there a way i can check which one it is. The CEL is a weird situation too. Sometimes when it does not start the cel goes off like normally (still no prime or click from fuel relay and pump) sometimes it stays on still no prime or click from relay or pump. I tried the paper clip trick when the cel stays on and i cant get it to work. i used to do the paper clip all the time no problem. dont know why it isnt working now. help please thanks
Old 08-05-2010, 02:04 PM
Former User's Avatar
Default Re: 93 civic b16 wont start. Fuel Pump, Fuel Pump Relay.
Most likely a faulty main relay. Read this related thread:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/1993-honda-civic-ex-1-5-l-electrical-fuel-pump-issue-2815857/
You can verify that the fuel pump is fine by jumping the main relay or wiring it to the battery.
Old 08-06-2010, 09:50 AM
ok ill try in out thanks, ron your the man you always seem to help me out all the time
Old 08-08-2010, 06:58 AM
Sorry. But how would I jump the relay. Never done it before. I have an idea but not sure. Also is ok if i drive it like that for a little bit.
Old 08-08-2010, 08:05 AM
Jump the main relay connector as described in the diagram. If the fuel pump runs continuously when the key is turned to ON(II), then the fuel pump is fine. You cannot drive the car like this. It's just a way to test the fuel pump.
civic08
03-14-2010 09:26 AM
uszcrx
24
09-09-2006 01:05 PM
Chuckyb
12-11-2004 05:45 AM
iwhichisme
09-08-2004 04:13 AM
fastaccord94lx
09-05-2003 08:50 PM
Quick Reply: 93 civic b16 wont start. Fuel Pump, Fuel Pump Relay.
