#1 |
1995 Volkswagen JettaJoin Date: Oct 2009
Last edited by skthx; 10-30-2009 at 06:01 PM. Reason: improper title; more clear |
#2 |
ok bodywork started. finished putting metal in. diidnt bring my camera to work
but got 2 pics of my shitty phone. will take pics of finished product tomorrow. BEFORE ![]() ![]() AFTER ![]() This side was not finished yet.. only the inner wheelwell ![]()
#3 |
Looks like a lot of work...good luck with it!
By the way, if you use photobucket you can rotate your pictures.
My Integra Paint & Body Thread: http://honda-tech.com/showthread.php?t=2613670 Read this before a $50 paint job: http://www.honda-tech.com/showthread.php?t=2490171 |
#4 |
that is a lot of cutting buddy. GL
#5 |
heres some pics of the car finished with the metal part of the job... Also how do you like the drop in the front? the rears i haven't had time i need new LCA's to drop it. . .
#6 |
is this your first quarter job? if it is, props for diving into one hell of a mess. i myself have to do this to my own dc and im not looking forward to it.
the bottom of the quarter directly in front of the tire has more of a curve then your metal patch has. also, the wheel well could be more curved. you want to do the best you can with your metal patch so your not trying to make up for it being mis-shapen, with body filler. are you covering it with fiberglass filler? short strand filler is waterproof and wont soak up moisture like body filler will. not sure if you knew that or not so i threw that out there. props for using metal though. good work so far.
95 Integra LS |
#7 | |
looks like he is using duraglass, could be wrong tho. IMO duraglass is the best thing to use on rust repair after you weld/glue a patch on. i always add more fiberglass resin to it. it doesnt soak up water like bondo does.
#8 |
did u just shape your own metal and bondo it to the car?
#9 |
No its welded only the big gaps i put some duraglass indeed. I hate bondo with a passion and even refuse to use their mixing tools.
The most ideal way of doing a job like this is shaping one complete peice to get the curve to match. I had no time so i used several layers but i have an idea of what im going to do to shape it out nicely.. doing the prep work today or tomorrow will keep you guys posted. |
#10 |
patches look pretty good .
![]() It would be nice if rustrepair.com or fixmyrust.com made patches for Integra's . save alot of time and less bondo needed !!
Black 95 4dr Teg (WoRked) Ls-V EBP Em1 ,Laguna Seca b16 EK 94 dc2 ,92 Civic Si LS BOOSTED
#11 |
So finally got a day where it wasn't too busy so i started prepping the teg. Two quarter panels, two doors, fender, trunk, bumper. Started off by grinding it down
![]() ![]() Taking pics in the shop isn't the neatest thing ![]() Filled with superglass ![]() Cheesed, grinded / sanded with 40 ![]() ![]() Mixing lightweight filler ![]() ![]() Filled / sanded ![]() Some evercoat rage / filler at this stage i think ![]() Another area being assesed. (TYK previous owner fiberglassed it. ;() Word of advice, if you're shaving side mold's please do not fiberglass matt it. Simply sink it with a dolly and fill it with glass filler. ![]() ![]() ![]() Grinded, sinked holes and filled with superglass. ![]() Fender slightly was damaged/bubbling so might as well take care of that now. ![]() Another side sinked and filled as well. ![]() Trunk holes were also fg matted, lol, so same procedure. Grinded, sinked, filled. ![]() ![]() Fender ![]() Getting there, putty with some filler ![]() ![]() Sanded the glass, put lightweight filler over, sanded. ![]() ![]() Fixing some high spots. ![]() ![]() chessed / grinded ( ran out of 40 grit ) / sanded ![]() Lightweight filler, almost there ![]() Hmm ![]() Some of the tools ^_^ ![]() Some more minor highspots filled, then putty then 320 sanded ready for primer. ![]() Blowing the car from dust --> My man eran ![]() Quick masking job.. ![]() Blah.. ![]() b4.. ![]() primed.. ![]() ![]() Thats it for the day, will sand tomorow maybe one more time prime it, watersand and ready for paint! YESSSIR! hope you enjoyed. Feel Free to ask questions. |
#12 |
nice. look forward to see tomorrow work!!
#13 |
sanded primer, primed again...
![]() ![]() Machined with 320. Started water sanding.. with 600 over everything with the exeption of the uper quarter panel trim, and of the two fenders with 2000 since its only being blended. (clear coat only). ![]() ![]() ![]() ![]() Turned out the kid partially painted the bumper with a spraycan before and didn't even clear it lol ... Going to repaint the whole bumper now.. Sanded... ![]() ![]() Washed, thinned inner trims of oversprayed primer, will mask the car tomorrow and shoot it friday or early saturday. ![]() ![]() This was a fun project, but, shows how a small job can go far. If you don't know much about bodywork, you will, in the end pay someone else not to only finish the initial damage but cleaning the mess of your work ![]() Will give you guys the paint tips and which paint / clear / gun im using when i spray it. |
#14 |
1995 Acura IntegraJoin Date: May 2009
what kind of primer did you use?
#15 |
Is this your dads work you were talking about in another thread?
60% of the time, it works everytime... |
#16 |
#17 |
that passenger side doesn't look right
#18 |
#19 |
i would have used some rust mort behind the quarter, its cheap insurance that the rust doesnt take control again. It only takes 0.006 of a square in for the rust to reappear
#20 | |
Love it or Hate it...get over it!
#21 |
How is that one simple word exactly?
#22 |
lol i sealed the weld spots.. especially on the other side & one stepp'ed & undercoated. car is painted ... just need to polish out the top .. will take some pics tomorrow
#23 |
I meant a couple of words smart ass!
#24 |
How do you know this? are you a body tech? I've seen this done and its never rusted from the under side. Its true it is a fifty fifty chance it might show up again depending on how well he primer and color the whole underside and top along with his body work. I've even done it myself buy not on my hatch. Yeah but you are right so I'm giving the guy his other alternative since he doesn't have access to a MIG welder.
#25 |
![]() ![]() ![]() ![]() will repaint bumper after winter. |
| Bookmarks |
| Tags |
| acura, bondo, civic, dc2, fiberglass, filler, honda, hondatech, panel, panels, quarter, repair, replacement, shaping, soak, water |
