Help: H22 swap in EK vibration at acceleration
Old 05-10-2010, 10:01 PM
bluEK's Avatar
Default Help: H22 swap in EK vibration at acceleration
I have had this swap for a year now and i finally got an LSD tranny for it (M2B4) but since i took off the tranny i decided to go get the clutch resurfaced etc... So when i was putting the driver side axle and one of the bearings fell so i bought new axles off kragen 89 integra for pass. side and a 90 integra for driver side. Car doesnt vibrate much when its idling its when i start driving it pass 15mph...........i've put it on the lifters and put it on gear and doesnt make any noise...... Thanks for help in advance
Old 05-10-2010, 10:59 PM
rellikgtx's Avatar
Default Re: Help: H22 swap in EK vibration at acceleration
Is there very little vibration? How does the steering wheel feel?
Old 05-11-2010, 06:46 AM
I'm really 2slow
2fast4u831's Avatar
everything is tightened up? lug nuts, bolts, axle etc..
Old 05-11-2010, 09:57 AM
bluEK's Avatar
nah its not a lil vibration like as soon as i start gaining speed the whole car vibrates
and yes i made sure everything was tight cus i have at least taken off the axles like 5 times to check that the axles are still fine and then bolt everything back up
Old 05-12-2010, 10:27 AM
Big Cat
fatboy1185's Avatar
Halfshaft?
Old 05-12-2010, 01:15 PM
bluEK's Avatar
i checked tha halfshaft and it has no play, cus i put the car up in the air and it doesnt vibrate at all
Old 05-13-2010, 03:06 PM
bluEK's Avatar
i lifted the suspension all the way and the car is running fine now so figure its my ride height lol........ since i was rokin 195/55-15 and bought some other rims that had 195/50-15, my best bet is that ihave to rock 16's
Old 05-12-2019, 09:33 PM
Onsite Ortiz's Avatar
I Have the same problem hopefully i can solve this the same way due to ride height.👍
Old 05-14-2019, 05:24 AM
AllMtrRex's Avatar
It's bad axle alignment. It comes from bad CV joint or if you are lowered, obviously this will cause axle alignment to be off.
Rise VTEC
Transmission & Drivetrain
12-22-2014 09:38 PM
Rheg6
05-31-2011 02:14 PM
EKJACE
05-22-2011 09:56 AM
SPEEDQUEST INC.
12-06-2004 08:24 PM
matix
02-01-2004 07:15 AM
Quick Reply: Help: H22 swap in EK vibration at acceleration
