#1376
Alright. But just some fyi... If you send me a pm during august-october, you wont get a reply. I'll be in texas for air force basic training. But keep up the good work on a great chassis that is totally under used.
#1377
1 Post
So after my cousin (SHG Beans) had 2 incedents with his dunlops (1 flat and another almost flat) I decided to put a spare back in the car.
We had this spare from our S2000 race car at the shop so I scooped that up and installed it with the OEM EP3 jack and took kit...
Mint mint mint!
Mint mint mint!
#1379
1 Post
No definitely not. The s2000 spare is just the right size and the trunk board lays perfectly flat over it. With a full size spare i wouldnt be able to run the OEM trunk board and it would suck lol. Gotta keep that trunk fully functional and OEM
#1384
Honda-Tech Order of Merit
that color green looks like the green used on whatever company that was from best motoring
http://www.youtube.com/watch?v=jDmfu07nvGw
#1387
1 Post
Banners are finally sorted and mine is the first one to be done! Mikes and Laurens will hopefully be complete later this week
Im LOVING this look
Here is the original (top) graphic vs the revised (bottom)... we decided the first was too small and opted to enlarge it. Glad we did!
Also got the washers in today for my M6 stainless hardware
Popped it in a few key spots
And last but not least... did some intake testing today but more on that later... for now heres a quick sound clip
Im LOVING this look
#1390
1 Post
Been a busy couple days putting in work on the car after the 9-5 job!
Spring perches got here the other day and I FINALLY got to install the rear FEEL's/Aragosta shocks. Theyre basically totally custom now, the only thing left from the originals are the pistons, lower mounts, and top hats. New bodies and valve stacks were made because the original parts are out dated and no longer in production for replacements.
Custom SHG Delrin lower bushings
Assembled with 1000lb springs
Then I threw it on the scales for a corner weight and alignment. I set the cross at 49.5% with driver weight (170lbs) to give the car a little tendency to oversteer in right turns over left turns since the tracks I will be running run counter clockwise. I was also able to get a 60/40 split while keeping the ride height were I wanted it from an appearance standpoint.
#1391
That alignment is boss! Its so cool that you can get such an solid weight distribution and the ride height still looks nice and even.
#1393
1 Post
So when you cross weigh the car the ride heights are obv different to adjust the weight on each wheel, so that will push and pull on the ends of the swaybar, making it act like a spring and throwing the reading off. Thats why race cars use adjustable endlinks so that the swaybar is never preloaded at static ride height.
Well, even though mine arent adjustable in the rear the swaybar isnt preloaded.... just worked out really well
#1396
Yeah dude I was so happy when it started coming together and I realized my ride heights for all 4 corners were within 1/8 inch! Also, something I was really surprised at was that theres no bind in the swaybars.
Thats crazy man, 1/8'' is nothing. I never thought about the swaybars being preloaded if the car is corner weighed or just has an uneven height but it makes a lot of sense. Very neat stub of info
I'm thinking of swapping around my coils what do you think?
They are 10K front and 6K rear so that they then become 6k front and 10k rear. That would somewhat compensate for my lack of a sway bar by having a tendency to oversteer IMO.
#1397
Very nice!! Whole suspension setup is too legit
Not sure on the banner on the car on its own, but I think it'll look great with all the cars lined up next to each other
Dont do this on an EG setup, just get an rsb and appropriate reinforcement if required
#1398
just gets better and better. for your brake dust, take a look at armor all wheel protectant. i run hawks and i use this and i can go a month without cleaning my wheels and they are barely dust covered. its great stuff for the moeny.
#1399
Damn just beautiful. I have been through all of the SHG threads and you guys are awesome. keep up the good work.
kris
kris
#1400
1 Post
Thanks dude, you know SHG does work
