#876
for what kind of numbers though?(vs BC) And Its not $225 more, its $400 more, You cant compare a mild steel header to BC's SS. You would have to coat the Mild one bringing it closer in price to the SS header anyway.
#878
1 Post
Buddy Club race header goes for $750.
SSR goes for $225 more. IMO, I would save a bit of next paycheck to get the SSR.
http://www.sixsigmaracing.com/K-SeriesRSX.htm
That being said the fairest comparison would be a used Buddy Club and a used stainless SSR, which is about $450 Vs $850-$950. A few ft lbs of torque just isnt worth it to me.
#879
1 Post
Haha not so near, probably mid next year. Im focusing on getting the suspension really dialed this year and investing in some track time, then Ill start working on the motor towards the end of the year.
#880
Yeah, Like Mike said you cant really compare the mild steel SSR to the stainless Buddy Club product, at least in my opinion - since I would never put any mild steel exhaust part on my car, ever. No matter what it's coated with it will eventually rust through, and everytime the car sits after driving condensation will collect in the low spot inside the header and rot it from the inside out. Using mild steel is a shortcut that shouldnt be taken honestly.
you ever read the threads on CRSX about headers? they test slot of them and im pretty sure the kidd racing made the best power. and i believe its stainless. i think they also make their own header. may be some usefull info
#881
1 Post
So I finally put the car on jack stands tonight, took all the wheels off and cleaned them thoroughly inside and out. I also took off the rally armor mud flaps since they were pretty shot. Front brakes are also off and about to get refinished to go up for sale.
Just a heads up Ill be selling the OEM TypeS front calipers, with ProjectMU B-Force street pads and Hawk DTC-60 race pads for $350
Pics will be up as soon as the calipers are done
#883
Yeah Ive read alot on the KR header. Its def a good piece and I was actually considering buying one for a bit but Id rather support Buddy Club and use their product. Plus it will be nice to have full Buddy Club racing spec from the engine to the exhaust tip
oh i see. good to support a compnay your a fan of
whats the next brake setup your going with
#886
ohh snap, just read through this whole thread and damn man, definitely one of the best and most detailed builds I've seen. Definitely can't wait to see the progress with the engine. I'm guessing you plan to drive the car between now and the time the new engine goes in?
The ONLY thing I'm wondering about is why you didn't go with a plug-in relay harness for your S2K start button? They're so much cleaner than individual wires going to the relay prongs. I used to do individual wires, but when I did my HID headlight harnesses I used the plug-in harnesses for the relay on each side of the car.
Harness looks like this:
Installed in my headlight harness:
And all taped up:
And all taped up:
#887
1 Post
Yeah, I thought about that after the fact. Looking back I should have used one but ohwell, live and learn. And yeah the car is going back on the road with the A3 in the spring, Ill be driving it for another year or so before I put the new motor in.
#888
sweet man, nice to know it's not going to just sit for over a year.
Also the red door pulls are totally unique, never seen anything like that before. Just wondering how they're going to hold up with that cable in there after pulling on it many times.
#889
1 Post
The strap should be fine, its so thoroughly sewn that theres no way it will move around to chafe itself free.
#890
1 Post
Here is the airbox plug after high build primer and wet sanding. Still needs a few more coats and sanding but getting there!
#891
Good stuff, Evan. Make that baby strong as hell! Are you increasing the interior volume a all?
-Jalal
-Jalal
#892
1 Post
Thanks J, the volume will be increased a bit, mostly by having a smooth contoured bottom half. As you probably know the stock lower half of the box is all kinds of crazy shapes. Also, the lid wont have the resonance chamber and contours inside so that will add a bit more volume aswell.
#894
1 Post
Thanks B! I'm glad I decided to keep them too, I'm so excited to see the car back together with them stuffed under the rpf1s
#895
Looking good!!! I had to re-visit your build to get some more info on my new wheel setup. I don't have 9's, but got 17x8 with 225/45/17's in the front. I'll be putting them on once I get my new lugnuts. Always a pleasure to read your build thread!!!
#896
Thanks dude! Youre right about the airbox. what you see there is the plug to make the fiberglass mold with. Then ill use that to make the final product in carbon. Theres still ALOT of work to do, although the top is close to being done, I havent even started on the bottom half yet.
cool
nice to see the progress of it
i wanted to work with cf too and got some stuff together
but one and only i've done since now is covering parts in cf
one day i pick up the work and start some mold production :D
keep it up
#898
1 Post
Good luck with your carbon work! I just checked out your thread, it looks really good. I love the fuse box in the glove compartment
#899
1 Post
Little update for you guys... I test fitted my OEM shock braces which Im going to use to make a strut bar in the spring, and cleaned the trunk well while I was in there.
I also cleaned up and began tearing down the rear suspension. Lots more coming in this department soon
