Fog light install issue
I have a 2000 Civic Si and i bought fog lights for it off of ebay and they didnt ship with instructions..supposed to be a factory kit..came with factory switch to mount next to my sun roof switch in the car..but my issue is A) i have a bad ground. or B) there is a brown plug that i have no idea where it goes its connected to a white wire thats comming off of the switch and it has a sticker tab on it that is labled "Lgn ition"...i tried bringing it up on line for a wiring diagram but no luck..they are VinJet brand...any suggestions?
Re: Fog light install issue
for the ground grind the paint anywhere in your chasis where not visible behind bumper...
as the brown wire gots to go to fuse box all the way up to there is like 5 in a row plug it where it fits that's it
there is no brown wire its white with a brown plug..i figured that for the grounds but im still stumped on this plug issue
Yes, the brown plug goes to the interior fuse panel. The slots for that plug are located at the top of the fuse panel and I believe there are 4... My 99 Si was really picky as to which plug the lights would work properly on though and my switch still will not turn them on and off, just come on with the headlights and won't go off with my high beams. Hope you have better luck lol
I am having issues with my install as well... I found my brown plug that goes behind the fuse box, however I am left with two other brown plugs (one connected to a red wire and one connected to a black wire). It says, in step 27 of the install manual, "connect the switch harness connectors between the headlight switch and the vehicle harness." the diagram http://www.handa-accessories.com/civ...cfoglights.pdf shows to disconnect the connectors from the headlight switch and pull them to the side (step 26) which I have done, yet I am confused on step 27... Suggestions?
...When I do this, I'm going to throw that damn switch and instructions away. Many of those switches and instructions are dumb and really make the situation worse. I just plan to direct the lights into my parking light system.
this should help
http://www.hondacivicforum.com/forum...ad.php?t=61880
^. Now I've found a walkthrough that starts at the console and shows you how to swap the system into your parking lights by swapping a few pin connectors. at what point would I end the circuit? Because it's obviously an open circuit till you connect the switch. Would I just need to end the circuit at the vehicle harness/fog light harness connector? That's what makes sense to me. Then from there swap the pins.
Here is a shot of my fog light switch harness... http://s6.photobucket.com/albums/y21...=1280871135632
the two plugs I have vacant are the two brown ones, one red wire & one black wire. here is a close up shot http://s6.photobucket.com/albums/y21...t=DSC01395.jpg
Since I cannot think of anywhere these would go, I am thinking about snipping the plugs off and grounding the black wire (which would be a second ground) and running the red wire to a fuse to generate power. Is this a good idea, or are these plugs actually meant for something?
Okay. Now i had some issues kinda like your's, but to my knowledge the Red wire/Brown plug goes into one of the 5 connectors at the top of your fuse box. That "should" be your Pwr wire. Now the Black wire/Brown Plug is kinda iffy. I wouldn't cut it and assume its a ground since you grounded a "ground" wire already. That wire might plug into another Brown wire taped up with Blue tape to the Back side of your fuse box. Not Sure though. Try that and see if any of this helps you
Also i didn't this route because when i pluged that brown plug into the fuse box, i went to hit the fog switch and Bam! it melted the inline fuse wiring and got all sketchy. LOL
Okay. to my knowledge the Red wire/Brown plug goes into one of the 5 connectors at the top of your fuse box. That "should" be your Pwr wire. Now the Black wire/Brown Plug is kinda iffy. I wouldn't cut it and assume its a ground since you grounded a "ground" wire already. That wire might plug into another Brown wire taped up with Blue tape to the Back side of your fuse box. Not Sure though. Try that and see if any of this helps you
i got my kit off ebay too, but from K2 motors(thinking it should be really easy to install, cuz i seen an article in project car mag several years ago) and when i got my kit, my relay side of the kit had to be wired outside in the engine bay,Red wire with the inline fuse went straight to the battery, ground wire grounded, and the wire that is suppose to plug into the brown plug by the windshield wash resevoir(blue wire) i ended up cutting that extra wire u have with the plug and spliced it into the the other red wire so i could plug it in to the harness by the resevoir, now for the inside wiring, the green plug should go to the switch, mine had couple extra plugs also, i had a white wire with brown plug so i found a slot for it in the under dash fuse box......My kit has 3 wires coming from the switch=Red-wire it or plug it into the blue wire w/brown plug(its under their)
White wire w/brown plug-plugs into fuse box
Black wire- Find a good ground(i used the kick plate bolt right below the steering column......Hope this helps, i'll try and take some pics of my set up if possible....
I checked again behind the fuse box, and the only wire with a plug at the end of it was that of a different connection and it was a two-wire plug (blue and black wires). here is the pic http://s6.photobucket.com/albums/y21...t=DSC01404.jpg
are you saying there are connections for the vacant brown plugs to just insert into the back/top of the fuse box?
If you can post pics of this it will give me a good idea of what to do. Im following what you are saying but I am a visual learner. Was your kit also for a 99-00 or does the color of the wires just not matter?
eternity-
13
05-20-2015 09:18 AM
DOMAN!EJ8
16
09-02-2009 10:17 PM
