wrong intake mani?!? pls. help
so im tryin to do a mini me on my 96 civic coupe 5spd
i have a d16y7 and pieced together a y8 head
and i just ran into some problems
i purchased a y8 mani but for an auto and wasnt aware of that til a few mins ago, is der a way i can make this work
also i wasnt able to find a y8 obd2 throttle body so i got a b18 obd0 throttle
i know it can work (might be a lil more messy) but wat should i expect?!?
and last, my ecu is a p2n. now im not too sure but i thought it came on an hx ek which are non v-tec, although the guy who sold it to me told me he got it off an ek ex which was equipped with v-tec
please enlighten me wid some knowledge
im in serious need of help
let me know if this set-up can some how work since im completely out of funds now
thanx
thanx
Re: wrong intake mani?!? pls. help
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/%5Bfaq%5D-d16y7-y8-mini-me-write-up-pics-56k-maybe-not-735196/
Is there really a difference between the manual and auto manifold? in fact was it the intake or exhaust manifold you have?
its better to use an auto y8 manifold because the auto has the iacv on the throttle body.. same as the y7 throttle body.. the manual throttle body has it on the manifold itself.. so good to go with the auto manifold.. so you can use your y7 throttle body.. but you will need the ROTOR and SPRING from a y8 throttle body.. rotor and spring is the piece that the throttle cable connects onto..
i believe hx models came with vtec.. but economy vtec.. http://everything2.com/title/VTEC-E
https://honda-tech.com/forums/showthread.php?t=735196
and ima run the y7 exhaust mani but the y8 auto intake mani
i had been stuck on this, even after about 5 hours reaserching
thanx
you will need to run the Y7 ECU if you're going to use the Y7 TB.. the P2P Y8 ECU isn't compatible with the 3-pin IACV on the Y7 TB.
but if i run the y7 ecu wats the point of doing the y8 head?!
the y7 ecu which is p2e, i believe, doesnt come with vtec
hmm didnt know the y8 ecu wouldnt work with y7 tb.. hmmmmmm.. i got a manual y8 manifold on me.. was planning on putting it on my y7.. but im keeping my head y7 too.. would make it easier if we just traded.. haha..
dam!
ill meet u in santa barbara!
lol
i just noticed ur location!
lol
i wonder how much shipping would be?!?
pm me ur zip
lol
lol
pm me ur zip
11-04-2012 07:24 PM
SOHC_Brian
01-15-2004 08:57 AM
