#1 | |||||
#05 ITA Honda Civic EX - 2005 SCCA Cal Club Reg ITA Champion FilterMAG http://www.filtermag.com Advanced Waterjet & Engraving http://www.advancedwj.com |
#2 |
Ridin Dirty in Cali
1993 Honda Civic |
Wow, one new set not lasting a whole weekend?
Either those pads are complete crap..errrrr naw they have to be complete crap. I have never heard of a pad that eats itself in a car only making 130 hp. Do you have any pics? |
#3 |
What caliper are you using in your setup. Its really a bad engineering design that the piston falls of the seal before the pad is to the backing plate. Either that or you are using discs that are way too thin.
On the subject of the pads not lasting, that seems excessive and hard to belive actually, but if that's the wear rates you have been getting with that pad then you're need to see what temps are the discs getting to. I know that the R4's last more than that so there must be an explanation. If you're looking for a pad to last the whole season, I think Performance Friction and Pagid are really the only good choices as they have the best endurance compounds in the pro field.
*SPECIAL* 2007+ FD2 Type R LSD and FD - $1000 - Includes Parts, install, and shipping Transmission Rebuild - $450 - Includes new Syncros and S&H |
#4 |
Suspetise...
How old are the calipers? Is there a chance the piston was sticking and causing the pad to be in constant contact with the rotor?
#5 |
Switch to cobalt. try the XR3. On my car i was running XR2 which was hevier.
Edo
92 Integra LS #78 04 & 05 & 06 & 08 WCHC H4 Champion : 07 H2 Champion HONDATA - HASPORT - MOTUL Oil - 5ZIGEN - JE Pistons - ASR Swaybars EdoMoto.com TeamMfactory |
#6 |
The calipers are "new" OEM remanufactured ones from Pep Boys. This exact same thing (destroyed new pads) happened at the beginning of September, so they are 2 months old. The rotors are the same one's everyone else is using: Valuecraft 10.2" blanks from Autozone, and these were brand new, too, bought at the same time as the calipers.
I assumed back in September when it happened, it had something to do with the fact that I was using used rotors that had been turned (which I will never do again), and some of my brake ducting had collapsed, so everything was running way too hot. This time, like I said, everything except the hard brake plumbing and brake booster had been replaced with new or remanufactured replacements. It appears that when it gets down to the backing plate on the rotor, it heats up so much it bends the plate back around the piston, and that allows enough clearance for the piston to cock in the cylinder, allowing the fluid to escape. There were flames (again). A Spec 944 racer at the track told me he heard that a bad batch of pads came out of Porterfield at one time. I wonder if not enough Honda guys use them to have gotten through the bad batch. I plan on calling them and seeing what kind of information they have. I was hoping to get some info from smart people here before calling them. Either way, I think I am planning on switching pads anyways. Several very experienced people have suggested trying the Cobalt XR3's.
#7 |
Moderator
Get a REAL PAD....R4's aren't exactly a race pad. they were the first aggressive pad i used i my street car back in 2000...
First: HPDE Sponsored RACER 001 |
#8 | |
What does the left front pad look like? That might isolate the problem better...
2003 SSM EP3 Quote:
#9 |
With everything the Formula said, I really think it's time for a different pad.
The R4 really isn't a true race pad, IMO. It's only a small step above the R4S. I've used the R4 on the rear of my car (1997 Jetta 2700lb) and they've lasted forever. There isn't much rear brake bias on my car, so using a stronger pad helped me keep the rear-end in check. This was my experience when moving from the R4S in the rear. You should look into the Hawk HT line, specifically the HT10 to start with. Make sure to do a proper bed-in and test them out. Testing (and wrecking, unfortunately) is part of racing. The more seat time you get, the faster you should be getting, and certain parts you can only push so fast. |
#10 |
If you want some real race pads that last, look no further than Pagid RS29 Yellows endurance pads. Expensive and you get what you pay for. I am running those and Hawk DTC-60's, which are also excellent. I have never run R4's, so no comment. I have run XP8's, XP10's and XP12's. If you want pads that brake well and wear quickly, buy those from Carbotech. No more of those for me. Never run pads down to the backing plate. That overheats the fluid due to heat from the rotor getting through the backing plate to the piston and then to the fluid. And as you found, can lead to catastrophic results. Plus pad material will overheat and start to wear very quickly when it gets to thin.
'Common sense is the most fairly distributed thing in the world, for each one thinks he is so well-endowed with it that even those who are hardest to satisfy in all other matters are not in the habit of desiring more of it than they already have.' Rene Descartes |
#11 | |
I've run and tested pretty much everything that is available on the market over the years and when it comes to these things, you get what you pay for. That being said, investing in a pro product with world renowned reputation like Pagid, Performance Friction, Carbone Lorraine, or even Ferodo will get you in awe, and whishing you had never spent money on the club level product from the other companies just to save a few bucks. You also need to know what you want from your brakes, high initial bite is not always a good thing, torque rise, or flat torque, release, and modulation, compressiveness, and consistency with temp are just a few of the things you should look for when talking to a brake company's engineer to get help in deciding what best suits you. If I were you I would call all of those companies and talk to them, you will learn more in 5 minutes of convo than reading bolox on the forums. Pagid - 239 540 1729 Performance Friction USA - 1800-521-8874 Carbone Lorraine USA - 864 834 7712 Ferodo/Essex - 704-824-6030
#12 |
I have been using the Porterfield R4 quite a bit. I have been getting several race weekends out of them. Usually 3 full weekends and test days!!!
I am using the porterfield pad as it has a lower grip than some others and it helps me adjust ssome bias. If you dont mind a pad thats a little grippier, but seems to last FOREVER, go with the Willwood "C" pad. Its cheap too !!! I think you can get a set from Summit for around 75 bucks.
2009 H2 National Champion - Because of the people who support me - Afterhours Automotive , Mfactory, Church Automotive Testing, Synchrotech Transmissions, Portflow cylinder heads, Hasport. AND MY HIGHLY ANNOYED DRIVING COACHES |
#13 |
$75 should be the cost of the brake fluid, not the pads!
#14 | |
Suspetise...
#15 |
lol I was trying to make a point. Although a good set of pads for 200-250 is not being baller, its trying to get a leg up on the competition.
#16 |
H-T Order of Merit
I had a set of Porterfield R4-S front pads on my GS-R in which I had a similar experience at the racetrack, i.e. the pads got hot and the metal backing plate "folded" around the piston. There was still a reasonable thickness of friction material on the pads at the time.
#17 | |
On that note, I had no idea that the R4's were not considered a "real" race pad. Kind of misleading when there's a picture of a Ferrari F1 car on the website, and Andy Porterfield drives an ex-Trans-Am and current GT-1 Camaro with his own pads. Of course, owning the company I'm sure has the perks of being able to change pads every session if he so chooses. Porterfield sells Hawk Blues, too. I'm sure I can swap the new set of R4's for them, but would that be a lateral move, or a step up in durability? Otherwise, I'm leaning towards a refund, and trying either the Cobalt XR3's, Pagid yellows, or Ferodo DS3000s. I'll try to get some pics of everything in the next couple of days. What site are you guys using as a pic hosting server, since we-todd isn't around anymore?
#18 |
Personally, I wouldn't go with the Hawk Blues. Yes, the pad is proven on the track, but they dust like crazy and once it bakes onto your wheels it doesn't come off.
Hawk HT series, or any of the ones you mentioned above would be fine. As I said before, there is alot of testing needed in racing, and finding what works best for your setup and how you drive isn't always going to be easy. |
#19 |
thats part of the beauty of racing these hondas , you dont necessarily have to spend a ton of money . granted there is a time to spend money .
I have won many races on the 75 $ C pad. Im not talking out of my ass here. It is basically the same compound we were running in H4 cars ( made by Raysbestos ) I dont think they make it for a stock caliper though. the XR-2 pads are great too.
#20 |
I ran the Porterfield R4S for 1 weekend, then the R4 for 1 weekend...I then moved to an early version of the Cobalt XR-3(Spec VR). I'm now running the XR-3 on the front of my H2 car, though I almost purchased the XR-2's instead, which have a slightly higher initial bite.
2001 Type-R 1994 Civic B18B H2 #23 HyTech Exhaust DynoSpot Racing HASport Motor MountsWest Coast Honda Challenge |
#21 | ||
2003 SSM EP3 Quote:
#22 | ||
H-T Order of Merit
The R4 may not be the most aggressive or the longest-lasting compound, but it's a track pad, not a street pad. Porterfield also makes a longer-lasting track pad, designed for endurance racing, called the R-4E. Quote:
I've used both. The R4 is a track pad, offering better grip and better resistance to heat than the R4S. It also squeals and needs to be warmed up to be effective, so it's not very suitable for street use. The R4S is really more of a street pad that can also be used for occasional light track duty; I wouldn't recommend them for a track-only car or in competition. (And I much prefer the Hawk HP Plus if you're looking for a pad that can be used on both the street and the track.) |
#23 |
I used the R4S for my first ever track day, they lasted the one event and I changed them afterward....not a track pad. The R4 lasted the next weekend, I wasn't too impressed with them at all. I also tried a few other pads, but it's been a while. I know that I eventually called up Cobalt and had a discussion on what I was driving(whp/weight/speeds) and my driving/braking style and we chose a pad that should work based upon my specifics, and it turned out that it worked well for me.
Austin
#24 | |
First, I tell you right now that you wont get a refund on a consumable race part. I've been at this and buying race parts since the early 90's and never have I heard of a refund after you used it. Replacements, yes in terms of warranty or good customer service but refunds forget it. Second, with the pad compounds that you mentioned I can see that you still need to figure out what's best for what you want. The cobalt being a medium bite & torque, the Pagid being medium/endurance, and then the Ferodo being high bite and high torque but not lasting much at all, are all different with different characteristics. Out of all of those though, the Ferodo is the best in terms of modulation, release, and torque with good cold bite, but the Pagid will outlast all of them. What exactly do you want from the next pad you're going to get? High/med/low initial bite High/med/low torque Cold bite, or ok if not? Longevity of the pad important? Low abrasion to the disc important? Release characteristics important - fast or slow Modulation important with high lockup threshold Thermal consistency Compressibility Torque rise or flat? All of these are important factors that you should be aware when chosing a pad. A lot of people really dont have a clue of whats going on in the friction event.
#25 |
First you need to know how hot your discs are getting on track. You then tell the pad manufacturer that temperature and have them help in pad selection. If your discs are running hotter than suitable for the pad, the pads will wear very quickly or not grip or both. Considering the cost of good pads, temperature paints are really cheap. Here is a link to AP Racing (temp paint is available from a bunch of sources). Read their text about temps.
http://www.apracing.com/info/info.as...emperatures_44 You can buy some Tempilaq brand individual ones here: http://www.pegasusautoracing.com/pro...p?Product=3161 The AP Racing kit has 3 temperature paints and Tempilaq closest match 1. Green 430 c or 806F, Tempilaq 3161-850 (850F) 2. Orange 560C or 1040F, Tempilaq 3161-1000 (1000F) 3. Red 610C or 1130F, Tempilaq 3161-1150 (1150F) Also get thinner.
| Bookmarks |
| Tags |
| bedding, merit, national, porterfield, practice, qualifying, r4s, scholarship, test |
