Nrg Techs sfwd Camshafts
Old 11-02-2009, 08:13 PM
sgnlab's Avatar
Default Nrg Techs sfwd Camshafts
I purchased a set of Millers SFWD cams for my setup. I was excited to see what the car would make as I finished up my setup Chris said "Keep them @ zero and see what they will do" I tuned the car to 32psi and the car made 777whp @ 458ft/lbs or torque. I then found out I had a boost leak that was a good size. I will test them out more very soon! Chris I want to thank you for an awesome product.
Here is my dyno sheet.
Old 11-02-2009, 08:37 PM
mrbh22's Avatar
Default Re: Nrg Techs sfwd Camshafts
any previous ##
Old 11-02-2009, 09:08 PM
Blueberry1320's Avatar
Whas ur set up ??
Old 11-02-2009, 09:11 PM
jdm inc's Avatar
Very nice!
Old 11-02-2009, 09:58 PM
V-SPEC 1's Avatar
Are those just cams or the whole rocker roller setup w/ cams. Nice numbers by the way.
Old 11-02-2009, 10:05 PM
ProjectBoosted's Avatar
what cams are they? the ones with the .475 lift? and how much do they run? please let me know thanks
Old 11-02-2009, 10:10 PM
tepid1's Avatar
.505 lift and non roller rocker cams.
This was from Steve's other posts....
Old 11-02-2009, 11:01 PM
Zer0_SpeedWorks's Avatar
how much are these?
can you use it on a street car/daily driver?
very awesome results to think you have a boost leak issue.
you cant compare these with pro1 right?lol
Old 11-03-2009, 03:31 AM
XXXRacing's Avatar
I heard that they were blox SOHC nitrous cams that he had modified...
jk
Old 11-03-2009, 04:47 AM
fmfkid250's Avatar
So it should go 8's now right?
Old 11-03-2009, 04:56 AM
1992Si's Avatar
jk
Hey, no telling other peoples secret's. lol
Old 11-03-2009, 05:06 AM
Boosted_B_Series's Avatar
I'm curious as to were I can get some more info on these as well.
Old 11-03-2009, 05:11 AM
sgnlab's Avatar
My setup is
83mm Benson sleeved gsr with ls crank and rods
PNP head w/+1mm valves
s372 w/standard cover
the cams are 505 lift and they are regular cams no rollers
Chris Miller @ Nrgtechparts.com has these in stock and he is very helpful and I think these cams are the best I have ever had. I do not have any comparissons for my setup vs. another type of cam. But I have tuned plenty of cars with pro 1's, crower n/a cams, ctr cams, I think just the way this car performed is amazing.
p.s. the boost leak was coming from my factory map sensor port on my bdl throttle body to give you an idea peak boost was 32psi but ended up @ about 27psi @ redline. These cams carried such a great torque & power curve.
Old 11-03-2009, 05:59 AM
b00sted EK's Avatar
Originally Posted by sgnlab
My setup is
nice #'s, but why it is so laggy? boost leak affecting spool? what turbo manifold?
Old 11-03-2009, 06:02 AM
sgnlab's Avatar
The leak was deffinatly not halping spool time. I have a peakboost top mount which I will be switching over this winter and getting a full race.
King of the One Liners
2fastGSR's Avatar
Miller is taking over the world . . .
Old 11-03-2009, 06:06 AM
QUICK8CIVIC's Avatar
The torque curve is amazing!
Old 11-03-2009, 06:20 AM
nonvtecallmotor's Avatar
Billet?
Old 11-03-2009, 07:47 AM
E-Town4229's Avatar
MagiCamz! lol sounds good. is this going to hit the track soon?
-Roger
Old 11-03-2009, 08:00 AM
1992Si's Avatar
Hint, miller.
another hint, www.NRGTechracing.com
Old 11-03-2009, 08:01 AM
narfdanarf's Avatar
Did you do V2V with these? I am curious because I have .5mm o/s valves in my head and with the pro1's I need 2 degrees of separation at least which is equal to about .034" It would be well worth it to me to buy a set of cams I can run straight up and not half to worry about v2v.
Old 11-03-2009, 08:23 AM
sgnlab's Avatar
I did not at all! He told me drop them in and there was nothing to worry about he was right!
Old 11-03-2009, 09:11 AM
h22 civic's Avatar
Nice. What brand cams? Or is it Top secret wich I understand
Old 11-03-2009, 09:27 AM
sgnlab's Avatar
They are a special NRG Tech Racing cam shafts.
Hit Miller up he will fill you in on the details!
Old 11-03-2009, 09:40 AM
V-SPEC 1's Avatar
Can Miller chime in on this special cams of his? that would be great.
Quick Reply: Nrg Techs sfwd Camshafts
