will DA integra suspension fit on EG hatchback?
Old 01-15-2010, 08:44 PM
gelok's Avatar
Default will DA integra suspension fit on EG hatchback?
Does anybody know if the 90-93 Integra suspension will fit on 92-95 Civic hatchback?
Reason I'm asking is because I totalled my 92 integra and it has a TEIN super street suspension in it. So before I sell it, I want to make sure that it will not fit on an EG because that will be my next car. TIA
Old 01-16-2010, 07:14 AM
gelok's Avatar
Default Re: will DA integra suspension fit on EG hatchback?
Bump for help!
Old 01-16-2010, 08:09 AM
ricanzxrebel's Avatar
i think so but dont know for sure
Old 01-16-2010, 04:15 PM
gelok's Avatar
^thanks! Anybody else?
Old 01-16-2010, 07:50 PM
gelok's Avatar
TTT
Old 01-16-2010, 09:09 PM
nothing_shocking's Avatar
I know that 3rd gen teg stuff fits, and I know the front upper strut bar from 2nd gen tegs fit on 5th gen civics (I have one) so since those nuts line up, it might work. If you don't get an exact answer here, just try and swap them in and see what happens.
Old 01-16-2010, 09:31 PM
Geoff92's Avatar
it will fit, but it will raise the front 2", and the back some more too, because the rear struts are much longer, and you must use the DA front forks aswell. i remember when i had my db2 (gs-r) its the opposite for eg suspension on those, the rear will sit lower than the front, and the front is automatic 2" drop, but if they are adjustable, it should be okay.
Old 01-17-2010, 09:42 AM
gelok's Avatar
Thanks a lot fellas for some good info! I'll be doing it as soon as I get my da back from the insurance!
Old 02-12-2010, 06:26 PM
killrlovr's Avatar
will the ef tein super streets fit on an eg?
Old 02-12-2010, 06:34 PM
BMWLOVE100's Avatar
yes it will
Old 02-12-2010, 06:49 PM
killrlovr's Avatar
how sure are you? cuz i can get them but i dont want to if they dont fit.
Old 02-12-2010, 10:24 PM
hushypushy's Avatar
EF/DA front suspension works on EG/DC and vice versa if you swap the forks too. The rear suspension is identical, nothing to change.
Old 02-13-2010, 08:06 AM
Geoff92's Avatar
Im pretty sure the rears will be longer, much like the DA suspension. but if they are adjustable then it shouldn't be an issue as you can just adjust the difference.
blk02ep3
09-21-2009 09:35 AM
Andyroo
10
03-09-2007 09:51 AM
1 sLoW hAtCh
01-16-2006 06:40 PM
AmginE
10-23-2004 10:07 AM
Quick Reply: will DA integra suspension fit on EG hatchback?
