> Forced Induction
Old 11-04-2009, 05:27 AM   #26
slow96lude
slow96lude's Avatar
Default Re: got a few questions, not sure its this is normal or not!
I would get a different BOV. They are way to inexpensive to be f*&kin around with them. When you say its fluttering 0-4 do you mean while your accelerating or when you let of the gas?
finally got the ls swap of my nightmares
slow96lude is offline Report Post   Reply With Quote
Old 11-04-2009, 07:09 AM   #27
NonovUrbizniz
NonovUrbizniz's Avatar
Originally Posted by NonovUrbizniz View Post
I'd get a decent BOV... ebay one's are known to suck and kill turbo's.
Eh hem...
do you want to save 150-200 bucks now so you can cost yourself a new turbo in a couple weeks/months/already?
For Sale Thread - Turbo Parts - D16 Parts - Random Stuff
http://www.hondamarketplace.com/show...4#post40554064
NonovUrbizniz is offline Report Post   Reply With Quote
Old 11-04-2009, 08:44 AM   #28
roadsqueegy95
roadsqueegy95's Avatar
slow96lude it does it when i accelerate. if i take the piston outta the bov until i get a new bov and boost just at wastegate spring (4 psi) will that be ok?
Get your honda-tech.com decals....on sale now!!
http://www.honda-tech.com/showthread.php?t=2573880
roadsqueegy95 is offline Report Post   Reply With Quote
Old 11-04-2009, 09:05 AM   #29
coneheadsracing
coneheadsracing's Avatar
Make sure your lines are hooked up right with the MBC, that can cause issues with boost creep, fluttering. Also, hook up the bov to it's own line off the intake manifold, and see if that helps.
My wife hates Honda-tech......
coneheadsracing is offline Report Post   Reply With Quote
Old 11-04-2009, 11:14 AM   #30
1DayIllBFast
1996 Honda Civic
1DayIllBFast's Avatar
^^ i had my BOV teed in to my pcv on the intake mani and i was getting compressor surge but once i gave my bov its own source off the intake mani it was good to go.
so to the OP. i would take your BOV line off the vacuum block and give it a dedicated source from your intake mani and try that instead of cutting it up.
EJ8 SQUAD #557
1DayIllBFast is offline Report Post   Reply With Quote
Old 11-04-2009, 12:24 PM   #31
roadsqueegy95
ok ill give that a try tonight / tomarrow. should i just drill and tap a new hole on the intake mani? ive got the boost turned down to w.g spring now, which is 4 psi. and i try to stay outta boost as much as possiable. figure that wont kill the turbo as fast at 10 psi.
Old 11-04-2009, 08:48 PM   #32
slow96lude
slow96lude's Avatar
there is something more than the bov wrong here. It shouldnt be fluttering from 0-4 psi while accelerating. There are two other possible scenerios here. One the wastegate is toast and keeps opening up. two you have a boost leak in your piping.. the only other problem would be the bov not closing right.
Old 11-04-2009, 08:48 PM   #33
slow96lude
slow96lude's Avatar
what BOV flange is on your piping or what bov do you have now
Old 11-05-2009, 09:25 AM   #34
roadsqueegy95
right now its a cheap ebay one, ima goin to upgrade over the winter, just trying to make sure it doesnt blow till then! i semi did a fast check for boost leaks, when the gauge flutters i hear a fluttering from the engine bay to
Old 11-06-2009, 01:39 PM   #35
slow96lude
slow96lude's Avatar
I thought of another thing that could be possible. The vacumm reference isnt any good. I.E. the clamps or something on the vac block arent tight.
Old 11-06-2009, 02:18 PM   #36
roadsqueegy95
ya i was thinking about that today at work. ima check and retighten everything tonight and see what happens
Bookmarks
2001, accord, acura, bov, decal, flutter, honda, hondatech, psi, sound, spring
