#1276
Helper springs are to keep the spring against the top hat at full suspension droop, say when you jack the car off the ground, or lift an inside rear wheel at the track or autocross. If you have a setup like say buddy club, there are separate height and preload adjustments. That means you dont have to use the spring perch to raise or lower the car.
#1277
#1278
#1279
The pro spec is similar to the spec3 but the pro spec has flanged joints instead of slip fit. I also had a spec3 on my eg back in 2006 lol
#1280
1 Post
independent height adjustment is def good for off the shelf setups but most if not all racing cars just use spring height. This is because the shock body and piston are made to spec for the cars ride height, and not having the extra parts for independent ride height saves weight. My shocks luckily are this way. I'm about 1/4 inch lower than the coilovers MAX ride height.
yup spec 3 again. They changed the finish on the muffler since I had the one on my eg, kinda dissapointed when I unwrapped it.
#1281
#1283
1 Post
I got a few things done at work today... Filled the rear mount with 3M Urethane and refreshed the Cat heatshield which is the only one going back on the car.
Heatshield nice and fresh waiting to go back on with new harware...
New OEM donut gasket:
Also got a few more collectibles recently... Steve (aka Kseries) was kind enough to hook me up with the EP3 press release and brochure. So sick
And the FD2R catalogue, brand new
Heres a portion of the rest of my collection... I need another display case!
#1286
Evan, I'm gonna look around for a Feel's catalog I might still have floating around. Looks like there's room enough to trump an empty Spoon box for space!
#1287
Location: 9/11/01 WTC Never Forget, United States Of America
Nice display Evan.....hey did you ever finish that EG model I sold you?
#1288
1 Post
Thanks bud, I still havent finished it lol. Its all done except for the body. I have to get an airbrush at some point so i can spray it and finish it up! I ended up doing it yellow and got some SW's for it to be a Spoon car
#1290
Ah nice very nice.....hey pm me your number next time Im heading up to Boston, I'll give you a shout
#1291
Awesome Rim setup First track day and the combo was perfect. Even stock and no issues, just tons of body roll :D
Currently bought DC5R midpipe (Looking for JDM DC5R header to match)
www.youtube.com/MissShift
Deciding to make videos of upgrades to Ep3 and car related material. #1 Shout out to Easy Ep3 for making my choices easier to make
Support would be awesome Thx guys.
#1292
1 Post
Nice man, where do you live? Seems that over in the UK drivers dont need to wear helmets on the track... Crazy!
Glad I can help you out with your choices too. I kind of wish I had been able to track my car with stock suspension to see what each upgrade did to the balance of the car. It will be interesting to see what the new bushings, spring rates, and damper valving do for the car
#1293
http://www.youtube.com/watch?v=vreUlIu3-x4
(The dude had a helmet and was ok). After seeing this happen literally infront of me, Im looking to purchase a helmet before I hit the track again
Technically speaking, Cayuga Toronto Motorsports track is a small, low speed track (no elevation to terrain or anything - sort of like a big gokart track for cars), at which only time attack cars had to wear helmets. Open lapping it was recommended but not enforced. (I think it changed now though)
PS. Yea thats me behind the subby
#1294
nice wheel skills buddy! You were super close to that bail of hay.... That subby was on it WAY to early it seems.. Looked kinda like a stunt. Kinda funny, I just watched the youtube of that teg screamin around the track...
Hey Evan! Thanks for the present in the mail. It seems that removing the center console is a bitch, when someone replaces the factory screws with ones thats are way too big! Stripped them in there good. What else was nice, was the wiring harness from the coupe is the exact same. Figured they were. Atleast I got on good thing. I got a BC type B ****.. But I saw some circuit hero stuff I may jump on.
#1295
i got new hardrace hardrubber bushings for my ep on a-spec rsx suspension
NIGHT AND DAY! SO MUCH LESS BODY ROLL.
...then again my old bushings were worn badly
i can only imagine how yours will be...
i just put on my volvo lip finally...and i'm wondering how you go anywhere with it
im on ~1inch drop and i scrape all over because it hangs so low.
#1296
1 Post
I live in Toronto. Just next door Helmets "were" optional until this happened a few days ago
o man...new bushings can do ALOT
My lip eats **** pretty bad sometimes, but for the most part it doesnt scrape very often. When it does though it just folds under and pops back out like nothing ever happened. Its the perfect lip
#1297
1 Post
Hey guys new update! Ive been spending a bunch of time on the car after work and got some good stuff done...
First I got the shifter cable and ebrake cable brackets back from powdercoating...
New vs. old hardware for the rear engine mount:
Exhaust hardware, with Buddy Clubs new 3 piece springs (old style was one piece)
Mid section ready to be installed
Preparation for the exhaust included some heat barrier tape in key spots where heatshields were removed
And the exhaust is finally installed! It sits so well at a slight upwards and outwards angle for an agressive look
You can see I also used some gold heat tape around the bumper to protect from heat, and idea used by many Rolex teams.
Slip joints are so sick
Also got the Buddy Club battery in
#1298
Super nice update! The Buddy Club goodies are so frigging nice I love how simple they all are and just nice looking period.
Interested to see how loud that will be. The FOM S2K sounds phenomenal and I bet that will too! Oh man at 4k it was just music to my ears, I cant even imagine it hauling *** banging gears at 9,000 revolutions!
Keep it up!
PS: You didn't go to Montreal? I thought you were gonna! I'll be watching the race in a little bit but from practice and quali, it looks very promising!
Keep it up!
#1300
1 Post
Keep it up!
Keep it up!
We werent able to go up some stuff came up unfortunately. We will be at Austin for the 2012 season for sure though!
Thanks man!
