#26 | |||||
1999 Honda Civic |
Vouches: tgh99si, ryanbartholomew85, black_hatch, Hittnthebz, b20turbojason, Hatchdude, civic-97-si-nx, Galaxykid70 AIM: Im4Kart6 E-mail: Feartheh1@verizon.net |
#27 |
1999 Honda Civic |
So factory dizzy that I know for a fact is working(rebuilt while MSD has been on) is not allowing my car to fire either, no spark. Any ideas wtf is up with my car?
#28 |
Don't guess, troubleshoot |
#29 |
1999 Honda Civic |
I'm a wiring retard, how exactly do I test for a short/open? I don't mess with electrical. I do appreciate all your help thus far ron
#30 |
1) First test whether the dizzy gets battery voltage.
2) To test the Yel/Grn wire for an open or short, disconnect the wire at the ICM and disconnect the ECU connector where the wire is routed to. Open test: Use a multimeter to test continuity of the wire between both ends. If there is no continuity, then the wire has an open (= broken wire). Short test: Use a multimeter to test continuity to ground at each end of the wire. If there is continuity to ground, then the wire has a short (it's grounding out due to damage).
#31 |
1999 Honda Civic |
Anyone have a wiring diagram of the wiring from ecu to dizzy?
#32 |
1999 Honda Civic |
No one?
#33 |
1999 Honda Civic |
Culprit was the coil... Tested good but swapped the thing with a blaster2 and it now runs smooth and only throwing a code for o2 sensor 1 low volts. Any way to correct this? Or do I just need to replace?
| Bookmarks |
| Tags |
| 2000, accord, car, civic, died, honda, integra, odyssey, p0170, p0171, type |
