#1 | |||||
Get your honda-tech.com decals....on sale now!! http://www.honda-tech.com/showthread.php?t=2573880 |
#2 |
I'd get a decent BOV... ebay one's are known to suck and kill turbo's.
For Sale Thread - Turbo Parts - D16 Parts - Random Stuff http://www.hondamarketplace.com/show...4#post40554064 |
#3 |
ya ive been thinking of upgrading, but i figured it there was anything else to check / replace first id to that before i started throwing part at it your know?
#4 |
is this when it is part throttle only?
Sleeved 2.0L HX52 Passenger turbo goodies equipped 10.82@124mph coasting at 900ft 703hp 459whp 35psi @ 8500rpm |
#5 |
ive noticed the fluttering sound anytime i left off the throttle, and the boost gauge flutter usually happens when im in say 4th and instead of down shifting to 3rd i gas it and it usually flutters between 0-4psi.
#6 |
getting off work bump!
#7 |
I dont know what kind of bov you have but you can try to adjust it.
CBR1000RR 95 Talon AWD 97 Eclipse GST |
#8 | |
Lighten up you BOV so it barely stays open with the throttle shut pulling vac on it. That way when just a tiny bit of boost hits the piston, it blows open.
finally got the ls swap of my nightmares |
#9 |
right now, its closed at idle, but its takes a little force to open it so it dumps. so i should adjust it a little more so it ill be almost open (dumping) at idle?
#10 | |
definatley ment to say barely stays closed. SORRY one to many landsharks tonight. just lighten it up to where the it is open at idle, then take it back down just a notch. Personally I just leave mine as light as possible, even open at idle. The only problem is, that your getting unfiltered air through there untill you press the gas and the BOV shuts. I get an extremely loud Blow off, by the way.
#11 |
ok im following you now! so adjust it so that its just a little open at idle right? not the whole way
#12 |
its really up to you. but it sounds like its just a little too tight. In my case my engine just sucks in a little unfiltered air, rather than destroying my turbo
#13 |
well i checked mine when i got home, and the top of the piston is a little bit above the opening it dumps out of, so ima mess around with it a little tomarrow, i can always add shims if i get it to loss.
#14 |
try hitting the throttle really fast and then clsing it really fast while its at idle. This will tell you how fast the BOV opens. If it is really slow, I would replace it with something a little better. I used to get a lot of Compressor surge when I had my ebay knockoff hks seq
#15 |
Does it happen under full boost?? Or is it just a small amount. I had the same thing and it was just the sound of the wastegate since it was only a small amount of boost.
Check all your vacuum lines to the BOV.
Before you criticize someone, walk a mile in their shoes. That way when you criticize them, your a mile away and you have their shoes. |
#16 |
slow96lude, ima go out and mess around with it now, ill give that a shot and see what happens,
psychoteen101 it happens pretty much any boost level
#17 |
well i adjusted the bov a little more, not quite open at idle, now when i shift i get a flutter on the turbo side of engine bay and right after it starts i get what sounds like a belt squeeling sound outta the bov. sorry thats the best way i can word it. guess maybe the bov still needs to be made weaker? the bov does flutter anymore, just kinda squeels!
#18 |
try making it as weak as you can, or take the adjuster out completely and give it a few good revs. Sounds like the BOV is stuck, might also try unbolting the top and check the diaphram and piston/valve. I have a cheap BOV and it happened to me
#19 |
ok, i was gonna try it again after work tonight, mine is the kind with washers in it
and i dont think its got a diaphram just the piston so ill take all the washers out, hell if i doesnt get any better ill just start cutting the spring a little by little, i know its not the right way, but if it works till i part it for the winter ill be happy. im confused on my the piston rattles at idle in the bov. i know its the piston cuz if i put my finger on it the rattling stops! if im following you right, at idle the bov should still semi work then? sorry for noob questions
#20 |
why use a bad ebay bov when you can get a cheapo 1st gen dsm for cheap and your set?
#21 |
cuz its what i had at the time, and after getting it tuned and such im left being broke for the time being. im planning on buying a good bov during winter when i park it and can save some money up, just tryin to get it to work for the time being
#22 |
I would think that you have the bov set right, by now. I would try looking at the wastegate. Mine flutters a lot, where do you have its vaccum referenced from?
#23 |
ima try to adjust it one more time tonight / tomarrow. its almost open at idle but still not. and all my lines are going to a vaccum mani that is T'd into the brake booster
im not sure if its just my dumptube fluttering or not, cuz something ALWAYS flutters, but every once in a while when im part throttle a gear to high or so, my boost gauge needle flutters to, thats y im thinking compressor surge?
Get your honda-tech.com decals....on sale now!! http://www.honda-tech.com/showthread.php?t=2573880 Last edited by roadsqueegy95; 11-03-2009 at 06:30 PM. |
#24 |
Try removing all the washers and cutting off a coil on the spring. And yes that's compressor surge. Get it fixed soon cause I've heard compressor surge can mess up a turbo.
#25 |
ya i think i got a few washers left, but if that didnt help im cut a lil off at a time. i know thats not the right way to do it, but like i said, as long as i can get it to work until winter ill be happy.
on another note, i have my hallman mbc connected to the side port on my wastegate, with the top port open, that correct? its a turbo xs (not the ebay one) wastegate im noticing the fluttering sound anytime im around 0 boost and above, and ive noticed the boost gauge flutter at 0 boost just a little bit, maybe a pound or two, but when i get around 3-4 psi, it will flutter from 0-4 psi until i throttle down!
Get your honda-tech.com decals....on sale now!! http://www.honda-tech.com/showthread.php?t=2573880 Last edited by roadsqueegy95; 11-03-2009 at 09:15 PM. |
| Bookmarks |
| Tags |
| 2001, accord, acura, bov, decal, flutter, honda, hondatech, psi, sound, spring |
