Engine or Tranny ?
Engine or Tranny ?
Hi Everyone
ok Here's My Problem
About 6 Months a go i Bought a 91 Accord EX Coupe With a 95 V TEC Engine
Everything Works Fine Except 4 The Tranny i Guess.
When Im On a Red Light with the pedal all the way to the floor if i let go on the pedal 4 about an inch my Engine started to shake till i give it more gas
When I start First Gear The Whole Car Rattle Vibrate Bumper, engine, tranny, dashboard
I Already Change Tranny Have New Clutch ,New Flywheel ,New Clutch Master Cylinder, New Sleeve Cylinder,New Axel s New crankshaft pulley, They Said It Was Out Of Balance I Stalled a New one also 2 New motor Mounts i Took the Car to The Shop But They Keep Saying its the Clutch I'm Pretty Sure Its Not Any Suggestions Will Be Appreciated Thank u
Re: Engine or Tranny ?
Thx I was Talking two a friend of mine and told me that i need to change the flywheel and crankshaft pulley From a 95 V TEC Since Those two that r from The Original Engine 91 what do u think ?? Thx Again
1 Post
definitely sounds like the balance shafts are out of sequence, best you get your search on for getting them aligned. If you don't know what they are or aren't very confident with your ability to adjust / check them, I would advise taking it to a mechanic for them to check it for you. Also could you tell us what the engine code / model is??
hell.... since Im such a nice guy I will even post something TouringAccord wrote up for the changing of a cam belt and balance shaft belts on a F22B1 (guessing thats the engine in your car??)
https://honda-tech.com/forums/honda-accord-1990-2002-2/how-replace-timing-belt-timing-balancer-belt-water-pump-f22b1-1908944/
Take your car to another mechanic, as anyone with the slightest bit of Honda knowledge would know to check the balance shafts.... as stated below the clutch wouldn't have the symptoms youre describing.
hondaracin24
03-31-2007 12:09 AM
