#1 | |||||
ej8 squad Last edited by 94dc; 11-08-2009 at 01:45 AM. |
#2 |
if the holes aren't really that big, then yes, you can use body filler to fill in the holes.
97 Prelude-wrecked 00 Prelude-Daily Driver 99 Prelude-RHD Prelude http://images.honda-tech.com/set1/smile/emwink.gif 98 Prelude-Parts Car-SOLD <FONT COLOR="blue">Retrofit service/pics</FONT> http://www.myspace.com/bceretrofits |
#3 |
k thanks for your help man
ej8 squad |
#4 |
NOO!!!! dont fill over them. weld them shut or they will crack out
91 CRX Si - BLOWN AND SOLD ![]() 93 EG HATCH (B16 MONSTER) - TRADE ![]() 91 SiR EF HATCH(I.T.R. SWAP) DD ![]()
#5 |
o damn thanks for tellin me..is there anything else i can cover it with that will stick to the filler like a special kind of tape or something??cuz i dont have a welder & neither does any of my friends & i dont have money to take it to a shop to do that
ej8 squad |
#6 |
That's not exactly true! its like what the other guy said its fine if you don't have a hole that's to big you can put body filler on it also as long as you body work is good you should be fine...but if your a noob at that then you should have a shop do it or someone with a bit of better knowledge go at it. Also welding is the full cure for it though...just whatever you can gain access to or within your budget.
Love it or Hate it...get over it!
#7 |
If the holes aren't that big, you can use body filler and it won't crack if you do the work right, but if the holes are pretty big, then welding them up shut would be best. If you weld too hot, then you may warp the metal which will cause you to do more work than what was needed
#8 | |
i just posted some pics of the holes lmk what you think
ej8 squad |
#9 | |
& i just posted pics lmk what you think
ej8 squad |
#10 |
the best thing you can do its weld the holes first and then the magic "bondo"
#11 |
Why not use fiberglass materials..
#12 | |
#13 |
You guys are killin me here.. First off, Welding the holes is the only CORRECT way to do this repair. Simply filling them with body filler will work fine for now but eventually it will absorb moisture from the backside and the filler will start to fail. You will see bubbles that look kinda like rust, or it will crack. If you simply insist on putting filler over these holes make sure you use a moisture resistant filler first, (All metal, Duraglass, Long and Strong, Kitty hair, Metal 2 Metal, etc.. there are a lot of them) Then use regular filler on top to finish the repair. Good Luck
60% of the time, it works everytime... |
#14 |
he is right normal polyester filler is not water resistant so moisture will get through it and will cause the metal to rust....you need to put a fiberglass filler dwn first thoes holes arent that bad i would use a fiberglass filler first (dura-glass) then i would sand that down so its smooth and you really cant see the holes (maybe out lines of them) then i would go over that with a light body filler. that way is the way i would do it and have done it |
#15 |
Welding isn't really the best way to fix those small holes....because youll burn the paint off the back of the panel and it will rust quickly.
Use short hair fiberglass filler.
Bottle Fed Racer....... |
#16 |
Wrong, if you work in this trade then you know the ways to treat the back of the repair.
#17 | |
Why would you want to weld a hole that small anyway?, especially on a stamped curve like that,the metal is thinner then the 22ga. the factory started with and you risk the chance of making the pencil eraser size hole the size of a quarter. He's gonna use filler there anyway, OP Tap those high spots around the holes down use the short hair to plug em'(push the stuff in there good with your paddle), then put lightweight filler over it dont listen to these guys about moisture because the paint is gonna seal it, good luck its just a small dent. The proper way to fix any hole in any car is with a adhesive panel kit, so Whaaah!
Bottle Fed Racer....... Last edited by Transpoquick; 11-11-2009 at 09:57 PM. Reason: actually I'm not in the trade, but I know more than previous poster. |
#18 |
dude the days of drilling holes into your car are over.... why!
#19 |
J B weld. the damn hole shut. if it can hold in freeze plugs it can fill your hole. sand smooth. seal metal on both sides so nothing can get to it. go on from there with body work. simple easy may not be the best way to fill the holes, but it will work.
#20 | |
#21 | |
Bwahahah you can't even spell adhesive, you expect me to believe your a certified bodywhore. Btw OP was looking for ways other than welding, and actually were both wrong, my full time friends who have been in the business for way more than 15 years saw the holes and said a stud gun would be the way to fix those, but the holes may be a little large. They also said something about a "eagle 2", at that point in the conversation though I was starting to nod off because body work is boring. Later Doo!
#22 |
thanks everybody for all your help..im pretty sure i know what to do now but just have to wait for a warm day to come cuz its been to cold to do anything lately..F reno weather lol..
thanks again everybody for your help
ej8 squad |
#23 |
just weld it bro based on common sense and it wont bothers you in the future anymore
#24 | |
I'm a bodyman not a spelling bee champion dumbass.. And yes if the holes were smaller, you could put studs on with a stud gun, cut them off and grind it down.. And in doing so you are WELDING the hole shut genius.. Anyways thanks for the entertainment.
#25 |
just fiberglass them
| Bookmarks |
| Tags |
| acura, dent, fix, hole, integra |
