Old 11-04-2009, 06:55 PM   #1
FearTheH
1999 Honda Civic
FearTheH's Avatar
Send a message via AIM to FearTheH
Icon2 CAR DIED! P0170 and P0171
So after turning in my reports at work last night I went to leave and my car didn't make it out of the parking lot. Upon accelerating it wouldn't go past about 2500 or 3000 rpms then it died. I scanned it today and pulled p0170 and p0171. I've tried searching and all related topics have been unresolved...does anyone know what I need to do to get my car running again? Any help is greatly greatly appreciated!!
Vouches: tgh99si, ryanbartholomew85, black_hatch, Hittnthebz, b20turbojason, Hatchdude, civic-97-si-nx, Galaxykid70
AIM: Im4Kart6
E-mail: Feartheh1@verizon.net
FearTheH is online now Report Post   Reply With Quote
Old 11-04-2009, 07:48 PM   #2
Unseen Racer
Unseen Racer's Avatar
Send a message via Yahoo to Unseen Racer
Default Re: CAR DIED! P0170 and P0171
we need more info than that.
what year is the car? how many miles?
any mods? etc
Originally Posted by Danthemagicbum
I've actually seen you make intelligent posts before.
Originally Posted by ZTwentyH8
I'm kinda pissed. I have yet to meet Chris Hanson.
Unseen Racer is offline Report Post   Reply With Quote
Old 11-04-2009, 10:17 PM   #3
93HondaDelSolSi
93HondaDelSolSi's Avatar
year of car and engine. i can get more info during my lunch hour and get you a description and trouble trees.
93HondaDelSolSi is offline Report Post   Reply With Quote
Old 11-04-2009, 10:27 PM   #4
Lord Yod
P0170 is Fuel Trim Malfunction, P0171 is System Too Lean (Bank 1). With both of those coming up at the same time out of the blue, I'd suspect a fuel pump problem. Turn the key off, then turn it to the on position (without cranking) for a few seconds. Can you hear the fuel pump cycle? If not I would check the fuel pump relay to make sure it's working.
Lord Yod is offline Report Post   Reply With Quote
Old 11-04-2009, 11:29 PM   #5
FearTheH
1999 Honda Civic
FearTheH's Avatar
Sorry fellaz, its a 99 em1 with 177xxx miles, intake and catback with brand new cat(oe not high flow) B16a2 ported head and 3angle valve work. Fuel pump was checked first and is priming properly, also checked fuses and all were good. Everyone else that is getting these codes seems to be able to still drive their vehicle, however mine will not fire and I haven't been trying to make it, just to prevent any other potential damage. I just had the timing set one week ago on it. I'm really wondering what could make it not rev past 25-3K rpms and then die. Again, any help is greatly appreciated!
AIM: Im4Kart6
Old 11-04-2009, 11:33 PM   #6
FearTheH
1999 Honda Civic
FearTheH's Avatar
Also I did run a bottle of lucas fuel injector cleaner through it a week ago... This happened the same night that I filled up with exxon gas as well and I'm kind of wondering if it was related in any way and how I could pinpoint if it was so they can do me the honor of paying for new parts.
AIM: Im4Kart6
Old 11-05-2009, 12:21 AM   #7
Lord Yod
Did you check your fuel pressure?
Old 11-05-2009, 01:12 AM   #8
FearTheH
1999 Honda Civic
FearTheH's Avatar
Negative, don't have a guage. May see if the local parts store has a loaner guage... What should stock fuel pressure be?
AIM: Im4Kart6
Old 11-05-2009, 06:17 AM   #9
RonJ@HT
RonJ@HT's Avatar
Clogged fuel filter?
Measure the fuel pressure and check the primary O2 sensor.
Don't guess, troubleshoot
RonJ@HT is offline Report Post   Reply With Quote
Old 11-05-2009, 11:53 AM   #10
FearTheH
1999 Honda Civic
FearTheH's Avatar
All pressures are good and now I do not have spark... I think my coil blew but not sure. Looking for my factory dizzy now, cleaned injectors(dirty as hell!) And now just tryin to get spark, all fuses rechecked and are good.
AIM: Im4Kart6
Old 11-05-2009, 11:57 AM   #11
RonJ@HT
RonJ@HT's Avatar
Does the dizzy get power on the Blk/Yel wire? Any CEL codes? Have you tested the ICM and coil in the distributor? The fuel pump still primes, right?
Old 11-05-2009, 12:18 PM   #12
FearTheH
1999 Honda Civic
FearTheH's Avatar
Fuel pump primes, coil is good, msd coil driver is good still no spark after swapping known working parts. Haven't checked the yellow and black wire. What should readings be? And what to do if no power?
AIM: Im4Kart6
Old 11-05-2009, 12:23 PM   #13
RonJ@HT
RonJ@HT's Avatar
Any CEL codes? Have you tested the ICM? The Blk/Yel wire should have battery voltage with the key in ON(II). If not, check whether dash fuse 9 (15A) is blown.
Old 11-05-2009, 12:29 PM   #14
FearTheH
1999 Honda Civic
FearTheH's Avatar
No cel codes, I thought vehicle had to run and post an error twice before it throws a code. Will double check fuse, it did this before and it was a fuse but they all look good thus far. Will triple check them. Also currently have no means of checking voltage other than just shocking myself lol
AIM: Im4Kart6
Old 11-05-2009, 12:31 PM   #15
RonJ@HT
RonJ@HT's Avatar
To test the fuse, a basic inexpensive test light will do. You should register voltage from both test tabs located at the top of the fuse with the key in ON(II).
How do you know the coil is good?
Take the ICM to an auto parts store for testing.
Old 11-05-2009, 12:42 PM   #16
FearTheH
1999 Honda Civic
FearTheH's Avatar
Fuse is definitely good, and icm was removed from my car before when ign fuse was bad, has been hooked up since and works.
AIM: Im4Kart6
Old 11-05-2009, 12:47 PM   #17
RonJ@HT
RonJ@HT's Avatar
Sorry, but I don't understand any of your logic here, including "Fuse is definitely good."
Old 11-05-2009, 12:52 PM   #18
FearTheH
1999 Honda Civic
FearTheH's Avatar
I checked the ign coil fuse again and it is "definitely good". It is not bad. I am trying to find a way to get a test light or something to test if current is getting to dizzy. This is my only car and I'm pretty much Fu*ked right now.
AIM: Im4Kart6
Old 11-05-2009, 12:56 PM   #19
RonJ@HT
RonJ@HT's Avatar
Don't perceive my comments as a personal attack, but I have had people state countless times that their fuses are definitely good but, in the end, their problem was caused by a blown fuse. How do you know that your fuse is definitely good? You need to rule out the simple before considering other possibilities.
Old 11-05-2009, 01:18 PM   #20
FearTheH
1999 Honda Civic
FearTheH's Avatar
Lol I didn't take it as a personal attack... I have checked the ignition coil fuse 4 times, and it is not blown. I also checked under hood fuse IGN1 (40a) and is also not blown.
AIM: Im4Kart6
Old 11-05-2009, 01:22 PM   #21
RonJ@HT
RonJ@HT's Avatar
Verify that power gets to the coil and ICM, have the ICM checked, and test the Yel/Grn wire running between the ICM and ECU for a short or open.
Also crank the engine for about 30 seconds to see whether a distributor sensor code pops up.
Old 11-05-2009, 01:40 PM   #22
FearTheH
1999 Honda Civic
FearTheH's Avatar
After cranking for 30 seconds it threw code P1359 manufacturer control ignition system or misfire
AIM: Im4Kart6
Old 11-05-2009, 01:45 PM   #23
RonJ@HT
RonJ@HT's Avatar
Old 11-05-2009, 02:05 PM   #24
FearTheH
1999 Honda Civic
FearTheH's Avatar
did all of the above and P1359 did not return... checked connections at ECM and distributor, rechecked fuses again and still nothing... this thread is going to quickly move to the For sale forums, i have had it with this car.
AIM: Im4Kart6
Old 11-05-2009, 02:09 PM   #25
RonJ@HT
RonJ@HT's Avatar
Did you try the factory dizzy?
Bookmarks
2000, accord, car, civic, died, honda, integra, odyssey, p0170, p0171, type
