> Honda Motorcycles
Old 11-03-2009, 10:20 AM   #1
Toadfart
Toadfart's Avatar
Default 600rr Stock Tire question
I have stock tires on my 600rr with 4k miles on it. The rear has squared off and needs replacement, but the front tires look brand new. What is the replacement tires for the Dunlop Sportmax D218? Can I run a totally different tire in the rear or would it be better if I rode similar tires front and back? Thanks in advance.
Home Theater: PS3 - Pioneer Elite - Rotel 981 Amp - Martin Logan Preface (Mains) / Fresco (Center) - 52XBR6
Bedroom: Lite DAC-AH w/ bypass mod - Little Dot Mkiii Tube - AKG K701/Grado SR80
Toadfart is offline Report Post   Reply With Quote
Old 11-03-2009, 10:23 AM   #2
MSchu
My Name Is Nobody
MSchu's Avatar
Default Re: 600rr Stock Tire question
Yes you can... although I prefer to change out for a set(f/r) myself.
whether or not that set is a matched or marketed set(I might choose to use two different tires), I like changing both
Originally Posted by Targa250R View Post
Bourdais is like the Michael Andretti of F1, except Michael Andretti was already the Michael Andretti of F1
MSchu is offline Report Post   Reply With Quote
Old 11-03-2009, 10:28 AM   #3
typerfit
typerfit's Avatar
Up to you really, if your front tire still looks new and your rear is thrashed then you might want to think about going to a harder compound tire, pilot makes a tire called a 2ct, it is a softer compound on the outside and a harder compound in the center, and always make sure you keep up on tire pressure, if they are not checked a lot it can kill a sportbike tire pretty fast
typerfit is offline Report Post   Reply With Quote
Old 11-03-2009, 10:30 AM   #4
Toadfart
Toadfart's Avatar
I bought the bike off a friend and i believe he mostly did highway riding. So it would be safe to ride the Dunlops in the front and the Pilot Power 2CT in the rear?
Old 11-03-2009, 10:32 AM   #5
Toadfart
Toadfart's Avatar
How difficult is it to change the tires? Or is it worth $90 for a shop to change them for me.
Old 11-03-2009, 10:46 AM   #6
MSchu
My Name Is Nobody
MSchu's Avatar
dismounting and mounting is something you can do at home... what you can not do is balance the tire. You might be able to static balance them, but not high speed balance
Old 11-03-2009, 10:47 AM   #7
MSchu
My Name Is Nobody
MSchu's Avatar
i've mixed makers before... but it's not willy nilly, you need a base of knowledge to do so. best stick to one make and compound for now.
Old 11-03-2009, 10:53 AM   #8
Toadfart
Toadfart's Avatar
I guess I'm gonna get another Dunlop until the front tire wears down some more. Would the Qualifier series be the replacement for the sportmax d218?
Old 11-03-2009, 02:04 PM   #9
CarsAddict
id reccomend getting another dunlop tbh.
Cars Route
CarsAddict is offline Report Post   Reply With Quote
Old 11-03-2009, 02:25 PM   #10
The Hooligan
The Hooligan's Avatar
Location: south jersey, land of chemtrails and landfills
Send a message via AIM to The Hooligan
if the back tire is squared off pretty bad, the front tire is probally squared off too, just rub your finger over it and check it out.
if its not, id just get a cheap replacement, like a shinko.
if the front is squared too, id get a set of bstone bto16s, best tires ive used on the street, and there very affordable.
2007 honda cbr 600rr - the horse
1998 honda cx - the daily
The Hooligan is offline Report Post   Reply With Quote
Old 11-03-2009, 11:22 PM   #11
Toadfart
Toadfart's Avatar
Thanks for the help guys. The front is in really good condition with tons of tread left. I bought a Dunlop Q2 tire for the rear. Thanks again.
Old 11-04-2009, 01:37 AM   #12
rd91sib18c5r
rd91sib18c5r's Avatar
Send a message via AIM to rd91sib18c5r
My f4i had simlar tires, rears seem to wear way faster.
I do alot of freeway also and I went with the dunlop
roadsmart tire on the rear, has dual compound and seems very sticky.
They have a tread simlar to the old metzler me1 I used to run on my vfr.
Very happy with the tire and will put one on the front when needed.
13.1 @105.98mph DD91 si b18c
97 ex coupe 04 cbr600f4i
rd91sib18c5r is offline Report Post   Reply With Quote
Old 11-06-2009, 06:14 AM   #13
WreckedTeggie
WreckedTeggie's Avatar
Send a message via AIM to WreckedTeggie
BE CAREFUL about mixing tires! If one is stickier than the other, you will be in for some trouble.. If the front is a harder compound it's not going to heat up or react the same to temperature or weather conditions.. if you're rear is sticky and the front is not, you're going to push the front and may crash. It's much better to have a stickier front for the street as the rear moving around a little is controllable and save-able.
2000 Audi TT Quattro S line - For sale $7000
07 R6 - Race Prepped and Trackwrapped - For sale: $7000
www.7eighty5.com
WreckedTeggie is offline Report Post   Reply With Quote
Old 11-06-2009, 07:45 AM   #14
Blindstuff
Blindstuff's Avatar
Thats not entirely true IMO, you are limited by the tire that has less traction, the fact that there is a stickier tire on the other end of the bike wont mess up the handling, it the fact that you have a shitty tire.
What I mean to say is that:
The problem is not the fact that the rear is sticky and the front is not IMHO, it just that the front is not sticky.
But I do agree, sliding the rear end of the bike > sliding the front.
On my GS500, that I mainly ride on the street and freeway on dunlop GT501's (sport touring tire), I can get away with going through 2 rears for every front.
05' Subaru Impreza WRX
05' Suzuki GS500 / 93' CBR600 F2 / 00' Honda XR400R
Blindstuff is offline Report Post   Reply With Quote
Old 11-06-2009, 07:59 AM   #15
typerfit
typerfit's Avatar
You always have to remember as well that the rear is your drive tire so obviously it will wear faster unless your gangster and draggin knees, the Q2 is a solid tire toad, imo still a little on the soft side for compound, good luck with the tire,
Oh yeah, be careful for about the first 30 miles or so, new tires are real slick, they are sprayed with cosmolene, (protects tire from drying out during shipping and storage)
Old 11-08-2009, 10:49 PM   #16
Toadfart
Toadfart's Avatar
Thanks guys. I'm hoping they'll both wear at the same rate and i'll end up replacing both front and rear the next time around.
Bookmarks
2003, 2007, 600rr, front, logan, martin, martinlogan, millenia, paradigm, preface, pressure, stocktires, street, tire, tires
