> Acura Integra
Old 11-07-2009, 01:21 PM   #1
huckaboo
Default knock sensor help!!
so heres the deal... i have a ls/vtec swap in a 96 teg its a b16 head on a b18 bottom end. i have the stock ls wiring harness being used and vtec is wired into it. also im running an obd1 gsr ecu... heres the problem though..... my CEL is on and its code 23 (knock sensor) the car still hits vtec just not as hard as it should. now i herd of someway to bypass the knock sensor and loop the wiring so the ecu wouldnt throw a cel. does anyone know how to do this??? if so it would be a great help!! thanks
huckaboo is offline Report Post   Reply With Quote
Old 11-09-2009, 09:23 AM   #2
huckaboo
Default Re: knock sensor help!!
come on 27 views and no one can help me... someone has to know something....
even if someone could tell me how to install a knock sensor and how to wire it into the ls harness into the ecu id be happy with that!
Old 11-09-2009, 12:03 PM   #3
lindseyhunt1090
lindseyhunt1090's Avatar
your check engine light is on because you dont have a knock sensor and you have a gsr ecu. Sence its an lsvtec its using an ls bottem which does not have a knock sensor. Your light is on because your ecu requies the knock sensor to adjust the timing for optimal performance. Using aftermarker tuning software people do sometimes disable the knock sensor. For stock applications i would put one in.
Sence the ls block does not have a spot to put, lots of people will just mod the alternator bracket and monting bolt hole to the right of the motor (closer to center of engine) take the bolt out and tap it to the same thread as the knock sensor and then screw the knock sensor in to hold the bracket. Then just run the wires to the proper pin outs on the ecu
You can show a race car, but you cant race a show car.
lindseyhunt1090 is offline Report Post   Reply With Quote
Old 11-09-2009, 12:24 PM   #4
huckaboo
ok thank you do you know which pin out it is?
Old 11-09-2009, 12:43 PM   #5
lindseyhunt1090
D3
Old 11-09-2009, 02:07 PM   #6
never-lifts
now thats whats up.
never-lifts is offline Report Post   Reply With Quote
Old 11-09-2009, 11:26 PM   #7
huckaboo
thanks guys ill let you know how it is after i put it in! anyone know any good places to get one?
Old 11-10-2009, 05:12 PM   #8
God-Driven
God-Driven's Avatar
as far as im concern ls/vtec requires tuning since theres not an ecu made for this set up from the factory, most of the guys that do this sep up use a P28 ecu and get it chip for ls/vtec.
God-Driven is offline Report Post   Reply With Quote
Old 11-11-2009, 07:30 AM   #9
huckaboo
i believe my ecu right now is chipped i just dont know what with.. is there any way i can tell?
Bookmarks
05, 2002, 97, accord, acura, bypass, honda, install, integra, knock, ls, put, sensor, show, tl, vtec
