New P.P & Middle East Record.
New P.P and Middle East Record.
Page 1: 9.7 run video added.
Page 2: Time slip breakdown.
Page 3: 9.412 & 9.477 runs video added.
Hi h-t
I took my SFWD civic to T&T after i install the ID2000 and A1000 pump, i tuned on dyno and manage 728hp @ 31psi then the car start spining on the roller.
firs pass of the night: 9.41 @ 252kph with 1.59 60 followed by 9.47 @ 251kph with 1.54 60 .
my setup is:
Engine:
B20 stock sleeves 84mm
CP 9.7cr pistons
Eagle Rods
GE block Guard
Ported PR3 head
supertech spring, retainers, valve seal & guides.
aloy retainers (may-be jun or spoon IDRK)
victor X inatake & Blox 72mm TB
chiniese intercooler
3" piping
Quick 4 (shorty) manifold
Tial 60mm gate
S372R / 1.0ar
Fuel, ECU & ignition:
ID2000 injectors
A1000 pump
5 gallon fuel cel (i stole Miller idea)
-10 feed / -6 return fuel line
BDL rail
Aeromotive regulator
Hondata S300 / boost by gear (Thanks Magican (Miller)for the tricks on the S300)
stock ignition / NGK wirs & plugs
Drive train:
Stock GSR trans
CC clutch twin plate
DSS 5.9 axel
Tein flix street coil over w/ custom rear spring rate
Spin werks 13x8 front / 13x3.5 rear
M/T 24.5x8x13 / Hosier 24.5x4.5x15
All fabrication, chute, engine built was done by my bruther, and tuned by me (i have good experiance in tuning hondas around 5 years)
video will be uplod later on.
Big thanks to:
Chris Miller (i never talk to you but i learn many things from you)
Chris Xenocron (thanks for the killer deals)
Mike Laskey (thanks for the killer deals)
from Bahrain:
-My yunger bruther (You are the best driver/mechanic )
-My wife & daughters (for supporting me & let me spend on my junk )
-Moh'd Khunaizy (thanks for all the help & support)
-Salman ((Drift King)) (thanks for all the help & support)
and All my frind and fans.
regards.
http://www.youtube.com/watch?v=oajOCwpWO0A
Hi h-t
my setup is:
Engine:
CP 9.7cr pistons
Eagle Rods
GE block Guard
Ported PR3 head
3" piping
Tial 60mm gate
S372R / 1.0ar
ID2000 injectors
A1000 pump
BDL rail
Drive train:
Stock GSR trans
DSS 5.9 axel
Big thanks to:
from Bahrain:
regards.
Re: New P.P & Middle East Record.
and i am runing VP C16 since i cant run Q16 or Import with my ID2000.
wow nice times, how long do you expect the B20 sleeves to last at your power level?
Also whats the story with the ID2000's and only C16, I was going to get a set for my new build but if I cant use them with Q16 then I certainly dont see the point.
I am interested in your dyno graph, I haven't seen anything for s372r with the 1.00 turbine housing and that's what I bought awhile back, still waiting on some funds for my id2000's and fuel pumps before I can start it up.
regarding the ID2000, i think that kind of fuel has something which effect the internal seal and cause them to cloges but you can check with T1 for more information.
Thanks man, actually i am tuning it.
Do you know what the fuel pressure is? I was under the impression that the A1000 couldn't provide the pressure to take advantage of ID injectors. Good job by the way.
Congrats thats awesome
Whats the breakdown of the slip? I want to race on that damn track, lol.
252 is like only 150ish mph? thats awesome, congrats again.
