D16 Diff bearing Ques
I am trying to install new differential bearings on my Mfactory LSD which will be installed in a cable D16 Si trans (PL3 3000)
I received my bearings from Majestic Honda and they are obviously for the 35mm case.
I ordered diff bearings for my 1991 Civic Si.
Part # 6207
91005 PL0 008
So, upon research I see that two part numbers are given for the 40mm case.
I searched for a 1989 CRX Si and 1989 Civic Si
Part # 6208
91005 PL3 B04
1994 Civic EX
Part # 6208C
91005 PS1 003
Which ones should I order for the Mfactory LSD inside the 40mm case? The 1608 or 1608C?
**BTW since the 35mm bearings are special order, they cannot be returned. If anyone has a need for them LMK. **
Part # 6207
91005 PL0 008
Part # 6208
91005 PL3 B04
1994 Civic EX
Part # 6208C
91005 PS1 003
D Tranny Guru
Re: D16 Diff bearing Ques
Did you order axle seals as well?????
Might wanna check the number on the drivers side, Honda also has that messed up listing a wagon axle seal instead.
Generally when I order all bearings and seals, I stay within 92-95 era due to correct part numbers.
Hmmm, Ill check. Thanks for the heads up.
cougar289
Transmission & Drivetrain
07-28-2009 06:16 PM
speeddave
04-29-2009 11:35 PM
