my very basic ls turbo build thread.
back to boost for me
1990 ls motor ($200)
8lb flywheel
act 4 puck sprung clutch
gsr tranny from last build
welded diff (love it)
ebay cast iron mani
ebay 38mm waste gate with vac bolt shaved down so it wont rub on the diaphram
custom dump tube
ebay ar.50 turbo
3" custom open down pipe, bumper exit
mild steel charge pipes
oil restrictor
dsm 450cc injectors
gm 3 bar map
s300 with boost by gear
goals are 275-300whp and traction. all I want is 12's on street tires.
my old all motor ls, ported head, gude performance cams, 8k all day
working on shaving / tucking the bay
worlds gayest valve cover lol
waste gate dump tube,will be painted and wrapped with header wrap
8lb flywheel
ebay cast iron mani
custom dump tube
ebay ar.50 turbo
oil restrictor
dsm 450cc injectors
gm 3 bar map
Re: my very basic ls turbo build thread.
lose the ebay 38wastegate.. next thing you know the gate wont open and your car will blow up.. i'll sell you a tial for 130shipped. 7psi spring.
used them before for over a year with out any problems. Iv had a tial 38 and a ebay, only diff was on the ebay the diaphram would rip because the bolt for the banjo fitting is too long so I shaved this one down so it wont rub.
a few more pics
gonna start fabbing up the down pipe today, unfortunately its about 22 degrees out :s
today was FREAKIN COLD
im so tired of the 20 degree weather around here, its the coldest its been in 11 years!
so today I wasn't down to spend the whole day working on the hb but I did run a few errons and grab some small stuff that I needed, unfortunately the throttle body gasket I bought was a hunk of crap, it was a feelpro but the bolt holes were all off by about 1/4" so tomorrow I have to run to honda to get a new one.
I also have to cut the radiator brackets because I had to cut them when I put my dc radiator in for my all motor setup. its extra work, but its all good since now I can move the radiator as far away from the turbo so the down pipe will clear it even better.I think Im gonna also make a custom radiator overflow that I can hide away some where.
I sold my old ls longblock for $1100 lol
other wise I would have boosted that one, it ran hard as hell on a 85 wet shot
started fabbing my downpipe today. its gonna be 3" out the bumper
of course.
Iv ran exhaust out the bumper on a sohc turbo I used to have and didnt have any issues with the po po's
its actually quieter then like a normal under car open down pipe because it doesn't resonate the whole car. its also alot better on fumes and exhaust ..etc
as for the welded diff, if you know how to take the diff out of the tranny then all you have to do is weld the two spider gears to the drive gears, Iv put about 5k miles on mine with out any issues and I have a 231whp all motor b20 vtec in it.
the welded diff makes parking lots kinda suck, but a hell of alot cheaper then buying a good lsd or spool. and if it breaks a stock diff isn't very expensive.
it also greatly improved cornering in my car which I couldn't believe at first. its much more of a point and shoot car now.
Dang son i wished i would have bought the chrome EMUSA wastegate. Those are good wastesgates from what i hear. Me and two of my friends are using them.
only thing I dont like about my wastegate is it seems to sit up hella high so Im gonna have to cut out some of the hood support or prop the hood up or something. or just let the natural route of things go and have the w.g. beat the **** out of my hood lol.
and justin.... yur ***** weak. Ima hit u up 2marro 2 get random assorted ls junk
