Old 06-12-2011, 06:38 PM
  #1301
<StevieG>'s Avatar
Default Re: SHG is back! Easy's EP3 goes under the knife...
butter!
Old 06-13-2011, 11:35 AM
  #1302
SHG_James's Avatar
Curious to know as why you didn't reattach the halfshaft heatshield.
Old 06-13-2011, 02:06 PM
  #1303
AllMotorDan's Avatar
sound clips of the exhaust or its too loud :-p
Old 06-13-2011, 03:44 PM
  #1304
SHG_EasyE's Avatar
Idk its a thing of mine, Excess stuff just bothers me. I also dont really see much need for it.
Haha sound clips tomorrow night hopefully. I still have to extend my secondary 02 for the RSX cat.
Old 06-13-2011, 04:43 PM
  #1305
^Sammy]!.'s Avatar
Location: 9/11/01 WTC Never Forget, United States Of America
Dam E the BC looks super dope on there homie
Old 06-14-2011, 01:19 AM
  #1306
SHG_Claudio's Avatar
Old 06-16-2011, 07:33 PM
  #1307
SHG_EasyE's Avatar
Ok so Im sure alot of you know Skunk 2's reputation for control arm bushings tearing out in no time. Im not sure if this will fix the issue 100%, or if other chassis have the same issue but here is what I found....
So when the control arm is placed in the frame there is about a 1/8" gap between the bushing and frame. So when you try to torque the bolt down in will pinch and bend the frame before tightening against the arm.
Then, once it is tight, the frame will be squeezing the bushing itself (which is supposed to stay stationary in the arm) instead of the dowel in the middle. This will cause all kinds of binding and tearing forces on the bushing.
The dowels used are too narrow as you can see here:
Solution: A wider dowel that will allow the bolt to be properly torqued aswell as give the bushing some extra room to rotate and twist freely. I used the center dowels from the OEM bushings and had them turned down to the same OD as the skunk 2 dowels. The indents will allow extra room for the bushing to twist under compression.
Also, I started working on my battery holder. I got the tray, frame rail mount, and tie down fabbed up. Now I need to do some welding! I think Im going to use this tie down instead of the Skunk 2 piece because it will go better with the rest of the holder. What do you guys think?
Old 06-16-2011, 09:52 PM
  #1308
SlightlyLifted's Avatar
Great build man! I hope my 02 EP can look as clean as yours. Hey question. Where can i find a set of the DC5R lower controls arms? I've been looking everywhere.
Old 06-16-2011, 09:54 PM
  #1309
Oh and battery tray looks sick. Loving the custom fab work your doing!
Old 06-16-2011, 10:56 PM
  #1310
faster Type R's Avatar
Progress looks good
Old 06-17-2011, 04:01 AM
  #1311
SonicRacing1's Avatar
It took me 2nights to read threw 53pages of these thread made for a great read each night love ur attention to detail. Since im just as meticulous as you everything has to be perfect.
Im more into drag racing an thats where i spend most of my time when im on HT but i'll be following ur thread. Keep up the great work.
Old 06-17-2011, 04:02 AM
  #1312
SHG_EasyE's Avatar
Thanks man! You can usually find a set used on clubrsx at any point in time. The usually run $200-$300.
Old 06-17-2011, 06:09 AM
  #1313
^Sammy]!.'s Avatar
Dam E you never fail to amaze buddy.....looking great
Old 06-17-2011, 03:48 PM
  #1314
Do the lca's have to be type r or just 05-06 rsx type s? I need a better setup because i'm going the 5 lug route.
Old 06-17-2011, 05:00 PM
  #1315
SHG_EasyE's Avatar
Well the ITR arms are the aluminum ones. All year Type S arms are steel. ITR arms are also 15mm wider on each side. The balljoint hole in them is also larger so you either need to run King Motorsports ball joint adapters or 05-06 Type S balljoints.
Old 06-17-2011, 06:37 PM
  #1316
hondaman122's Avatar
Ep3 is looking good. gluck with the r&d an build
Old 06-18-2011, 08:53 AM
  #1317
SHG_EasyE's Avatar
FFUUUUUUUUUUUUUUU
http://www.youtube.com/watch?v=YA0AQChP2EQ
Old 06-18-2011, 09:09 AM
  #1318
That's stupid nice. Nice and deep and doesn't seem crazy loud either.
Old 06-18-2011, 12:33 PM
  #1319
SHG_EasyE's Avatar
Thanks Clauds! Yeah its like - the perfect sound. It makes me think Im going to abandon plans of the Buddy Club header for the new motor and run a JDM ITR with cat
Old 06-18-2011, 06:23 PM
  #1320
SHG_Mike's Avatar
Im sure jason still has his.
Old 06-18-2011, 06:28 PM
  #1321
SHG_EasyE's Avatar
Yeah but I want the whole oem setup with cat
Old 06-18-2011, 07:17 PM
  #1322
^Sammy]!.'s Avatar
That BC is music to the ears buddy!!
Old 06-19-2011, 03:52 AM
  #1323
Sounds throaty i like
Old 06-23-2011, 09:57 AM
  #1324
<StevieG>'s Avatar
hey bud... Heard you may not make the show cause of not having your rear shocks... If I come up, Ill let you borrow my br racing rear coilovers from my coupe... They should bolt right up!
Old 06-23-2011, 04:38 PM
  #1325
nightfiref7efi's Avatar
Nice looking car
Quick Reply: SHG is back! Easy's EP3 goes under the knife...
