Need help to reset SRS ind on accord Se 2002
Hi,
Last night SRS ind suddenly cam on and I know it can be reset using MES connector. But I am not able to locate it. Can any one help me locating MES connector, in Honda accord 2002 SE
GDD Member
Re: Need help to reset SRS ind on accord Se 2002
MES is under the dash on the driver's side by the fuse box.
You're going to have to unplug it and jump it with a paperclip, then turn the ignition on with it jumped.
With the MES jumped and key on (not start, just on), the light will come on, then go off.
When the light goes off, remove the paperclip jumper and the light will come back on.
Jump the wires again with the paperclip, the light will turn off.
When the light turns off, remove the paperclip again, SRS light will blink twice, then turn the ignition off and you're done.
Once you start it up again, the light will come on for a few seconds, then turn itself off.
Here's a random picture I ripped from google:
Thanks Slomofo, but I when put my head under steering wheel to see the connector, I saw ther were 2 yellow connectors attached to something. One is smaller and one is bigger. Which one is MES?
PaulRi
12-08-2015 05:29 PM
