#1 | |||||
#2 |
Not a problem at all
Check out my BLOGhttp://thenextenth.wordpress.com/ Thanks to.. www.motowear.com www.prima-racing.com www.hasport.com |
#3 |
I have an inconsistant brake pedal and I was told it was most likely due to the wheel bearing causing the calipers to open up...the spacers would be stressing the bearings???
#4 |
Location: where i stunt SAND CANYON in Southern California
they shouldn't unless ur wheel bearings are already bad..
#5 |
Nice looking EG!!!!
I think wheel spacers can add a lot of stress to the wheel bearings. I use them and i go through wheel bearings on a regular basis, just be carefull. Spacers are a great tuning tool
2009 H2 National Champion - Because of the people who support me - Afterhours Automotive , Mfactory, Church Automotive Testing, Synchrotech Transmissions, Portflow cylinder heads, Hasport. AND MY HIGHLY ANNOYED DRIVING COACHES |
#6 |
Re; bad pedal:
What kind of calipers do you have? I'm inclined to say that the issue is much more likely to be a bad hub/ wheel bearing. Then a spacer adding stress and causing the flexing. Spacers are, in a way, just like running a low offset wheel. We've always ran spacers, and never had a problem with them. On the 06 si we ran something like 1.5 inchs of spacers up front, for 25 hours... Not a problem. If you run the 88-91 crx/civic or 92-00 cx/dx/vx/hx upright you will go through hubs/bearings. Much more frequently then the bigger upright.
#7 | |
92 Civic Si #43 RTA SFWD 2009 --> HCH2?! http://charlesctran.blogspot.com Special Projects MS - PC-I - MOTUL Lubricants - Toyo Tires - Plan:B Motorsports - Carbotech Brakes Last edited by .:Made in OC:.; 10-22-2009 at 01:08 PM. |
#8 |
Honda don't make bearings, they use KOYO and NTN...I use them with great durability, and I get them from any local part store for much less than @ the dealer.
Concerning the EP3.....nice buy !!!!!!
Thanks George @ HT, thanks Ryan @ Eibach, thanks Lee @ Koni. Unban Kiwi. |
#9 |
^Good to know, thanks for sharing. Even with NASA club discounts those things are expensive, how much did they run you at the parts store if you don't me asking?
#10 |
I think they are around 40 to 50, not 100% sure on that.
#11 |
I just replaced the front bearings on my EJ1 with Timkins from Autozone, and I think they were about 30 per.
#05 ITA Honda Civic EX - 2005 SCCA Cal Club Reg ITA Champion FilterMAG http://www.filtermag.com Advanced Waterjet & Engraving http://www.advancedwj.com |
#12 |
What about Moog bearings?
Does anyone have a ntn or koyo bearing number for a 89 crx? |
#13 |
knock back, with stock rotor and caliper... that is an issue with the braking system, or with the hub/bearing.
#14 | |
ProFunction/GT Motoring
1998 Acura Integra |
Besides that, spacers retard the motion ratio, making your suspension effectively softer. Again it's not something "bad", just needs to be accommodated by adjusting the spring rates. |
#15 |
So I guess it affects the steering acrenum!!!
I Have 700lbs front and 1200lbs rear and I notice that my front was little on the soft side...keep in mind I have to run 205-15-50 |
#16 |
24.5" slicks for sale with wheels. $340 shipped. |
#17 |
^^^ I was wondering if anyone was going to say anyting haha
#18 |
I think it only softens the suspension very very slightly due to camber curve, not motion ratio.
Eibach: The WILL... to reduce unsightly fender gaps |
#19 | |
That will reduce the motion ratio. Correct?
#20 |
The "lever arm" does not increase because there is a pivot at the lower ball joint. If the camber curve is zero (knuckle stays exactly level through the suspension travel), then extra wheel offset won't affect wheel rate.
#21 | |
At least, that's how I've read it, and it makes sense to me. |
#22 |
Yes, if the center of the tire's contact patch moves further from the inner pivot as well as the shock attachment point on the LCA (fulcrum), then the leverage ratio will change.
#23 |
Car is looking good. Shouldn't be a problem if your bearings are still good. The Wider the better basically is what i do
down with the sickness son... |
#24 |
thats what pontiac says lol.
#25 |
Good to know I wasn't just dreaming. I run a set of 1" spacers in the front of my car and always swore that the front end felt so much more planted. I originally did it for looks but after my first run I was loving how good the car felt.
Fernando Alonso Nut/Cawk- Rider Crew Member #02 |
| Bookmarks |
| Tags |
| 08, acura, autozone, civic, drag, honda, hx, integra, racing, si, spacer, spacers, tech, tl, wheel |
