#1 | |||||
#2 |
Not enough to worry about IMO. You should check your ride height on both sides and/or scale the car to make sure you are not goofed up on your corner weights.
ITR 98-301 Yes, the #35 "Budman" car. Currently in NASA PTC trim. HOOSIER TIRES ROCK. |
#3 |
Check to see if your subframe is centered. If it has been shifted to the side, it will add negative camber on one side while taking it away from the other. Caster is also affected by the subframe position.
#4 |
besides the subframe would there be any othe reasons why my camber is uneven
#5 | |
Bent suspension parts Incorrect parts installed on only one side (its happened to some people when buying used) Frame damage Uneven ride height (though generally not very noticeable in terms of camber differences) |
#6 |
thats not uneven.
Don't IM me your TECHNICAL question. Start a thread, I'll answer there. FS: Mugen CF-48 13x5.5 -38 Wheels *NIB* FS: 4040 Brake Proportioning Valves |
| Bookmarks |
