Anyone down for the cheapest stroker kit? H22A4s, H23As, F23A, F20B
Yes guys, i do mean stroker kit.
Me and a member from cb7tuner been on this for a cupple months now, and im just finished all my research, and soon going to start experimenting. The crank im going to use, is a honda crank and fits in 55mm main journals.
What im talking about is a 2.5l stroker kit for boost, and 2.4 for na
The downfall is, the block has to be resleeved for my stroker kit to work. I might try to see if a local machine shop in my area, could hook me up with sleeving services.
Parts used
CP Pistons 90mm 11.5.1 cr. (which equals out with my rod/piston combo - 9.3cr/2519cc/1.39 stroke ratio)
Weisco Pistons 89mm 14.9.1 cr - NA USE ONLY! (with my rod/piston combo - 11.1.5 cr/2463 cc/1.39 stroke ratio
Eagle Honda Spec Rods (could handle 900hp)
Acl Bearings
Honda OEM Crankshaft
Ill start working on the boost kit this spring and let you know how it works out. Right now im looking for people intrested
Parts used
Acl Bearings
