#26 | |||||
#27 |
![]() hell yes, that bitch is huge! At least its machined to fit the wheel hub flush. I also wouldn't doubt they added it for brake clearance as well.
Fernando Alonso Nut/Cawk- Rider Crew Member #02 |
#28 | |
http://www.hondatuningmagazine.com/t...eel/index.html If you have any questions about this, please do not hesitate to add them to this discussion.
2009 #31 CRX H4 Honda Challenge 2009 #37 Integra H4 Project Car (Halfway from HPDE to race spec.) Aerodynamic Solutions Motorsports |
#29 |
For solo II, track width does play a large role in the optimal driving line and there is a large trade off with the wider you travel around the cones.
Marc Sasso m_sasso@shaw.ca G2 Integra Parts For Sale http://members.shaw.ca/m_sasso/forsale.htm |
#30 | |
Consider what happens if you have a really thick spacer, and you have these different suspension geometries: A) a really strong camber curve - a small deflection of the suspension causes the top of the wheel to flop inwards. b) a parallelogram linkage where the camber is a constant 0. c) opposite of A), where a small deflection of the suspension causes the top of the wheel to flop outwards. Again, the effects of a wheel spacer on effective wheel rate comes thru the camber curve, NOT the increase in lever length of the LCA.
Eibach: The WILL... to reduce unsightly fender gaps |
#31 |
I think you're failing to realise that the location of the LBJ does not factor into the lever arm length when looking at the wheel rate. The lower control arm does not bend at the LBJ. The effective length of the lower control arm in an OEM configuration is the total length from the inner pivot point at the chassis to the center of the contact patch of the tire. Not the inner pivot point to the LBJ. If you move the contact patch further out (wheel spacers) the effective length of the arm increases which alters the wheel rate.
#32 |
1) On a car with an upper control arm, wheel spacers will NOT effect the wheel rate
2) On a car with a strut (no upper control arm), wheel spacers will effect the wheel rate.
NASA Road Racing. Visit McKinney RaceWorks for info about my race car. Visit MFactory Competition Products for info on my sponsor!! |
#33 | |
#34 |
while i know you can find anything on the net here is one of the first images that popped up on google image search.
http://www.miracerros.com/mustang/t_wheel_rate.gif I don't see how it matters between strut or DBW/multilink. You are still moving the center of the tires contact patch further away, increases the total distance. Like jaker said the LBJ is a solid attachment point.
Check out my BLOGhttp://thenextenth.wordpress.com/ Thanks to.. www.motowear.com www.prima-racing.com www.hasport.com |
#35 |
I tried simply saying it. Then I tried giving examples. Now I have no choice but to be a pedantic ass. Look at these two diagrams, which spells out how the UCA DOES matter in terms of wheel spacers. Because it sets the camber curve.
![]() Now watch what happens when you take away the camber curve. ![]() And yes, there are some approximations.
#36 | |
PN# 44300 SB2 966 Hit up Jeff @ Proparts USA he's got them.
Wheels for sale! Yokohama Kruezer XII 15x7 4x100 BNIB, Volk RE30, Rays 57 Motorsport CSCC STS #352 1989 Honda CRX Si |
#37 | |
#38 | ||
ProFunction/GT Motoring
1998 Acura Integra |
I didn't check back this thread until now, didn't know it got into more discussions.
![]() Quote:
For those who can't visualize it, try drawing simple free body diagrams. For DWB, spacers would increase the compression and tension on the UCA and LCA due to the longer moment arm, but the vertical forces that get transferred to the hub surface would not change; and hence, the force being applied to the spring would not change. In simpler words, the additional force resulted from the thicker spacers is being resovled as a couple (tension/compression) and is taken by the control arms. The spring wouldn't see any of that. I hope I get the point across, and of course I would welcome any corrections if I were wrong. |
#39 |
A strut suspension generally has even less camber change than a double wishbone, so the effects of a wheel spacer would be even less. As you say, all that "extra leverage" from the wheel spacer will go into side loading the shock, not compressing the spring.
| Bookmarks |
| Tags |
| 08, acura, autozone, civic, drag, honda, hx, integra, racing, si, spacer, spacers, tech, tl, wheel |
