Thermostat replaced, now leaking coolant from housing
Old 11-09-2009, 04:12 PM
jermie_jrmz's Avatar
Icon3 Thermostat replaced, now leaking coolant from housing
So I had drain/flushed/refilled my cooling system and replaced my thermostat, because my civic was overheating. During the test drive, after flushing my cooling system and replacing the thermostat the overheating went away. But as soon as I got home coolant was dripping/leaking out of the thermostat housing.
Should I put a sealant/gasket? Help would definitely be appreciated.
Old 11-09-2009, 04:15 PM
Function>Fashion
Harlowe's Avatar
Default Re: Thermostat replaced, now leaking coolant from housing
There should be a rubber ring that you put around the thermostat before you put it in. Did you install that?
Old 11-09-2009, 04:16 PM
Yeah I did.
Old 11-09-2009, 04:35 PM
redbull-1's Avatar
Take it apart again and check the rubber seal position. You may need to try another rubber seal if it still leaks.
Old 11-10-2009, 04:00 PM
eviee1973's Avatar
The rubber seal is not reuseable, and very prone to getting caught and damaged, even with a brand new one. Personally I hate the angle the housing is at as it is extremely difficult to get everthing into place, and then trying to fasten the bolts.
Old 11-13-2009, 04:20 PM
boxeocampeon's Avatar
you might have smashed the gasket when you put it in did you over tighten it?
Old 12-31-2009, 04:51 AM
honda.lioness's Avatar
Red-bull-1, that drawing above that shows a bleeder bolt is not from a Civic, right? I only found a bleeder bolt on the thermostat housing on some Accords and Preludes. Folks often ask here about bleeding their Civic's cooling system, so maybe some clarification is needed. My owner's manual, FS manual and www.bkhondaparts.com show the 01-05 Civic to have no bleeder bolt anywhere. Instead, per the steps in the manuals, bleeding is accomplished by letting air bubble up through the radiator filler neck.
Old 12-31-2009, 12:51 PM
If memory serves, folks here and/or elsewhere have reported that the Civics without a bleeder bolt do not purge very well using the manual's method. (My 03 Civic is not due for many more miles or three more years, so I cannot give eyewitness testimony on this point just yet for this generation. But I am watching the posts on the subject for future reference.)
Old 12-31-2009, 08:42 PM
Whatislove's Avatar
its also good to wet send the surface before installing the new gasket. nothing major, just give it a shine.
Old 03-09-2015, 04:15 PM
vladarab's Avatar
Hello guys ive been having the same problem housing leak so i discovered a design flaw on thermostat housing. if you take it out and put it on a flat surface the two holes where the bolts go through swing back and forth when you press on them. so no matter how new the gasket is or how tight the bolts are..its not flat. the housing is warped due to old age and excessive heat. an easy fix so i used a power sander to grind it flat again. then it it will not swing.
chrysler kid
12-09-2016 08:26 PM
lfunk11
01-16-2012 12:34 AM
ehonda1980
07-29-2007 09:03 PM
stdefhatch
07-15-2007 07:27 AM
kevin96GSR
02-03-2004 06:41 PM
Quick Reply: Thermostat replaced, now leaking coolant from housing
