Old 11-03-2009, 04:16 PM   #1
killercamaro
Default 99 civic EX problem. not sure what.
first, ran a search and couldnt find anything specific to this. also, this is my sisters car. its a 99 civic EX thats 100% stock and has 102XXX miles on it.
what happened: she was driving it to work and (according to her) it just completely died in the middle of the road. yes, theres plenty of gas in the tank. we (my dad and i) have checked spark (good), fuel (40 psi), and pretty much everything else we can think of. it will turn over, but wont start. wont even hiccup like it wants to start.
basically, we're out of ideas. anyone here have any experience with a car just dying completely out of the blue?
thanks!
killercamaro is offline Report Post   Reply With Quote
Old 11-03-2009, 04:29 PM   #2
shawn_crx
shawn_crx's Avatar
Default Re: 99 civic EX problem. not sure what.
Did you check for your dizzy module????
it may spark but it will not spark enough to turn the engine. Did you check 1 cyclinder or all 4 for spark? I would take out all the spark plug, check it, and clean/dry it.
also look for loose grounds
shawn_crx is offline Report Post   Reply With Quote
Old 11-03-2009, 04:32 PM   #3
killercamaro
we checked 2 of 4 for spark. both had spark, and we replaced the plugs for good measure. good call on loose grounds, i had overlooked that.
and being that i tend to work on older carbed cars, what is a dizzy module? or is that some joke like blinker fluid? haha.
Old 11-03-2009, 04:32 PM   #4
geneeunit
geneeunit's Avatar
Send a message via AIM to geneeunit
do you have a check engine light?
i do my own stunts..
F/S:http://www.hondamarketplace.com/show...php?p=39225123
geneeunit is offline Report Post   Reply With Quote
Old 11-03-2009, 04:43 PM   #5
killercamaro
no. theres no check engine light on at all. and according to my sister it never came on even when it died initially, which i find a bit odd, but i wasnt there.
Old 11-03-2009, 05:00 PM   #6
shawn_crx
shawn_crx's Avatar
LOL blinker fluid...
sry... dizzy module = ICU ignition module inside your dizzy.
Old 11-03-2009, 05:12 PM   #7
killercamaro
haha. ok, still dont know what a dizzy is, or how something can be inside it. but no, we haven't checked the ICU. mainly for lack of knowing how to check it. so, how does one check the ICU?
Old 11-03-2009, 05:14 PM   #8
shawn_crx
shawn_crx's Avatar
Dizzy= distributor... short name....
here is a link...
http://www.honda-tech.com/showthread...t=dizzy+module
Old 11-03-2009, 05:18 PM   #9
R666_EK
R666_EK's Avatar
The DIZZY = Distributor. Civics have an "internal" coil, and ICU
However, since you say you have spark, I have you thought of the main relay?
My first though was ignition switch, but I noticed you said it doesn't even attempt to start. Pretty much ruling that out.
My assumption would be that "IF" it was infact getting spark, just a small amount, or only on 2 or 3 cylinders, it would still fire, but run extremely rough or only for a second and shut down.
97 DX Coupe W/B18c1. (STOLEN)
04 Yamaha R6 (SOLD)
97 Prelude (New Project)
R666_EK is offline Report Post   Reply With Quote
Old 11-03-2009, 05:29 PM   #10
killercamaro
see i thought the same thing. if its getting spark and fuel, it should at least attempt to run. by main relay, you mean what? like i said, im used to working on mostly carbed cars. i know the technical side of EFI and whatnot, but not the more model-specific terminology. (i usually just say "distributor", for example. haha)
Old 11-03-2009, 05:32 PM   #11
josiah965
1996 Honda Civic
josiah965's Avatar
ive had this problem a couple times. on my civic it was doing that cuz the alternater was goin bad... but i that happened to my geo tracker and it was a loose ground on the starter.
josiah965 is offline Report Post   Reply With Quote
Old 11-03-2009, 05:34 PM   #12
R666_EK
R666_EK's Avatar
The main relay is what basically controls the fuel pump. Tells it what to do.
Check out this site. It will also tell you how to remove and test.
http://techauto.tripod.com/
04 Yamaha R6 (SOLD)
Old 11-03-2009, 08:23 PM   #13
killercamaro
very interesting site. thanks for the link. sadly, the car doesnt really show any of the symptoms from there, save for MAYBE the bad coil symptoms.
the car being outside, inside, hot, cold, heater on/of, and all that from the main relay part make no difference here. and the fuel pump is working as we can both hear it when the key is turned on.
dash is still lit iirc and its not that it can start and stalls later, rather that is just flat wont start at all.
i've been wondering if it may have jumped time on the timing belt, but im not sure how to test for that either.
Old 11-03-2009, 08:40 PM   #14
shawn_crx
shawn_crx's Avatar
Check for timing, line up the Crank TDC with the CAM TDC markings, but you have to take your valve cover off to see the cam TDC.
Could you get your hand on another dizzy?
What happened to mine was, one night it just crank and crank... won't turn on....
I test for spark / fuel / timing/ all there... My bro said it was my module.. so i switch the module and it started like a champ... So to make the story short, you'll get spark but it probably won't be every cycle loop to start the engine, or it's other cyclinder are not firing.
Old 11-03-2009, 09:09 PM   #15
RonJ@HT
RonJ@HT's Avatar
If the CEL doesn't work, then you won't know whether a code is thrown. When you turn the key to ON(II), the CEL should turn on and then off after 2 seconds if no codes are thrown.
What color is spark at the plugs? It should be bright white, not weak orange or blue.
As mentioned, also check whether the timing belt skipped a few teeth.
Don't guess, troubleshoot
RonJ@HT is offline Report Post   Reply With Quote
Old 11-04-2009, 06:04 AM   #16
Deuce1
Listen to RonJ@ht, he knows what he is talking about.
Deuce1 is offline Report Post   Reply With Quote
Old 11-04-2009, 04:51 PM   #17
killercamaro
the CEL does come on for the 2 second start up time, but goes off after that.
spark is not a bright white. i'd say more of a dull white or light blue.
i'd love to check the timing belt for skipping, but how?
Bookmarks
99, blinkers, center, civic, cranks, dead, dont, dx, honda, hondatechcom, jump, panel, start, stolen, tooth, top, wont, work
