Picking up where they left off. 56K warned. K20 EG turbo!!
Old 10-31-2009, 04:03 PM
Psychoteen101's Avatar
Default Picking up where they left off. 56K warned. K20 EG turbo!!
Whats up honda-tech. I guess ill start it off with a little backround.
Car is a 93 civic CX.
Engine:
-K20z1- Type S
-Darton Sleeves-
-9:1 Je Piston w/ Crowler Rods
-Ferrera Valves/ Retianers
-Golden Eagle head Studs
-Has Sport engine mounts
-Hondata K-pro Ecu
-Hondata Intake Manifold Gasket
-Kong Intake manifold
-Kong Top Mount Turbo Manifold
-Kong I/c Pipping
-Kong Down pipe
-Kong Blow down Tube
-Kong Stainless Stee Upperl radiator hoses- upper/lower
-Kong IAC relocator adapter
-Kong Triangle Catch Can
-Kong Battery Trey
-Kong Engine Harness
-Precision Turob Sc61 Billet wheel
-Precision 1000 cc injectors
-Precision 700 hp i/c
-Tial 44mm wastgate
-Tial BOV
-255 Walbro Fuel pump
-New OEM Timing Belt
-New OEM Water pump
-New OEM chain guides
-New Oem Chain tensioner
-Oil Pan, Brand new threads welded on oil return line for turbo
-C/R radiator with fan for RSX
-Thermal Exhaust stainless steel 3” piping
-Ceramic coated turbo housing/down pipe/turbo manifold/Blow down tube
Drivetrain:
-Rsx base model 5 speed trans
-All new Syncros
-Aluminum Flywheel Compettion clutch
-Stage 4 Competition clutch
-Gator axles- rated at 500 whp
-Quaife LSD
-Karcept shifter Bracket
-Rsx shifter cables/shifter box
Suspension:
-Tein Flex coilovers w/ EDFC
-Kong traction bar
-Function 7 camber kits
Brakes
-12.2 Wildwood Calipers with s/s brake lines
-Rear disc conversion from 00 si
-rear ep3 4x100 10.2 rotors with rsx calipers
-hawk street pads
-4040 GSR proportion valve
-New Rear Rotors
Wheels/Tires:
-16x7 Drag slipstream look-a-likes
-Falken Azenis 215/45R16
-Burnt Chrome Lug nuts
Body:
-Carbon fiber Wing (prvious owner states it was a spoon!)
-Vis carbon Trunk
-OEM Mud Guards
-Oem front bumper
-Vision carbon mirrors
-Momo Monte Carolo 320mm wheel
-NRG Gold Hub/quick release
-Oem Honda Jdm Arm rest (Wrapped in red tweed)
-Oem Honda Jdm center counsol
-Driverside/Passenger Side Door panels Wrapped in red tweed(similar to type R set up)
-Tein Hood Damper
-OEM TYPE R DC5 Valve Cover
-Spoon rear lower tie bar
-Itr shift boot- red stitching
-OEM Stanley Corners- New
-JDM EG6 Headlights
-ARC Titan shift ****
Unfortunately i cannot say ive built this car to the point you see it at now, but i dont intend to leave it the same as when i bought it. Many of you have probably seen it on here before, there are numerous build threads dedicated to its construction. Now im picking up where the previous owner left off so another buid thread is in order!
Here's the car when i bought it.
First thing first, the car when i purchased it was untuned because the motor was still on the break in cycle. So i took it to the 1,500 mile mark then did an oil change. While in there i checked the oil for any metal shavings, checked the pan for shavings with a magnet, looked inside with a bore scope, and cut the oil filter, took it apart and inspected its internals. Everything was legit, oil pressure was still phenominal, so it was time to tune.
Other than some minor issues on the dyno, it was a straight tune with no major problems.
Tuner - King Motorsports of New Berlin, WI
Numbers---
385WHP 285Ft lbs torque at 13psi - Wastegate spring
460WHP 340Ft lbs torque at 18psi
570WHP 440Ft lbs torque at 28psi --- 112 octane race gas
Much more to come so enjoy!!!
Old 10-31-2009, 04:22 PM
DrZFiNeSt's Avatar
Default Re: Picking up where they left off. 56K warned. K20 EG turbo!!
Nice numbers.Hopefully you can pickup where the previous owner left off
Old 10-31-2009, 07:01 PM
Flattery Will Get You Everywhere
markspan6243's Avatar
bought not built
nice car though
Old 10-31-2009, 07:13 PM
BoostinEJ1's Avatar
^ Moron.
Saw the previous owner trying to trade this for just about anything on the board seemed like he really wanted to get rid of it which came off kind of shady. Glad to see you had no real problems and the car put down nice numbers. Whats in store for it from here on out?
Old 10-31-2009, 07:28 PM
B16Drag's Avatar
Looking good. Clean up the engine bay a bit.
Old 10-31-2009, 08:44 PM
Lord of the idiots
[ej]Jonathan's Avatar
i hope you dont have any problems man. im always edgy when it comes to buying someones modded car
Old 10-31-2009, 09:10 PM
z6htch's Avatar
Originally Posted by markspan6243@yahoo.com
bought not built
nice car though
Yeah he bought it, now he is going to build it further.. D bag.
Old 10-31-2009, 11:41 PM
Jdmsoles's Avatar
Location: Dodgin Cops all Round Ana-Crime to Orange & Sd
agreeed ^^ still has a good amount of work ahead of him, so its all good op, in for more updates.
Old 11-01-2009, 07:19 AM
im not saying this guy is a dbag for buying it built, i just think that building a car is better than buying it, but ya he does have alot of work ahead of him. i wish him the best of luck working on it.
Old 11-01-2009, 08:23 AM
I understand where your coming from with the bought not built thing, but you gotta take it from my point of view. Im 20 years old, work in a restaurant and go to school full time. Ive built numerous cars since i was 17, money was tight and it still is. I recently fully built a D16 in my old EG hatch. It cost me about 4K to build the motor, not to mention other upgrades i had to do. It spun a rod bearing maybe 5 minutes off the dyno, due to tight clearances on rod bearing #4. I didnt want to build another motor and waste a ton of money. I found this car for a great price, so i sold my hatch, my turbo kit, what was salavageable from the motor, then got a loan for the rest and picked this hatch up. It was too good to pass up, so yes its bought, but i intend to take it much farther, which is better than just leaving it how i found it.
Near future plans
Gonna do a custom cage, havent really decided on the design yet, ive been checking out some other cages and want to make some designs around those. It will most likely be a 6 point.
Working on down grading the brakes. I love the big brake kit, but unfortunately i can only run a 16" wheel and i want to be able to run a beefy slick at the track, so i need brakes that will allow a 13 or 14 drag wheel.
Brake line tuck for sure. Not just for the look, but if you take a look in the pics of the engine bay you can see how much heat is produced by the manifold, its gets to the point where it boils the fluid in the lines and i get brake fade.
I will atleast be repainting the front and rear bumper, then i will buff the whole car and pick out some of the minor dents. If i dont like how it turns out, i will repaint the whole car.
Once the brakes are finished, i will be getting new wheels. I personally dont like the look of a 16"+ wheel on an EG, they look goofy in most cases.
Will be installing an ECU kill switch, for anti theft use, as well as a turbo time with anti theft on it.
Also will be workin on doing a better job on a wire tuck, mostly inside the car because all the wiring takin from under the hood is pretty much cluster f*cked on the passenger side.
Ofcourse these are just plans in the next couple months. So ive got my work cut out for me atleast through winter.
Old 11-01-2009, 08:35 AM
Unfortunately i had a little bit of bad luck right off the bat, but it could have been worse.
Off the dyno, even a little before hand, i noticed the car would smoke a bit at idle or after a pull in boost. At first it was almost un-noticeable, but in the coming days it got much worse. Smelled like burning oil. I immediately checked my oil level, it was fine, havent lost a drop. This exact same thing happened on my previous car, it was a blown turbo seal. Sure enough when the turbo got warmed up, i checked it for shaft play. Pretty obvious, the play was so bad, the turbine was just about grinding on the compressor housing. So i pulled it off and sent it to precision.
Theyve had it for more than 2 weeks. Still havent taken it apart, so i dont know what caused it or how bad the damage is. Supposably they are gonna give me a call monday or tuesday and tell me what caused it, the turbo maybe had 2,000 miles on it. Im hoping they will warranty it!
Old 11-01-2009, 09:09 AM
1.5Slowmatic's Avatar
Originally Posted by BoostinEJ1
^ Moron.
guy needed money to bring his fiance over to the states pretty sure
car is SICK. cant wait to see where you take it
Old 11-01-2009, 09:16 AM
SouLaQuaRiuS's Avatar
good stuff
Old 11-01-2009, 09:27 AM
DSRxCandyh2bEG's Avatar
Wow, that is a monster of a setup. I aggree with the person above about building the car and not buying it but it sounds like you got a hell of a deal on a car that has a lot of nice parts on it.
Are you planning on upgrading the fuel pump setup at all??
Old 11-01-2009, 09:55 AM
GetEfdupEH's Avatar
bought or built whatever, hope you work out the kinks...
Old 11-01-2009, 08:36 PM
Jman8108's Avatar
It's cool to build a car from the ground up but makes much more sense to buy it when someone else has already taken the initial hit of the swap/build/boost whatever. Good luck man. EG hatches are best in white.
Old 11-01-2009, 08:40 PM
I doubt ill upgrade the fuel system anytime soon. Tuner had no problems with the 255 pump and i dont plan to up the boost so i dont really think its worth the money at this point in time. Once i get used to it on slicks, im sure ill have a solid 10 second hatch no problem, which is all i really want. I love K pro because i can set numerous duty cycles instantly to change my boost level through the hondata boost controller. So on the street i run the 13psi level, 365whp is plenty to mess around with. Ill be pickin up some drag radials this week with my new wheels for street use.
Old 11-02-2009, 04:23 AM
oh btw, i think that "kong" isnt an actual brand, but they custom made alot of that parts. correct me if im wrong.
Old 11-02-2009, 04:57 AM
That manifold itself is 1 of 2 made. The previous owner, his dad, and brother do there own custom fabrication. It's there own design. There also other one off pieces on the car with the Kong logo on them.
Old 11-02-2009, 03:19 PM
rames_cd5's Avatar
ok... not going to bad mouth precision turbos.. my buddy had a billet 70mm on his Buick. had it on the car about 1000 miles and started coming apart, sent bearings into his front cover and killed his front cam bearings and whipped his oil pump.. and they have had his for 5 weeks now.. hes getting inpatient.. again.. not bad mouthing.. just bad luck maybe.
Old 11-02-2009, 03:26 PM
gotcha
Old 11-03-2009, 07:13 AM
Well, precision still has mine, its been about 3 weeks. I called them about a week ago and they said they should be able to take mine apart by today. If i dont get a call by tomorrow, ill be calling them. Persistence pays off eventually.
UPDATE>
Will be taking care of removing the big brakes and installing the GSR brakes to make room for some slicks. I picked up the last of the parts i need. Pics will be up this evening.
Old 11-03-2009, 11:59 AM
Time for Brakes.
Out with the old and in with the new...
GSR rotors
GSR performance pads
GSR brake hoses
GSR caliper brackets
GSR calipers
Old 11-03-2009, 12:14 PM
The Difference is obvious ^^^
Unfortunately, i didnt know that with the GSR brake conversion, i needed to replace my OEM spindles with GSR spindles.
So i picked up a set from a local performance shop. One had a bad ball joint, so i switched it with a good one from the old spindle.
Old 11-03-2009, 01:35 PM
94-integra-ls's Avatar
wtf would you take those old brakes off
Quick Reply: Picking up where they left off. 56K warned. K20 EG turbo!!
