#1 | |||||
#2 |
O
#3 |
K
#4 |
TSXs wiring harness is different, hence that's why when people with TSXs upgrates to K Pros they need to run dual ECU... you can only use some sensors off that K24 but not all.
08 SPOON TSX #57 ~wife 08 JIC Magic Time-Attack FG2 #58 ~driver 06 SPOON DC5R ST#59 ~ my track whore |
#5 |
Wow, way to do things the hard way. If you got kpro, you could use the ep3 harness, waterpump/ therastat housing and t/b for a rather easy install. Hondadata even have a map for this.
old cone killer
#6 |
Thanks
Well I am happy to know that k-pro is the best solution. I guess then I will use the k-20's sensors, maybe I can get a bit of $ for it. While we are on the subject, what's the recommendations for handling sensors? Like avoid contact with ?* chemical. Storing or cleaning them? I will have a look on Hondata's site about the use of the tb. I wonder if the pedal / cable requires? To work. Anyways would have had it on except missing a motor mount. Arrived later then planned. I will try to film one funny ass back alley ghetto style engine swap. Gotta love the ghetto. You can get away with some crazy shit! I also wanted to know about the coils from the TSX are much better then mine. I wanted to use them. I can only assume they are the same. I wanted to know about opening these wire harnesses. Never done it. Other then that cosmetics are looking fine. Gonna put a few pics later. Thanks guys |
#7 |
Did you get this engine off Eric in Allentown, PA?
Just finished my 08 TSX swap I can try to help ya with answers, but yeah you really should go with KPro + the EP3 wire harness. much simpler.
"So whats the deal with politics? I don't get it...Am I right people? ![]() ![]() "
#8 |
Yeah I think any other way is difficult.
You say you have the same set up? I would love to know how it feels and your comments on how drives and how it differs from the tiny loud ass k20a3. |
#9 |
Yeah, its an 08 but same shit.
I am very pleased with the power (TORQUE!). Its a real night and day difference. Even at like partial throttle it feels stronger than the A3.
#10 |
Funny how this makes this all worth while.
Did you need to change the exhaust mani? I mean looks the same but i did not caliper measured it. If you used some sub model substitute witch one was it? Thanks. |
#11 |
I have heard the stock EP3 header clears the sway bar ok on 02-03 EP3s. Not sure about 04-05 sway bars. But I used a DC Race Header so i don't know. The DC rattles against the sway bar on my car right now which is pretty annoying.
#12 |
Well sorted it out by replacing the exhaust elastics by general use ones by cheaper rubber stiffer then the stock. Tire pressure is also a factor they must be the same. Otherwise they rattle more. But yes the elastics should do it. A 20 at Autozone should do it. I miss the Cali sun.
#13 |
HT White Ops
You miss the Cali sun get ready for the Montreal cold and snow buddy!!!
PSN: DaveSi677 2002 EP3 SiR Nighthawk Black 1993 EG Si Type-R Berlina Black RIP |
#14 |
I know born here, studied 4 years in Vegas. Don't ask...
Guys I got a stuck tie rod. Got a work around? |
#15 |
Just tell me what you think about this:
#16 | |
http://www.etoolcart.com/balljointseparatorotc6297.aspx get the spx tool, the cheaper ones are crap and they will brake.....It also works on the lower balljoint. The trick to suing them is you put a load one the tool, then smack the load side with a hammer....."POP"....joints apart.
old cone killer
| Bookmarks |
| Tags |
| 02, civic, em2, engine, ep3, funniest, honda, k20aorg, k24a2, motor, swap, swaps, tsx |
