> Acura TSX
Old 10-27-2009, 11:51 AM   #1
EJ8VTEC
EJ8VTEC's Avatar
Default Rear Suspension
I know we dont have very many followers in this forum but im giving it a try...
To replace the rear suspension: Bottom back seat needs to come out, then the vertical pieces & i should have access to the upper part of the shock? Is that it, or does the whole rear dash need to be removed? Anything else i need to know? I did the front already and seemed very similar to my civic...
Sorry im having a little trouble finding answers on this...
Daily Driver: 04 NBP CL9 6MT/Navi - CL9 Squad #001
Sold: 00 CGP EJ8 - Retired EJ8 Squad #121
Go Lakers!
EJ8VTEC is offline Report Post   Reply With Quote
Old 10-27-2009, 12:29 PM   #2
D_TY3
D_TY3's Avatar
Default Re: Rear Suspension
ej8vtec
the bottom seat does not have to come out. There is a bolt near between the side bolster and the lower seat cushion, grab your ratchet, an extension and a 10mm socket (i think). push down on the lower cushion and you should see the bolt. take that off all you have to do is carefull slide you side bolster(s) up. this would give you access to the upper portion of the shocks.
99 integra ls
D_TY3 is offline Report Post   Reply With Quote
Old 10-27-2009, 12:32 PM   #3
EJ8VTEC
EJ8VTEC's Avatar
thank you sir
Go Lakers!
Old 10-27-2009, 01:22 PM   #4
aeon
aeon's Avatar
Send a message via AIM to aeon
Originally Posted by D_TY3 View Post
ej8vtec
Yeah that's it and to make things easier for next time, you can do it like me and not put the bolt back in. With the seats set back in place, the bolsters hold firmly in place. I'm always adjusting my struts so I'm back there a lot.
<U>DB Squad #22</U>
aeon is offline Report Post   Reply With Quote
Old 10-27-2009, 01:41 PM   #5
D_TY3
D_TY3's Avatar
in addition, when removing the lower portion of the suspension, it is not nec. to remove the sway bar link. all you have to do is remove the bolt holding in the strut, and then remove the bolt that hold the plate, which the strut bolt threads into, and also is connected to the sway bar end link. by removing this plate it will allow you to move the sway bar/end link assembly out of the way. i just did this, and i found this was the easiest way
99 integra ls
Old 10-28-2009, 04:54 AM   #6
Mr. DB2
I had to remove(loosen links and mounts and slide towards exhaust) the sway bar. 2 more minutes of work to remove and install.
2004 TSX BLK/BLK 6-SPEED W/NAVI.-CL9 squad member #110
Neuspeed Race suspension
Eibach(SPC) rear camber kit
Mr. DB2 is offline Report Post   Reply With Quote
Old 10-28-2009, 09:08 AM   #7
endlesswinterco
endlesswinterco's Avatar
the only problem with remvoing the sway bar from the endlinks is that the endlinks on our cars suck. they freeze up, those causing more of a problem to get off, and often need to replace them. I gone through two sets of endlinks while changing out my susp several times.
06 ABP TSX
CL9 Squad #7
endlesswinterco is offline Report Post   Reply With Quote
Old 10-28-2009, 12:58 PM   #8
Mr. DB2
^Maybe its your area. I buy my vehicles down south and bring back up to NC.
Old 10-29-2009, 07:25 AM   #9
D_TY3
D_TY3's Avatar
endlesswinterco, i agree with you 100%, that is why i dont even bother removing the links
99 integra ls
Old 10-29-2009, 09:14 AM   #10
endlesswinterco
it deff is. we get all four season, and a ton of salt every winter.
06 ABP TSX
CL9 Squad #7
Old 10-30-2009, 09:10 AM   #11
EJ8VTEC
EJ8VTEC's Avatar
A ton of bolts were pretty rusted on mine. Not to mention stripping the damn allen key stud at the top of the strut, that is always fun. Even with an impact damn thing still wouldnt come off, had to torch it. FTL. fun night
I found instead of trying to hold the strut center cylinder from turning with the allen key, just grip the strut with a set of vise grips makes it much easier!
Go Lakers!
Old 10-31-2009, 12:35 AM   #12
Brice.Hayden
1/2 Mexican
Brice.Hayden's Avatar
Send a message via AIM to Brice.Hayden
make me hesistant to do coils on my TSX. maybe ill just pay a guy at honda to do it for me
MissShift
Originally Posted by Arthas View Post
I love you too Brice.Hayden, I love you too.
Brice.Hayden is offline Report Post   Reply With Quote
Old 10-31-2009, 04:52 AM   #13
Mr. DB2
As long as your car is not rusty underneath you'll be fine. The proceedure is pretty simple. The front is just like an older honda(thank god b/c my FA5(F&R) was a bitch imo). The rear is a little more complicated with more stuff to remove,but still simple. The hardest part was taking the rear seat side bolsters out.
Bookmarks
2004, civic, honda, hot, rear, replace, shocks, suspension, susprnsion, tech, tsx
